Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Jun 7, 2019 at 8:41 AM
    #331
    effektz
    effektz New Member
    Fort Worth, TX
    2017 Tundra CM TSS Offroad
    I ordered mine last Friday, they shipped on Monday from China and its being delivered today. So 4 business days really. They shipped mine UPS Worldwide Expedite
  2. Jun 7, 2019 at 8:41 AM
    #332
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    2-3 days they do dhl express. at least for me.
  3. Jun 7, 2019 at 8:46 AM
    #333
    tinman10101
    Tinman
    2016 MGM Crewmax
    factory mic: i have researched and tapping into factory mic seems impossible so far. please let me know if you find out different. i plan to run extension mono 3.5 mm from factory location around windshield down pillar and into dash.
    android auto: you can run your own launcher. just download the launcher in play store then you can go to settings - default apps and set it to the launcher. some of us use nova launcher and some like the UI launcher it comes with. I personally like the car launcher AG and its $1.99 ... i pair that up with poweramp because the music portion interfaces with it. I have yet to figure out the SMS portion but then again i have my cellphone mounted next to it and just glance with my eyes.
    SWC: there is a steering wheel app that you must launch to program. you can map long and short depresses. if it doesnt work you might need to go into factory settings and under "other" tab there is a steering wheel control option, you might need to change it from canbus to swc or reverse. hope this helps.
  4. Jun 7, 2019 at 10:54 AM
    #334
    Topherwv
    Topherwv New Member
    Thanks, I'll run their mic to the steering wheel column this weekend. I downloaded CarWebGuru at lunch and so far I'm liking this interface. I got Google Hangouts to work but when i installed Verizon messenger + it crashes out immediately after opening. Probably because there's no SIM card or cell signal. I'm sure there's an app that goes through bluetooth or such to gain messages but the last thing i need is another unknown publisher gaining access to my messages.
    Anyways, thanks for the support. I was going to change the steel wheel option under factory settings but didn't want to goof things up too badly.
    Will try that and report back later today.
    tinman10101[QUOTED] likes this.
  5. Jun 7, 2019 at 3:06 PM
    #335
    Topherwv
    Topherwv New Member
    Yup that worked switching to CANBUS but can't hold for Assistant.
    Really liking this User Interface much better.
    Thanks again
  6. Jun 7, 2019 at 5:06 PM
    #336
    tinman10101
    Tinman
    2016 MGM Crewmax
    That's great. I'm super anal so when I received mine I spent literally three days straight learning the whole user interface and all settings. Glad I could be of help.
    Topherwv[QUOTED] and Wynnded like this.
  7. Jun 8, 2019 at 11:34 AM
    #337
    effektz
    effektz New Member
    Fort Worth, TX
    @VTYOTA where did you run the power cable for the camera?
  8. Jun 8, 2019 at 11:40 AM
    #338
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    For the front camera? There is a wire for the FCAM power source on the same harness you would plug in the video feed for the FCAM. The camera I bought had a “trigger” wire that I used to connect the power to the front camera. Take a look at post #246.
    Here is the picture from that post. I used a Posi-Lock to connect the two wires.
    effektz[QUOTED] likes this.
  9. Jun 8, 2019 at 3:31 PM
    #339
    effektz
    effektz New Member
    Fort Worth, TX
    Thanks @VTYOTA . I got the HU working and all but the only thing is my factory back up camera does not work. Not quite sure which cable that one is because I didn’t see an RCA connection on the factory head unit
  10. Jun 8, 2019 at 3:46 PM
    #340
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    Did you look at post #33 that @916tundra provided? It tells you everything you need to know about all the cables provided with the head unit. #2 in post #33 is what you need to connect your rear camera.
  11. Jun 8, 2019 at 5:36 PM
    #341
    effektz
    effektz New Member
    Fort Worth, TX
    Yeah I saw that post but didn’t help. There is 2 yellow wires coming from the Canbus, both labeled CAM VIN. On the harness to the HU, there is one yellow labeled CAM VIN and one labeled VID AUX IN. After playing around, I found out all I had to do was switch the two CAM VIN around and it worked.
  12. Jun 9, 2019 at 3:58 PM
    #342
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    Anybody have photos of where they poked the camera wire through the firewall at?
  13. Jun 9, 2019 at 5:14 PM
    #343
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    I went through the rubber grommet on the driver's side. If you search FRAC and go to the FRAC thread, the first post has a front cam installation video. They go through the passenger side firewall though. Basically the same idea, you just pick which side you want. I already had a hole in my driver's side firewall grommet from my LED headlights installation.
    BeachyTundra[QUOTED] likes this.
  14. Jun 9, 2019 at 7:13 PM
    #344
    effektz
    effektz New Member
    Fort Worth, TX
    I went through the passenger side like in the video. Does anyone know where you can get new car launchers? Is it just in the play store? Got mine all hooked up, I like the unit but looking for a good UI
    BeachyTundra likes this.
  15. Jun 10, 2019 at 4:36 PM
    #345
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    Ordered last Friday but hasnt shipped yet. Will have all the other stuff for the install by Thursday. Anxiously awaiting the HU to ship.
  16. Jun 11, 2019 at 4:34 AM
    #346
    prerunnerseth
    Apex, NC
    Mine is due in on Friday. Hope I can find time to install on Saturday. Going to be a nice day and will probably be on the lake instead.
