Cooper AT3 XLT
Discussion in 'Wheels & Tires' started by CaptTyler, Jul 25, 2018.
  1. Feb 25, 2020 at 7:00 PM
    #451
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Running 37 psi on all fours. Good results from the chalk test too.
    AZTundra[QUOTED] likes this.
  2. Feb 25, 2020 at 7:10 PM
    #452
    AZTundra
    Paul
    Phoenix, AZ
    Thanks. I got mine installed on Friday, not sure what psi they set them to and I haven't had a chance to check, but feels like it might be a little on the high side. This gives me a place to start.
  3. Feb 26, 2020 at 6:47 PM
    #453
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    I emailed Cooper tire support regarding tire pressure and ask them what is the recommended pressure to run the AT3 XLT. This is their response:
    “Thank you for your email. Always follow the air pressure recommendation of the vehicle manufacturer as listed on the placard on the door of your vehicle. Proper air pressure is based on the weight of your vehicle and is determined by the vehicle manufacturer and not the brand or type of tire you have. Even if you’ve changed tire sizes or rim diameters you would still utilize the door placard recommended pressure settings. Also, never exceed the max air pressure as listed on the sidewall of the tire. For your Tundra, you would run the tires at 33 psi both front and rear.
    If you have questions regarding this or need more information please contact your vehicle manufacturer. There are several sites you can refer to as well regarding tire pressure safety.
    www.ustires.org
    www.nhtsa.gov
    www.safercar.gov
    Have a Great Day!!!
    Eric
    Consumer Relations Specialist
    Cooper Tire and Rubber Company
  4. Feb 26, 2020 at 7:48 PM
    #454
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Wow, 33psi seems pretty low....
  5. Feb 26, 2020 at 8:11 PM
    #455
    AZTundra
    Paul
    Phoenix, AZ
    I checked mine this morning and Discount Tire had them set at 40psi front and rear.
  6. Feb 26, 2020 at 8:56 PM
    #456
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Yeah, the receipt from Discount said to have the front at 40 and rear at 45. They inflated to 40 all around.
    AZTundra likes this.
  7. Feb 26, 2020 at 9:06 PM
    #457
    Tires still impress me when I actually need them.
    Yesterday
    2wd. I actually turned around due to visibility was almost non existent. The second video I was going 10-12 mph.
    If there could be one gripe with the tires, is they do pick up rather large rocks and either huck them or stay in the tread. Living off a dirt road or driveway might get annoying. I pick out the rocks every so often now. 4500 miles on tires.
  8. Feb 28, 2020 at 4:32 AM
    #458
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    Installed these before my yearly ski trip to Snowshoe, WV and glad I did. When we got there, no new snow anywhere. The night before we left, we got around 6-7” of fresh powder on top of 1/4” of ice. Coming down the mountain Thursday was easy and I never felt like the truck was going to slide. I am so glad I went with these instead of the other options I considered. 490032D5-341B-45E0-B51E-6E910744B6E7.jpg
    Trooper2 likes this.
  9. Feb 28, 2020 at 12:42 PM
    #459
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    That does not jive what what I have seen based on other posts where when people check with the tire manufacturer for pressure on new LT tires- moving from P to an LT.
    Boerseun likes this.
  10. Feb 28, 2020 at 12:49 PM
    #460
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    That's the lawyers takin...
  11. Mar 4, 2020 at 4:26 AM
    #461
    The_Bob88
    The_Bob88 New Member
    08 Tundra Crewmax
    Still no complaints yet with these tires
  12. Mar 4, 2020 at 6:11 AM
    #462
    frichco228
    I am so ready to get mine...but the tires on it now still have some life.
    Liking the white letters out!
    The_Bob88[QUOTED] likes this.
  13. Mar 5, 2020 at 8:22 PM
    #463
    Wldkatz03
    Wldkatz03 New Member
    Michael
    2019 Toyota Tundra 1794 Edition 4x4
    What size? I have the same wheels and just installed TRD pro suspension! Wondering what I can fit! Looks awesome
  14. Mar 5, 2020 at 9:16 PM
    #464
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    275/55/20 - stuck with stock size, as I have not lifted.
    Will go bigger on next set of tires as I will lift at that time
  15. Mar 6, 2020 at 1:28 AM
    #465
    Finch
    Finch New Member
    Donnie
    '16 Inferno CM 5.7L TRD Off-Road
    Funny, I received that same email the day you posted this. I have the 275/70/18 AT3 XLTs and he recommended I do 30 front and 33psi rear. I'm at 40psi all the way around but plan on doing another chalk test.
