CV Axle Concern
Discussion in '3rd Gen Tundras (2014+)' started by Acrotalus, Mar 11, 2019.
  1. Mar 11, 2019 at 8:31 PM
    computeruser6
    computeruser6 Climate heretic
    Dirk
    San Diego
    2008 Regular Cab Tundra
    Yes, move the collar adjuster on the coilover. It doesn't take long if the right tool is used:
  2. Mar 12, 2019 at 12:26 PM
    Acrotalus
    Acrotalus [OP] New Member
    TX
    2016 Quicksand TRD Pro Tundra
    Fab Fours Elite Bumpers Total Chaos Shackle TRD front and rear sway bar Westin R7 Running boards
    Can I take out the preload using the spanner wrench with the coils still on or do I have to remove them and use compressor tool?
    Icons look like you can just take out set screw and adjust while still installed
  3. Mar 12, 2019 at 12:39 PM
    15whtrd
    15whtrd Mr. Blonde
    White 2015 Tundra DC SR5 TRD 4x4 5.7L
    TRD Pro suspension, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate.
    Man we were just talking about this a month ago. Ideally you would want to remove them. If you do it while they are on the vehicle you want to take as much load off of them as possible. Jack the truck up. Make sure everything is really clean so you don’t gall up the threads. Loosen the setscrew but only a little so you don’t jump the threads and mess them up. Did it come with a little spanner wrench? Depending on which one you have, some say they are pieces of shit. Some have resorted to donating a screwdriver and modifying it to use as a spanner wrench.
    @ColoradoTJ do you have any suggestions? Since I haven’t personally done this I don’t really want to recommend anything. I thought I remember in that thread some of you talking about certain shocks you shouldn’t do this to. Maybe you recommended not doing it on the truck at all. What say you good Sir?
    TheBeast likes this.
  4. Mar 12, 2019 at 12:45 PM
    15whtrd
    15whtrd Mr. Blonde
  5. Mar 12, 2019 at 1:03 PM
    Acrotalus
    TX
    Thanks. My CV angles are off because there is like 4” of preload on these coils. Even after adding CB +3 shackles (and 4” block with kit) to the rear, the front is still pointed at the sky. I work in the oilfield and have a shop, and jacks at my disposal, but getting it taken somewhere to get adjusted will take more time than I have. If I can jack the truck up and do it on my own, I want to try that.
  6. Mar 12, 2019 at 1:04 PM
    15whtrd
    15whtrd Mr. Blonde
    Check that thread out that I posted
    It’s really not that hard to remove the coil overs. But you will need an alignment again. But in that thread they discuss adjusting them on the truck.
  7. Mar 12, 2019 at 1:06 PM
    Acrotalus
    TX
    Thanks I’ll be giving that a shot. I have a Fox spanner wrench to use, shouldn’t be too hard. I appreciate it.
    15whtrd likes this.
  8. Mar 12, 2019 at 1:09 PM
    15whtrd
    15whtrd Mr. Blonde
    No problem. Hope you get it sorted bro
  9. Mar 12, 2019 at 2:19 PM
    computeruser6
    Dirk
    San Diego
    Any load placed on the coil will make adjustment more difficult. My Kings have a collar adjuster and it's still best to remove all load from the spring. The housing is aluminum and will gall easily.
  10. Mar 12, 2019 at 2:24 PM
    Acrotalus
    TX
    Don’t have the time or the tools. I work about 150 miles from civilization in any direction. I am relieving the coil of the load, so hopefully it’s easier than trying to apply additional load. I’ll see how it goes, fingers crossed.
    It would have been a lot easier to have the installer do it right the first time, even when I told them I wanted at least 1” of forward rake and they had it for FIVE days
    TheBeast and 15whtrd like this.
  11. Mar 12, 2019 at 2:28 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah! You’d think after what you told them that they would’ve readjusted it from the start. You never know height it’s going to sit at until it’s on the truck. The springs may settle a little but not that much.
  12. Mar 12, 2019 at 2:58 PM
    computeruser6
    Dirk
    San Diego
    The coil itself is a load if it's touching the collar. They took five days to install drop brackets?
  13. Mar 12, 2019 at 3:05 PM
    Acrotalus
    TX
    The hardware kit for the coils wasn’t shipped so they had to wait for BdS to send it, then it overlapped a weekend where they don’t work...
  14. Mar 12, 2019 at 5:25 PM
    LT75
    LT75 New Member
    Saint Charles, IL
    2018 White Platinum Crewmax
    Icon 3.5/3 lift, 20” KMC XD wheels on 285/65/20’s.
    Lowering is definitely easier than adding lift if the truck is not jacked. It really depends on the thread conditions.
  15. Mar 12, 2019 at 5:51 PM
    Acrotalus
    TX
    Brand new so hopefully it can be done easily. Will report back tomorrow on success/fail!
  16. Mar 12, 2019 at 7:38 PM
    texasrho83
    texasrho83 Teacher in a Tundra
    Charles
    Conroe TX
    2016 DC MGM 4x4
    I've done a little..
    Mannnn I'd be miffed if a shop let me drive it home after doing major suspension work on it like that knowing the CVs weren't right.......
    15whtrd likes this.
  17. Mar 14, 2019 at 9:32 PM
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky TrD offroad double cab
    E658E5FF-E9D0-47C4-AD6B-0333011F842F.jpg These cheap coil spring compressors will be able to take a lot of the pressure off. That way you dont need to pull out the coilover. I did it before, just spray some lub on the colars also
  18. Mar 14, 2019 at 9:37 PM
    Acrotalus
    TX
    Yessir these are exactly what I ordered. They arrive tomorrow! Thanks amigo
  19. Mar 14, 2019 at 10:54 PM
    #49
    Fish2eat88
    Jay
    If your even lazier then me, i jacked it up, turn the wheels one way and worked one side at a time haha tight fit but it works
  20. Mar 14, 2019 at 11:05 PM
    #50
    computeruser6
    Dirk
    San Diego
    Be careful, that type of spring compressor is meant for a MacPherson strut, not a coilover.
    Edit: Also, the presence of the reservoir hose will make adjustments while installed on the vehicle very difficult.