  17. Jun 11, 2019 at 8:53 AM
    #347
    minter66
    minter66 2007 TSS CrewMax
    Sorry - been in the mountains of Colorado for the past week. It sure was nice having this headunit on the 14+ hour to/from drive when towing my Travel Trailer. Music, maps, even downloaded Amazon prime so the kids could watch some educational cartoons.
    As far as your question - I had plenty of cable and I can try to get you more photos if you still need them. I mounted the cam by drilling through the bottom of the Toyota emblem. Then just ran the wire across the grill and then zip tied it using holes in the underside of the hood. It looks a lot like the windshield wiper fluid hoses if you aren't paying attention.
    As it has been mentioned before, there is an actual camera that fits inside our Toyota Logo with no drilling/cutting required.
    VTYOTA and jmevis like this.
  18. Jun 11, 2019 at 2:17 PM
    #348
    stonesmith
    stonesmith New Member
    2019 Tundra SR5
    Hi all - Thanks for creating this thread, it is amazing.
    I am putting together a cart to purchase, but things keep changing from the initial list of components posted back in April. Now the base unit appears to be Android 9.0 with rockchip px6. you can order the older gear but it is the same cost. Unless there is a compelling reason, I am inclined to go with the later gear.
    https://www.aliexpress.com/item/33014370012.html?spm=a2g0o.cart.0.0.68603c00rq1LaV
    Model Name: HA2156A-MAX6 - $434.7
    OS : Android 9 Pie
    CPU : RK3399 , Dual Cortex-A72 + Quad Cortex-A53,
    64-bit RAM : 4 GB ROM : 64 GB GPU : Mali-T860MP4 Radio : ST7708 Bluetooth : CSR BC6
    Ordering from Aliexpress saves about $70 over Amazon....
    Any comments would appreciated...
  19. Jun 11, 2019 at 2:25 PM
    #349
    tinman10101
    Tinman
    2016 MGM Crewmax
    That is their price without the canbus. they will tell you to tag on another canbus item to customize it for your tundra.
  20. Jun 11, 2019 at 2:35 PM
    #350
    VTYOTA
    Howard
    'Merica
    2014 SS CM TRD
    It also doesn't include the Android Auto/CarPlay Dongle. Also, the Max6 is also a different unit then the one most of us installed. Not sure if it will work with GEN3.
    EDIT: Forget the comment about Max 6. I guess that's what they are calling it now.
  21. Jun 11, 2019 at 3:12 PM
    #351
    stonesmith
    2019 Tundra SR5
    Thanks for the comments. I have loaded the canbus and dongle in the dongle in the cart as well,but that is all unchanged.
    1. Canbus CB004, $35
    2. Carplay dongle, $60.39
    I will also have to order some cables from crutchfield, like the usb adapter, etc.... I am also unclear if the external mic is included or if that was a "free gift". But I can sort that out when the package from china arrives.
    Still for about $550 plus a few extras, this should be a killer deal.
    I read that some were hesitant PX6 because it was so new. I am outside my depth here so was wondering what experience others had.
  22. Jun 11, 2019 at 3:22 PM
    #352
    prerunnerseth
    Apex, NC
    Looks like they pushed my delivery to Monday :confused:
  23. Jun 11, 2019 at 3:29 PM
    #353
    tinman10101
    Tinman
    2016 MGM Crewmax
    you definitely want to sort it out before they ship. the mic is included. if you are missing something, they will send it regular china post and that takes 4-6 weeks.
    your best bet is to do it through Amazon. they will give you a package deal for everything for $480. just message the seller and tell them you are from the tundra forum. PX6 works fine. I have PX5 chip and there is no noticeable difference.
  24. Jun 11, 2019 at 3:34 PM
    #354
    stonesmith
    2019 Tundra SR5
    Thanks Tinman.
    I did not realize the $480 price on Amazon included the canbus adapter an the dongle. I will message them and confirm.
    tinman10101 likes this.
  25. Jun 11, 2019 at 3:38 PM
    #355
    tinman10101
    Tinman
    2016 MGM Crewmax
    straight from the horses mouth ... lol
    EDIT: so it looks like they wanted $10 for shipping now
  26. Jun 11, 2019 at 4:43 PM
    #356
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Maybe they're forecasting headwinds for the slow boat?
  27. Jun 12, 2019 at 7:27 AM
    #357
    minter66
    I paid the extra $10 for 7-day shipping when I set up the original Amazon deal that everyone is using. If someone got 7-day shipping for free - post up.
    Beats 1 month on a ship. I literally just got a replacement cable from Thailand for my headlight levelers. Took 31 days.
  28. Jun 12, 2019 at 9:12 AM
    #358
    prerunnerseth
    Apex, NC
    I didnt pay anything extra and mine will be a little over 7 days
  29. Jun 12, 2019 at 9:13 AM
    #359
    prerunnerseth
    Apex, NC
    Sweet. Delivery day is back to friday!
  30. Jun 12, 2019 at 3:24 PM
    #360
    stonesmith
    2019 Tundra SR5
    I heard from Iris that she will honor the Tundra Forum deal, by unit is out of stock. Will take 2 weeks to resupply.....
