Cooper AT3 XLT
Discussion in 'Wheels & Tires' started by CaptTyler, Jul 25, 2018.
  1. Jan 31, 2020 at 11:23 AM
    #421
    Trooper2
    JR
    Houston, TX (Suburban South)
    Not sure about the tire size. Thinking you'll be OK.
    TRD wheels will need new lugs, maybe take-offs will come with some; @Roman can quote you. Thinking new TPMS sensors may be needed, steelies may have different style than alloy. @Roman can verify.
  2. Jan 31, 2020 at 11:24 AM
    #422
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    I believe you should be fine with 275/70/18 and you don’t need new lugs for OEM TRD alloy wheels since I’ve done that with my friend truck. Although you would need new tpms since the tpms on the steel wheels has different angle.
  3. Feb 5, 2020 at 4:17 PM
    #423
    AZTundra
    Paul
    Phoenix, AZ
    Just secured my quote for Cooper AT3 XLT's in 295/70/18. Discount Tire saved my quote in their system and the store mgr gave me a discount, but I can't get them on until later this month. I need to install my shims and +3 shackles from Coachbuilder first to get another 1" of clearance to fit them. Looking forward to these! Still rolling on the factory tires right now with just over 55K on them.
    vhstejskal, Boerseun and SprinterAE86 like this.
  4. Feb 6, 2020 at 6:47 AM
    #424
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    I finally got a couple days of snow storms to test out these tires. I have to admit the Coopers were my second choice as I really wanted the additional comfort from the WildPeak tires (mainly because they were three peak snow flake rated). Several retailers did not have the size I wanted to run so I went with the AT3’s.
    Light Snow (Ice Underneath) they handle just like any other tire I’ve owned with the exception of studded tires, but that’s (apples vs. oranges). The AT3s tracked well on unplowed roads and I felt confident in keeping in my lane and being able to stop. Even when I started to drift it was easy to get the truck back under control.
    Moderate to Heavy Snow (unsure about Ice) This is where I was completely blowed away with how well they handled. Changing lanes across 6+ inches of slush and snow and I wasn’t afraid I would be spin out. Traction was good along with confidence in stopping.
    This is just my interpretation but I would buy these tires again. While I’m sure the WildPeaks perform just as well with the added snow rating and unable to compare the Coopers are a capable All Terrain tire.
    TOYOTRD8 and ColoradoTJ like this.
  5. Feb 6, 2020 at 8:45 AM
    #425
    eltundra
    eltundra New Member
    Got my XLT's on yesterday with TRD Off Roads from America's Tire. 275/70/18 with stock suspension and no rubbing issues so far (made a few u-turns as well). So far i am impressed with how quiet they are, and love the look. The size i got do have the three peak snow flake rating, which will be nice on my snowboarding trips.
    I had a little bit of an issue with the tpms sensors from the TRD wheels. They were take offs from a 2020, and when they tried to program them, they weren't reading at the same frequency to my 2017 Tundra (according to the AT guys). The sensors from the stock steel wheels didn't work either due to the angle.
  6. Feb 6, 2020 at 9:38 AM
    #426
    Damn good looking truck! One of my favorite colors. Slowest color, but definitely a head turner...:rofl:
  7. Feb 6, 2020 at 9:40 AM
    #427
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    :duel:
    WFD473 and ColoradoTJ[QUOTED] like this.
  8. Feb 12, 2020 at 10:55 AM
    #428
    gupster88
    gupster88 New Member
    Brett
    Charleston, WV
    2019 Toyota Tundra SR5 TRD Off-Road
    Well I thought I was dead set on the Nitto Ridge Grapplers until I ran across this thread :monocle:
    Trooper2, vhstejskal and Boerseun like this.
  9. Feb 12, 2020 at 12:57 PM
    #429
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I am about to pull the trigger on these XLT's myself.
    My truck came with the Vision +18 20's and 285/55/20's and they look small on my truck. In this pic, I had not done the 5100's yet.
    I have the 5100's on top setting and have plenty of clearance. Looking at my truck, do you think I can squeeze a 305/55?
    According to my measurements, I have about 1.6" clearance front and back of the tire before touching the inner fender. Mudflaps are gone.
    Trooper2, Black Wolf and SprinterAE86 like this.
  10. Feb 14, 2020 at 12:09 PM
    #430
    wanderinghome
    wanderinghome New Member
    Bill
    Forest Hill, MD
    2017 Silver Crewmax Limited TRD Off-Road
    TRD: Pro Suspension, Dual Exhaust, Sway Bar, Pro Grille, Coachbuilder: 3" Shackles, 1/2" Shim, Carrier Bearing, Spidertrax 1.25" AMP-Research step, Nitto RG's 285/70/18
    I have 285/70/18 Nitto Ridge Grapplers with 35k miles, and am not enjoying what has been happening. Tread life would suggest I have 10k - 15k miles of life left, but as miles have piled up they have become loud, and rough, they are chipping and cupping. I am diligent with maintaining air pressure and rotating, these tires are not what I was hoping for. Most critical is the worsening traction on any wet road conditions. I am looking to replace them very soon. Thinking AT3 XLT's, want to learn more about Yokohama's also.
