CRAWL RATIO
Discussion in '3rd Gen Tundras (2022+)' started by FO LO, Sep 11, 2021.
  1. Sep 14, 2021 at 10:34 AM
    FO LO
    FO LO [OP] New Member
    17 CM w/ 5.7 and 4.30s
    No just a baseline to see which direction the turbo tundra is going off road or highway.
    timsp8[QUOTED] likes this.
  2. Sep 14, 2021 at 10:35 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I don’t see any need for a higher ratio in low range for crawling than what is currently found in the current Tundra.
    Put me down in the camp of guys who would not rock crawl their daily driver truck. I’d far rather have a versatile reliable Jack of all trades pick up, and a nice trailer to tow my off road toy to its play ground instead.
    2mchfun, snivilous and FO LO[OP] like this.
  3. Sep 14, 2021 at 11:07 AM
    Kung
    KG, VA
    Pretty much this. I absolutely bought my Tundra to be able to have a versatile reliable truck.....but almost nobody buys a brand new Tundra expecting it to rock crawl (stock, anyways).
    FO LO[OP] likes this.
  4. Sep 14, 2021 at 11:24 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    I do almost all of my off roading in Florida in 4 high.
    ArcticEd and FO LO[OP] like this.
  5. Sep 14, 2021 at 11:30 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Serious question, do you really need 4LO in Florida aside from sanding conditions?
  6. Sep 14, 2021 at 11:41 AM
    FO LO
    Lol if that
  7. Sep 14, 2021 at 11:56 AM
    JuicyJ
    JuicyJ New Member
    Nice, we just did Bulldog Canyon earlier this year, did you go all the way through it or turn around?
    Bikeric[QUOTED] likes this.
  8. Sep 14, 2021 at 12:18 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I did the whole 8.3 miles, but it took me longer than 54 minutes LOL. I entered from the North Gate and went South. I think that is the easier direction to travel. Had I entered from the opposite direction I would have turned around at the climb about 2 miles in from the South entrance. I started from the top and just rolled and banged down LOL. When I got to the bottom I looked back and was like F-That!! Route 10 if I remember correctly.
    FO LO[OP] and JuicyJ[QUOTED] like this.
  9. Sep 14, 2021 at 12:18 PM
    ArcticEd
    ArcticEd New Member
    Jacksonville
    '24 Plat Hybrid Crewmax 6.5 CSM
    We have lots of mud, and there are hunting trails/roads. Maybe not 100% required, but nice to have.
  10. Sep 14, 2021 at 12:26 PM
    JuicyJ
    JuicyJ New Member
    We entered the West entrance, and wheeled to the south assembly area with the sandy mini dunes. Our first time to do it, not sure if that's an easier route, but I found out real quick I needed to remove the mudflaps, and there was one gnarly section.
    I used to live in Apache Junction, oddly I didn't know bulldog canyon existed....
    Bikeric[QUOTED] and FO LO[OP] like this.
  11. Sep 14, 2021 at 2:01 PM
    FO LO
    Crawl control did pretty good around smith mtn lake but mostly just gets annoying and turned off
    Old logging roads and slick red mud. Not too rocky
  12. Sep 14, 2021 at 3:32 PM
    Half Assed
    Heartland Florida
    10 crewmax
    In the Tundra I don't use it that much, only when i need better slow speed control or the load on the truck is too much for high range. Most of the time I want wheelspeed on demand and high range works better for that.
    But other trucks I have wheeled needed low range. They were either manual transmissions or didnt have enough power in high range. Run a bigger, more aggressive tire on a truck with 100hp and it can't spin them without low range.
    You're not wheelin' hard enough my man. :D
    The only vehicle on that list that would be able to take advantage of a lower crawl ratio is the jeep wrangler. It's the only one in a factory or slightly modified configuration that could traverse actual crawling obstacles. Everything else isnt built for it IMO. Something that would be far more useful however would be a factory locking rear diff and/or a real limited slip option. It's almost a crime that Toyota doesn't offer one because a pickup truck can get stuck on wet grass in 2wd.
    FO LO[QUOTED][OP] likes this.
  13. Sep 14, 2021 at 3:51 PM
    FO LO
    Agreed. Wish they would delete crawl control and use the dollars for the front/back lockers Would probably be cheaper
    JuicyJ likes this.
  14. Sep 15, 2021 at 7:58 AM
    JuicyJ
    JuicyJ New Member
    The new Tacoma SR5 Trail Edition, with a lift, rear locker, skid plates and bronze TRD wheels is garnering excellent reviews, many of which specifically mention they'd rather have the locker and the trail control gizmos are totally not needed. Also, many prefer the cloth interior over the mandatory leather in a Pro.
    I would be giddy if Toyota makes a SR5 Trail Edition Tundra. I just want a locker with my mid-level truck.
  15. Sep 22, 2021 at 7:36 PM
    FO LO
    Tundra not made for rock crawling LOL yal hilarious cant wait to see the crawl ratios they put in that sucker
    Latest commercial from toyota
  16. Sep 22, 2021 at 8:00 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Just because you can do something doesn't mean you're good at it. A half ton truck is not a good rock crawler, all the dimensions are less than ideal.
    Now of course if you hit a patch of rocks on the nice trail run you won't be screwed since it has the same crawl control the Tacoma has, but heading specifically for rock crawling there's much better vehicles out there.
  17. Sep 22, 2021 at 8:08 PM
    Half Assed
    Heartland Florida
    10 crewmax
    You could drive up that in a Camry...
    JuicyJ and FO LO[OP] like this.
  18. Sep 22, 2021 at 8:16 PM
    FO LO
    Trd pro Camry with crawl control lol
  19. Sep 22, 2021 at 8:36 PM
    #49
    Half Assed
    Heartland Florida
    10 crewmax
    BMP, cowboyjack and FO LO[QUOTED][OP] like this.
  20. Sep 24, 2021 at 5:53 AM
    #50
    FO LO
    As I see it the turbo tundra is going to be king of the wind tunnel not mountain. Doubt she will stray from Toyotas other off roaders up to this point and will likely get highway gearing made for highspeed wheeling whatever that is and highway cruising. Gearing may even be lower on the pro to offset the extra power.
  21. Sep 24, 2021 at 6:24 AM
    #51
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    How it works. Guys in mid size trucks complain about full size trucks clogging the trails. Jeeps complain about mid size trucks. Razors complain about jeeps. Motos complain about razors. Guys on the trials bikes just climb over everyone.
  22. Sep 24, 2021 at 8:22 AM
    #52
    FO LO
    You forgot camrys :D
    Melikeymy beer likes this.
  23. Sep 24, 2021 at 8:39 AM
    #53
    JuicyJ
    JuicyJ New Member
    How many times I've tried to impress my wife with the off-road capabilities of my truck only to find a Camry or Prius at the destination :facepalm:
  24. Dec 31, 2022 at 2:02 PM
    #54
    FO LO
    Checking in to see if they ever put out what the overall gear ratio in 4lo 1st gear in the 3rd gen sr5 TRD4x4OR is??
