CrewMax Rear seats
Discussion in '2.5 Gen Tundras (2014-2021)' started by westcoastmcgyver, Jan 22, 2023.
  1. Jan 22, 2023 at 12:15 PM
    westcoastmcgyver
    westcoastmcgyver [OP] New Member
    New to me 2018. Is there a way for the rear seats back portion to fold forward? I can't see anything and would like to utilize the room behind for tools/jumpers/ect
  2. Jan 22, 2023 at 12:22 PM
    Taco-Spike
    Two Trucks
    Take them out or fabricate a bracket assembly. I like my Tacoma does it but I just put the back seats up in the tundra and stuff everything up there from the bottom (insert joke)
    I also leave the tundra back seats up all the time anyway
  3. Jan 22, 2023 at 12:24 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    The 2007-2013 2nd gens did this. For 2014+ 2nd gens, your path of least resistance is aftermarket storage for under the seat like the ESP long box:
    ZappBrannigan and bulldog93 like this.
  4. Jan 22, 2023 at 5:30 PM
    jhinderliter
    jhinderliter New Member
    dondino and bulldog93 like this.
  5. Jan 22, 2023 at 7:31 PM
    2mchfun
    Floor storage is best, it keeps the weight (tools) down low where you want it.
  6. Jan 22, 2023 at 7:40 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is there no option to cut the upper seat bracket like in the DC?
  7. Jan 22, 2023 at 7:45 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Nope. The seat back is completely static in the CrewMax.
  8. Jan 22, 2023 at 7:46 PM
    2mchfun
    You could keep an electric 12volt plug impact under the front seat or in the console to make for quick and easy seat removal and installation. Not saying it's a great idea, but certainly a possibility. Depends on how often you want access. Lots of possibilities under the hood exist also. I'm going to try to work my hi lift in the engine bay in separate parts.
  9. Jan 22, 2023 at 9:54 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    This is the best answer. I didn’t go with longbox because it uses aftermarket seat brackets. When it comes to safety and crash ratings I prefer to stick with factory engineering. I have the one that adds 3 boxes under the seat, as one large unit, that keeps the factory brackets. It was a pretty easy install once you get past taking a knife to your carpet.
    2mchfun and Terndrerrr[QUOTED] like this.
  10. Jan 23, 2023 at 6:14 AM
    Terndrerrr
    Music City
    6UR-FE
    Agreed, very easy install. I have zero concerns with the ESP seat mounts. ESP did not cheap out on these in the slightest. They are just as beefy and heavy as OEM and appear to be just as well made. They don’t change how the seats are supported or where they mount.
    The brackets on our trucks are elevated all the way forward because the 2nd gen Tundra rear seats used to slide and recline. Toyota removed that feature in 2014 but kept the same brackets that create that useless elevated shelf on the rear floor. Kinda lame.
    The ESP mounts are the same size as OEM until the part that is forward of where the seats mount.
  11. Jan 23, 2023 at 6:19 AM
    2mchfun
    Are you saying or do you know for a fact that I could easily swap over to the previous rear seats and gain recline feature or is the high floor foam going to be a problem? I'd like to have the recline feature and a DIY underseat storage unit if possible for a decent price.
  12. Jan 23, 2023 at 6:25 AM
    Terndrerrr
    Music City
    6UR-FE
    All I know from reading is that the brackets never changed in 2014, and the early 2nd gen trucks’ rear seats slide and recline. I’m assuming that in order to slide and recline the rear seats, you would need that OEM bracket height all the way forward. But I haven’t checked into it.
    2mchfun[QUOTED] likes this.
  13. Jan 23, 2023 at 6:27 AM
    timsp8
    NY
    There was someone on here about a year ago that tried to swap 07-13 seats into their 14-21 and said it didn’t line up. I don’t remember who it was though.
    Edit: maybe I was wrong, although this guy never came back with pics.
    https://www.tundras.com/threads/gen-2-tundra-seats-fitted-in-my-gen-3-tundra.60312/
  14. Feb 21, 2023 at 12:44 AM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
  15. Feb 21, 2023 at 8:23 AM
    coTony
    Tony
    Montrose, CO
    I do not remember the last time someone sat in my back seats
  16. Feb 21, 2023 at 8:28 AM
    jhinderliter
    works great, easy install and tucks up nicely in the wheel well..
    its big enough for jumper cables a tow strap , cargo straps , tire plugs/mini compressor , ect ...
    fits under my bed cover , its lockable and its easy to remove if you need to..
    didnt have to cut my cab up either..
  17. Feb 21, 2023 at 11:58 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    You can do more with a back seat than just sit in it.
    bulldog93 and Mater like this.
  18. Feb 21, 2023 at 1:50 PM
    coTony
    Tony
    Montrose, CO
    I keep telling my wife that. Thing is I have no place to put the seats. That would be a bitch getting in the attic
    EDIT: Well after our 3,500+ mile adventure across the country my wife is convinced that it would be much better with no rear seats. I am sure I could get folks to sit in the bed if I had to pickup anyone from the airport or something
    ZappBrannigan[QUOTED] likes this.
  19. Feb 21, 2023 at 2:05 PM
    Rocko9999
    Rocko9999 New Member
    What would cutting the bracket provide?
  20. Feb 21, 2023 at 2:33 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The back would fold down.
  21. Feb 21, 2023 at 2:51 PM
    Rocko9999
    Wouldn't that make them useless as a seat without a secure back?
  22. Feb 21, 2023 at 2:54 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Rocko9999[QUOTED] likes this.
  23. Feb 21, 2023 at 3:03 PM
    Rocko9999
    TRDFerguson[QUOTED] likes this.
  24. Feb 21, 2023 at 3:14 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I have always wanted to take the rear seat from a 2007-2013 CM and put it in my 2014. The ability to move the seat and recline would have been killer.
    DeesCrewMax and ZappBrannigan like this.