  16. Mar 6, 2020 at 2:56 AM
    #466
    Zero One Actual
    285/75R18 at 40psi. Super quiet. Rides like the stock tires on my 2019 crew max.
  17. Mar 6, 2020 at 9:33 AM
    #467
    frichco228
    They are just quoting the door sticker. I know for a fact that is not correct when moving from a p to and E (or any LT) tire. Chalk test and vehicle handling on past jeeps and trucks I have owned proved it.
    Chalk test takes 15 minutes. If wear looks ok, then drive it a few days around town and at speed and see how things feel.
    I have seen MANY posts regarding air pressure here and on other sites, where people have contacted a tire manufacturer about air pressure on the vehicle and the answers are all over the place.
    Just search here....you will see posts from folks with similar trucks (same class and size of tire) get many different recommendations back from tire manufactures.
  18. Apr 11, 2020 at 10:24 PM
    #468
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Update:
    Have had these tires for almost 10,000 miles. Wearing ok, definitely louder then when they were new. I left them on all winter this year instead of switching to my usual snow tires. They did ok not great. All winter they would flat spot if I let it sit for over a day.
    I had them mounted to my new wheels a couple weeks ago. Now they won't hold a balance. Have a constant shimmy and shake, currently running 40 psi at all 4 corners. This was after experimenting with different psi, 40 seems the best for the truck. At 33 front and 30 rear truck felt very squishy and unstable at speed in turns. I'm starting to wonder if the 9" wheel is affecting the tires characteristics. I have tried 3 different sets of lug nuts just to make sure the wheels are seated correctly and no change.
    Re balanced twice and small incremental changes. With the 9" wide wheel they also take more weight to balance then the factory 8" wheel. I'm currently looking for a tire shop around me that does road force balancing and see if that helps. I have been wanting to up size so I may do that sooner then later, just stinks b/c there is a lot of tread life left on these. But the dealer included them in the deal when I bought so technically not losing money on them. Others have had great luck with the . I'm starting to wonder if I got a bad set or bad tire in my mix. Also my White Letter are different then what Cooper and others have posted. Mine are like the regular AT3's.
  19. Apr 11, 2020 at 11:37 PM
    #469
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    38
  20. Apr 17, 2020 at 3:20 PM
    #470
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    Just had these installed in 275/70/18 and they look and ride great. I have 9” wheels and my shop does road force balancing. Ride home was about 17 miles and was very smooth.
    Zero One Actual likes this.
  21. Apr 24, 2020 at 2:13 PM
    #471
    havasuTRD
    havasuTRD New Member
    Brett
    2017 Tundra crewmax TRD 4X4
    What prices are you guys getting for these suckers? I’m in the 275/60/20 market and the best Price I’ve got is $1255 with road hazard certs. Sound ok or high?
  22. Apr 29, 2020 at 10:43 PM
    #472
    Redcon41318
    Redcon41318 New Member
    I got these on my stock tundra, 265/70/18, my truck is not driving straight, im getting a slight pull to the left? What you guys think? I have about 250 miles on them,
    If they still do this im taking them
    Back.
  23. Apr 29, 2020 at 10:47 PM
    #473
    Outbound
    Aaron
    Northern Alberta
    I'm kinda mad they don't make these in 265/70/R17...
  24. Apr 30, 2020 at 3:58 AM
    #474
    Zero One Actual
    That’s an issue for the person who did your balance and alignment. They didn’t get the numbers right.
    havasuTRD likes this.
  25. Apr 30, 2020 at 6:22 AM
    #475
    Redcon41318
    Its gona be the 2nd time going back “to make it right,” i have never had this happen before with tires and im starting to feel its a defective tire. This tire shop is americas tire and they are usually competent! Which makes me believe its defective.
  26. Apr 30, 2020 at 7:02 AM
    #476
    frichco228
    balance probably will not cause a pull....would cause wobble or shimmy. When was the last time the truck had a front end alignment?
    Have them move the front tires to the rear. If it is still pulling then you know it is something else.
  27. Apr 30, 2020 at 7:23 AM
    #477
    Redcon41318
    Trucks brand new, all stock drove straight and solid before tires.
  28. Apr 30, 2020 at 8:38 AM
    #478
    Zero One Actual
  29. Apr 30, 2020 at 1:07 PM
    #479
    degs
    degs New Member
    2020 MGM Crewmax
    following. I just purchased a set
  30. Apr 30, 2020 at 1:14 PM
    #480
    Stonehide
    Stonehide New Member
    2020 Cement DC Limited 4x4
    Same. Just placed my order for a set of 285/75r18.
