CoPart forklift driver cracked my transfer case cover
Discussion in '1st Gen Tundras (2000-2006)' started by Legionnaire, Mar 18, 2023.
  1. Mar 18, 2023 at 12:01 AM
    Legionnaire
    Legionnaire [OP] New Member
    Tucson, AZ
    2001 Jade Tundra AC 4x4 v8
    I bought a salvage 2001 Tundra AC 4x4 at auction, it looks great and will start a build thread soon.
    It arrived today and my driver told me some bad news... he was getting the car loaded and the CoPart people insisted on loading the car onto the trailer with a fork lift even though it drives. The fork lift driver hit the tiny transfer case skid plate/guard and it knocked a bolt up and put a big hole in the transfer case cover. I am very glad my auto transport guy took photos of it on their forklift, I will see what CoPart says...
    I was wondering if anyone had a spare 4x4 transfer case rear cover I could buy. I found it here, but it's $360. I also found entire eBay transfer cases for ~$400, but I just need the rear cover.
    Thanks for any help, excited to rebuild this car just wasn't expecting to fix this part on top of everything else :)
    M3Tundra-JK, JasonC. and w666 like this.
  2. Mar 18, 2023 at 5:24 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L “Best Cab”/AC Limited 53k mi
    Ain’t no negligence quite like gross negligence.
  3. Mar 18, 2023 at 5:27 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I would consider JB Welding that. It's a perfect application for such a repair. Looks like a clean break that will piece back together perfectly, and that mount point is not under stress unless the bash plate gets bashed. Even then, JB Weld is pretty strong stuff.
    I'd still get a payout from the CoParts though just as insurance in case there was any unseen damage. But honestly, it looks pretty straight forward.
  4. Mar 18, 2023 at 7:32 AM
    shifty` We call it “riding the gravy train”
    Don't have a part I can share, just wanted to say, welcome to the forum, and gl on your search. Hit this thread if you're bored and want/need a head start.
    1lowlife likes this.
  5. Mar 18, 2023 at 8:03 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    Also, OP congrats on finally sealing the deal on one, you can finally update your profile!
    Looking forward to seeing some pics of your pickup; mine also spent a significant amount of time in UT so I’ll be interested to compare frames. Mine has a date with a wire wheel and some Ospho in the near future but nothing bad.
  6. Mar 18, 2023 at 8:05 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    That was my first thought but I doubt he has that piece, so it’ll be a trickier patch job.
  7. Mar 18, 2023 at 8:11 AM
    tvpierce
    Maine
    The piece is in the first pic. Should still be attached the bash plate.
    Aerindel and JasonC.[QUOTED] like this.
  8. Mar 18, 2023 at 8:29 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I would think copart being a huge salvage company would have a cover or transfer case they could send you on their dime
  9. Mar 18, 2023 at 8:39 AM
    Legionnaire
    Tucson, AZ
    I actually do have this piece!! My first thought was JB weld but I thought most people would laugh at that solution. I will definitely try this since it fits like a jigsaw piece.
    woods likes this.
  10. Mar 18, 2023 at 9:12 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Welcome! Good luck!
  11. Mar 18, 2023 at 10:47 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Take the cover off and have it welded back together since you have the piece?
    joseph_womack and joonbug like this.
  12. Mar 18, 2023 at 11:54 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Before you try the JB Weld, you might want to consider something like this. The transfer case cover is aluminum after all. If you fail at the "Aluminum Welding", you can still come back with JB Weld, but if the JB Weld fails it may be impossible to try it.
    fuzzamungus likes this.
  13. Mar 18, 2023 at 12:18 PM
    tvpierce
    Maine
    When I was a teenager I had a summer job working at a marina. We had a 2 stroke Johnson 3 cylinder motor throw a rod and crack the crank case. We rebuilt the motor, and epoxied the case back together with JB Weld. Worked as a rental for years and never had a problem with it. For all I know it’s still running like that.
    If the point in question was supporting the TC then JBW would absolute not be an appropriate fix. But with this particular application, it is the ideal solution, IMHO.
