Cooper AT3 XLT
Discussion in 'Wheels & Tires' started by CaptTyler, Jul 25, 2018.
  1. Apr 30, 2020 at 1:32 PM
    #481
    Redcon41318
    Redcon41318 New Member
    I just exchanged my set thru americas tire, bummed they didnt perform well on my stock tundra. I bought an oe size goodyear ATs with kevlar.
    tire manager said theyve have nothing but complaints on e rated tires on tundras.
  2. Apr 30, 2020 at 1:42 PM
    #482
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    That's weird. A tire will not make the truck pull (unless you have a significantly different size or weight tire on one side which you did not have). Also, there are lots of guys here running those tires and nobody had the same or even similar complaints.
  3. Apr 30, 2020 at 1:47 PM
    #483
    Redcon41318
    Probably tire defect, i ran 265/70/18 e rated, had it rebalanced twice. Still shaky, unstable, un safe feel on the tires.
    I ran it at door sticker suggest psi, 36, 38 and 40 psi all same. I had enough went with stock oe size and went with goodyears. Not hating on coopers, just my luck.
  4. Apr 30, 2020 at 3:48 PM
    #484
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    Do they do road force balancing? My previous ko2s and new AT3 XLTs were both super smooth being balanced that way.
  5. Apr 30, 2020 at 5:18 PM
    #485
    Redcon41318
    Not even sure, i had it with that issue. I have a low tolerance when it comes to dealing with bull chit. I cant tolerate tinkering, thus why my tundra stays stock and my mods go to my 96 tacoma.
    the coopers were a good looking and im sure if it wasn’t defective itll perform fine. But goodyears it is for
    Now.
    Clemsonman14 likes this.
  6. May 2, 2020 at 3:58 PM
    #486
    havasuTRD
    havasuTRD New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    Got my at3XLT’s on today. Looking forward to see how they perform. Sure are quiet
    Trooper2 likes this.
  7. May 3, 2020 at 2:46 PM
    #487
    slip sinker
    slip sinker New Member
    2018 Silver DC 4WD
    Do these tires have two or three plies in the sidewall?
  8. May 3, 2020 at 2:57 PM
    #488
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Sounds more like a wheel issue.
    I bought a set of Anthem wheels and could NEVER get rid of the steering wheel shimmy after 7 balances, 4 of them road force.
    I kept the documentation from all attempts and contacted Anthem.
    They sent me 2 more wheels for the 2 worse balancing wheels.
    Same issue.
    Put the stock wheels back on, shimmy gone.
    I'm very lucky Anthem let me return the wheels for a full refund, although I did spend over $600 on all the balances.
  9. May 3, 2020 at 5:05 PM
    #489
    Redcon41318
    Side wall 2ply.
  10. May 3, 2020 at 8:56 PM
    #490
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    I just put the aftermarket wheels on maybe 500 miles ago. All of my experiences with the tires were on factory TRD OR wheels. I had them rebalanced and they are doing better but we are getting into warmer weather now so the flat spotting only lasts a couple minutes and they are warmed up. My mechanic looked over the wheels and they are running true. I think the majority is that they were on 8" wide wheels for almost 10k miles and now they are on 9" wide wheels. They are wearing in different areas now. They are getting fairly loud now too. I'll hopefully see for sure if a tire problem, I'm upgrading size once I get my BMC done.
    1lowlife[QUOTED] likes this.
  11. May 3, 2020 at 9:29 PM
    #491
    1lowlife
    DADA
    2014 MGM DC SR5
    Thank you for the update.
    I plan on buying these tires when my KO2s wear out.
    Those Anthem wheels I bought were the same size as my stock wheels, 20X9, but had a +18 offset as opposed to the stock +55.
    I don't know why I couldn't get them to balance.
    I was lucky they gave me a refund.
    Here are some pics at the attempts to balance..
    ColoradoTJ and Bravohook[QUOTED] like this.
  12. May 3, 2020 at 9:31 PM
    #492
    Bravohook
    Addame
    NY
    2007 RCSB
    Cool Things
    Dang!!! That a lot of weight, but BFG A/Ts are notorious for not balancing well. My work when I was in AZ ran those on the work rigs and they wouldnt balance out very good , course we were hard as hell on them too
    equin and 1lowlife[QUOTED] like this.
  13. May 5, 2020 at 8:08 AM
    #493
    Outbound
    Aaron
    Northern Alberta
    Got an email back from Cooper. There are no plans to offer the AT3 XLT in 265/70/R17. Apparently the AT3 LT is their equivalent in the smaller size.
  14. May 5, 2020 at 3:21 PM
    #494
    Holy hell. With all that weight on the wheels you probably dropped 2 mpg. :rofl:
    Glad they took those wheels back.
  15. May 5, 2020 at 3:32 PM
    #495
    I have around 10k miles on these tires now. So far, been very impressed with the ride and low road noise.
