Custom Under-Seat Storage (crewmax)
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1_thirsty_tundra, Dec 5, 2019.
  1. Dec 5, 2019 at 11:03 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I would have to pay someone to do it for me. Dont have the tools and I was not real good in wood shop... :sawzall:
    GODZILLA likes this.
  2. Dec 5, 2019 at 11:07 AM
    :rofl: I don't know any half assed carpenters. I figure a Master is better than nothing, right?
  3. Dec 5, 2019 at 11:26 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    A Canadian vendor!!:canada: :yes::D
    Really nice work! That looks awesome!
    if you ever want to make money with this let me know, I’ll be first on the list lol.
  4. Dec 8, 2019 at 5:03 PM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Nicely done man!
    1_thirsty_tundra[OP] likes this.
  5. Dec 8, 2019 at 5:08 PM
    Fire123
    Fire123 New Member
    2015 White 1794 Edition
    7" BDS w/ Fox, Fuel Wheels
    SOLID WORK!!! You should mass produce for a little supplemental income.
  6. Dec 19, 2019 at 10:14 AM
    November Sun
    Huntsville, Alabama
    I'd buy one
  7. Dec 19, 2019 at 3:39 PM
    Borador
    Borador New Member
    Olive Branch, MS
    2016 Crewmax 4x4 w/1794 Interior upgrade
    Awesome job!!
  8. Dec 19, 2019 at 4:07 PM
    DoubleJackOnTap
    DoubleJackOnTap New Member
    SW Washington
    2018 Super White TRD Sport
    CoverKing Neoprene Seat Covers, UltraFlex
    That is a very nice box. Best I've seen yet.
    On a side note. Where did you get the floor mat? I haven't seen that one before.
    sf319 likes this.
  9. Dec 19, 2019 at 4:59 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Can you tell what structure the seat bases are connected to?
  10. Dec 30, 2019 at 1:19 PM
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    Well. I'm that half assed carpenter today!
    I blew your photos up as much as I could and copied your design. From what I could garner from the pictures and few measurements you provided. A huge Thanks from me!!!!! If you make it down to Orlando, a cold bucket of bottles of your choice awaits!
    Here's what I came up with for anyone else feeling inspired by these projects:
    Template:
    One of my employees has a Tundra CM, and he too was looking for under seat storage. I had a full sheet of plywood for this project, so I made two from the sheet:
    Here's one completed from carpentry:
    Thanks to you and your ideas, I'm having them sprayed tomorrow, and then I'll install mine after Holiday and his next week.
    I used a Blonde wood 1/2 inch plywood furniture grade from Lowe's. I'll have a whopping $80.00 in both of them when they are completed. Took me about four hours today to build them. Without your pics and description, it would've taken me much longer.
    Thanks again!
    Randy
    Yota559, blizz86, GODZILLA and 2 others like this.
  11. Jan 2, 2020 at 3:09 PM
    tech1208
    Orlando, FL
    Here it is completed and installed. My 2020 has the keyless FOB, and the antenna for this is located underneath where the center box would be. I drilled a 7/8 hole through the front of the box, and mounted the antenna inside the front vertical board. For anyone else doing this, you need to beware when cutting the foam on the center of the vehicle. It's slightly off centered to the driver's side. I cut the rear, and sides and presliced the upper portion of the foam not going all the way down and pulled upward from the rear forward to break along my splice. This allowed the cable to be unharmed.
    Thanks again for the design.
  12. Jan 2, 2020 at 3:16 PM
    Rocman
    Rocman New Member
    Randall
    Reno, NV
    2019 Tundra Platinum
    Well done!
    tech1208 likes this.
  13. Jan 2, 2020 at 3:18 PM
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    One of the best custom mods I've seen.
  14. Sep 25, 2023 at 8:08 PM
    Breckler23
    Breckler23 New Member
    Georiga
    2025 Limited TRD OR Black
    How did you wire that to the dome light?
    bmann7 and marcelo73 like this.
  15. Sep 26, 2023 at 10:28 AM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    I'd buy that just for the lighting and looks of it - nice job!