    NewImprovedRon and w666 like this.
  14. Mar 18, 2023 at 1:34 PM
    Legionnaire
    Tucson, AZ
    Love it!! I sent it and put the high heat stuff on there. I could have taken the case off and welded but I wanted to try the easiest route first haha. Cleaned up good letting it harden will give an update.
  15. Mar 18, 2023 at 1:39 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    I wouldn't do that but good luck. Just my opinion.
  16. Mar 18, 2023 at 1:48 PM
    Aerindel
    Aerindel New Member
    Montana
    I would JB weld as well. I think it has a very good chance of working.
    Mr Badwrench likes this.
  17. Mar 18, 2023 at 2:42 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    It'll probably work fine if you got it clean.
    I'm guessing the oil already drained. o_O
    FrenchToasty likes this.
  18. Mar 18, 2023 at 3:01 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Did you use the putty or the paste?
    I do think it will work just fine, but I would still maybe look at junkyard for a spare case. That looks like a case skid that bolts onto that part
  19. Mar 18, 2023 at 3:28 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Damn....somebody left the door open :facepalm:
    shifty` and FrenchToasty like this.
  20. Mar 18, 2023 at 5:03 PM
    Legionnaire
    Tucson, AZ
    Yeah this is hopefully a relatively temporary fix. I cleaned it up with degreaser, then brake cleaner, then scuffed it with sandpaper and wiped it clean. I have the clamp holding the part on tight overnight with lots of the high heat putty on there. There was no oil near the job.
    Fingers crossed I just wanna be able to drive it to it's salvage inspection this week. Will definitely check the junk yard, not a lot of Tundras at Tucson pick-n-pulls it seems.
  21. Mar 18, 2023 at 5:10 PM
    FrenchToasty
    Mo
    Bone stock
    Your local!
  22. Mar 18, 2023 at 6:17 PM
    Legionnaire
    Tucson, AZ
    HEY! You live in Tucson?! That's awesome!
  23. Mar 18, 2023 at 6:19 PM
    FrenchToasty
    Mo
    Bone stock
    Look for the smoke signal in 3 minutes!!!
    if you want to do a trail after she’s trail worthy, let me know!
  24. Mar 18, 2023 at 6:20 PM
    Legionnaire
    Tucson, AZ
    Most definitely! Will do! Do you have a recommendation for place to get service done in town or an independent mechanic? I am going to do as much as I can alone here, but you never know.
  25. Mar 18, 2023 at 6:25 PM
    FrenchToasty
    Mo
    Bone stock
    Eh I hate using anyone but myself, some people like dans toy shop, some people like desert toyota, Lexus on speedway has a good tech named Colton. zona Motorsports for custom stuff.
  26. Mar 19, 2023 at 2:41 AM
    tvpierce
    Maine
    You JB Weld like I stick weld: The bigger the gob, the better the job! :rofl:
    woods, AZBoatHauler and shifty` like this.
  27. Mar 19, 2023 at 6:56 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Had I screwed this up, I would have attempted JB Weld. Since someone else broke this, I would have waited for a new transfer case or a check for the damages.
    landphil likes this.
  28. Mar 19, 2023 at 10:37 AM
    Legionnaire
    Tucson, AZ
    Yeah I got all my evidence and photos of it being their fault, but CoPart is in Utah and I'm in Arizona, so it's not like someone is going to come out and check it. Also as positive as I am I feel like CoPart isn't going to give a crap-o-la. Also I don't have insurance cause it's a salvage truck I just bought at auction.
    Aerindel and FirstGenVol[QUOTED] like this.
  29. Mar 19, 2023 at 10:43 AM
    Legionnaire
    Tucson, AZ
    One dumb question! I'm gonna fill her up and see what happened today since it's been 24 hours. My transmission fluid level is unphased by this big hole right?
  30. Mar 19, 2023 at 10:45 AM
    FrenchToasty
    Mo
    Bone stock
    Correct
    Aerindel and Mr Badwrench like this.