    So far I have done two balances and one rotation.
    My rear tires are down to 12/32” from 17/32.
    Front tires are down to 14-15/32”.
    From these measurements, I highly doubt 60k miles will be reached. Been towing pretty heavy lately, so not real surprised.
    Trooper2 and 1lowlife like this.
  16. May 5, 2020 at 5:48 PM
    #496
    Zero One Actual
    So if 60k doesn’t get reached then they still fall under Cooper 60k warranty correct?
  17. May 5, 2020 at 6:27 PM
    #497
    Yep. It usually isn’t much even if they only make it to 40k miles (I’ll be happy if they do). Personally, I would rather have a tire that works great for 90% of my needs and has a shorter life vs the other way around.
    1lowlife, Boerseun and saybng like this.
  18. May 5, 2020 at 7:40 PM
    #498
    JEFFTHEROBOT
    JEFFTHEROBOT New Member
    Jeff
    Lakewood, CO
    2017 Crewmax Barcelona Red
    TRD Pro grill & bulge Method 305NV 18x9 (x5) Eibach PRO LIFT SYSTEM (Stage 1) ICON 1.5″ REAR ADD A LEAF UpTop Overland mid-height truss Area BFE Black series Aluminum hard shell rooftop tent (Large) TRD Pro Shift knob Total Chaos bed stiffeners AJT blackout interior OEM blackout badge overlays Diode dynamics SS3 fog lights Diode dynamics 42" stealth light bar Rigd mega ultraswing spare tire carrier Compustar Pro R3 remote start EBC brakes & rotors
    @ColoradoTJ those tires performed well for you during winter this year? I ski a lot and looking for something that does great During those months too. Thanks in advance.
    ColoradoTJ likes this.
  19. May 5, 2020 at 7:48 PM
    #499
    I was rather impressed with these tires.
    4wd was rarely used in the storms and ice.
    JEFFTHEROBOT[QUOTED] likes this.
  20. May 5, 2020 at 7:56 PM
    #500
    JEFFTHEROBOT
    Jeff
    Lakewood, CO
    Awesome. Thank you.
  21. May 9, 2020 at 2:35 PM
    #501
    degs
    degs New Member
    2020 MGM Crewmax
    just got mine installed yesterday
  22. May 9, 2020 at 4:10 PM
    #502
    Stig
    Stig New Member
    Got mine a few days ago as well, replaced the stock Michelins. Slight steering wheel wobble so I'll probably try to rebalance.
    First time driving on E rated tires. The steering response is more noticable than I expected (good thing).
    Ride doesn't seem any harsher but I'm noticing I can feel some of the smaller pot holes and broken pavement a little more. The old tires were squishy and kind of floated over everything.
    Haven't noticed any loss in power up to 60mph but need to see how it does at 80 on the rolling highway.
    All in all glad I went this route so far. I was debating because of all the comments about harsh ride and power loss. Don't care about mpg.
    ColoradoTJ and Trooper2 like this.
  23. May 9, 2020 at 4:29 PM
    #503
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    What size did you go with? 295/70r18? Pics?
  24. May 9, 2020 at 4:31 PM
    #504
    Stig
    Stig New Member
    Yep. Pics soon.
    dpast88[QUOTED] likes this.
  25. May 9, 2020 at 4:39 PM
    #505
    Redcon41318
    Stig,
    i felt a power loss going e rated and a larger than oem tire. Tell me if your rebalance works well, i had to return my tires.
  26. May 9, 2020 at 4:46 PM
    #506
    Stig
    Stig New Member
    Will report back on rebalance.
    I'm sure I'll see the power loss on the highway, just didn't notice it on back roads. I already thought 6th gear was weak on the highway. Plan is to regear and install a blower at some point.
  27. May 10, 2020 at 5:11 PM
    #507
    Stig
    Stig New Member
    Did some highway driving. There were only a few inclines where I noticed the power decrease. Otherwise I couldn't tell.
    I didn't notice them being any louder until I drove over an hour and found my ears ringing. That's probably the biggest negative so far. I read these tires were quiet compared to some others but they are definitely louder than the stock squishies
  28. May 10, 2020 at 5:16 PM
    #508
    Redcon41318
    Yes, definitely louder than oem. Other members were blowing smoke saying they were quiter or just as quiet.
    I wouldnt recommend E rated
    Unless you tow frequently and long distances.
  29. May 10, 2020 at 6:48 PM
    #509
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Wouldn't call them quieter than OEM, butt they're quieter than the Terra grapplers I had before. These are larger than the Nittos too.
  30. May 12, 2020 at 5:57 PM
    #510
    Stig
    Stig New Member
    What do you guys tolerate for wheel balance? Or what is a reasonable goal?
    I have a decent steering wheel wobble between 50 and 60. Everywhere else it's so slight I don't mind. Planning to take them back for a reblalnce but just wondering what my expectations should be. Zero wheel shake would be nice.