  11. Feb 14, 2020 at 1:37 PM
    #431
    Zero One Actual
    Cooper has 60,000 warranty also.
    Trooper2 and equin like this.
  12. Feb 17, 2020 at 6:03 AM
    #432
    gupster88
    Brett
    Charleston, WV
    I think I have decided... 275/70-18 Cooper AT3 XLTs will be my tire of choice. Just going to wait on some deals from DTD to get em!
    Zero One Actual and Boerseun like this.
  13. Feb 17, 2020 at 7:24 AM
    #433
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    I finally got mine on! 295/70/18. I like them so far. 6CB44B12-7061-4303-A783-8E7BEBED101C.jpg
  14. Feb 17, 2020 at 7:27 AM
    #434
    AZTundra
    Paul
    Phoenix, AZ
    What size lift/level are you running? What trimming was needed to fit if any? Mine will be going on Friday same size (295/70/18) and also on stock rims. Just curious what needed to be done to fit them. Thanks!
    dbrown and Jeffroski like this.
  15. Feb 17, 2020 at 9:23 AM
    #435
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    I have 2.4 inches in the front from spacer/co's and 1.25 in the rear from shackles. I had someone trim for me before tires went on. Both mud flaps are gone in the front and some trimming on the inner fender liner. Not sure if all that was needed but I have no rubbing at all and tires cleared the upper control arms and rear Bielstein shocks and reservoir hose. I have heard that all you really need to take off is the front mudflap. Start there and see what else needs trimming.
    AZTundra likes this.
  16. Feb 17, 2020 at 9:35 AM
    #436
    AZTundra
    Paul
    Phoenix, AZ
    Perfect, thanks for the response. I'll be at +3.5" in the front and about +1.75" in the rear. I'll remove the front mud flaps before I take it in to Discount Tire. You're not running any wheel spacers are you?
  17. Feb 17, 2020 at 9:41 AM
    #437
    wanderinghome
    Bill
    Forest Hill, MD
    CoachBuilder makes a front bumper shim kit, moves front bumper 1/4" to 1/2" Forward
    AZTundra[QUOTED] likes this.
  18. Feb 17, 2020 at 9:47 AM
    #438
    AZTundra
    Paul
    Phoenix, AZ
    Yeah, I've see that. I'm hoping I'll get by with what I've got. Will definitely post up some pics on Friday.
  19. Feb 17, 2020 at 1:46 PM
    #439
    dblizzo
    dblizzo New Member
    Dennis
    16 Tundra
    I do not have wheel spacers
  20. Feb 19, 2020 at 9:38 PM
    #440
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Ordered 275/55/20 AT3 XLT and install on Friday.
    I read alot about these tires, but after seeing this post, it reaffirms my decision. Cant wait!!
  21. Feb 20, 2020 at 6:50 AM
    #441
    AZTundra
    Paul
    Phoenix, AZ
    Same here, Friday is the day. 295/70/18.
  22. Feb 20, 2020 at 7:48 AM
    #442
    Zero One Actual
    You will both be very happy with them. The weight, the warranty, the sound and the smoothness is awesome compared to a lot of other tires out there.
    I’m guessing with those sizes your PSI should start at 40. Then work down from there.
  23. Feb 20, 2020 at 8:14 AM
    #443
    AZTundra
    Paul
    Phoenix, AZ
    Sounds good! Thanks for the info.
  24. Feb 20, 2020 at 1:19 PM
    #444
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Thanks for the info!
  25. Feb 20, 2020 at 4:42 PM
    #445
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Ordered mine. Going on Saturday
    285/60/20’s
    Pics to follow Saturday afternoon
    Trooper2 likes this.
  26. Feb 21, 2020 at 1:40 PM
    #446
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    C49D6E97-9296-4D9C-B93C-AE032D6B3247.jpg Just got back from the tire store. So far, I’m loving them. 285/60/20’s
    14EDFF8D-95E4-4440-9207-6B24CF91D08A.jpg 6941C0DA-B59F-4C25-A5B5-2FF7377CE41B.jpg 86C15F4D-5CF7-470A-9425-D82B672A0583.jpg
  27. Feb 21, 2020 at 4:32 PM
    #447
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    got mine today and love them!
  28. Feb 21, 2020 at 5:09 PM
    #448
    AZTundra
    Paul
    Phoenix, AZ
    Got mine today as well. 295/70/18.
    dbrown, dpast88, Trooper2 and 7 others like this.
  29. Feb 23, 2020 at 5:44 PM
    #449
    CincYOTA
    CincYOTA New Number
    2012 Tundra SR5 DC 5.7 4x4
    This thread helped me make the decision to get the Coopers. I got 275/70/18s on the new TRD Pro wheels. They are extremely quiet. Added Bilstein 5100s all around with fronts on middle setting.
  30. Feb 25, 2020 at 6:57 PM
    #450
    AZTundra
    Paul
    Phoenix, AZ
    For those with 295/70/18 what psi are you running?
