Conversion from center console to center seat
Discussion in '2.5 Gen Tundras (2014-2021)' started by Snoozer, Jan 22, 2018.
  1. Mar 24, 2020 at 2:20 PM
    #61
    Hatric
    Hatric New Member
    2015 Gray Tundra SR5 4X4
    They're definitely not the same plugs. Wires don't even match up. I have a column shift assembly and it's a single plug I think I posted a pic earlier in the thread.
  2. Mar 24, 2020 at 2:27 PM
    #62
    14srAKH
    14srAKH New Member
    2014 tundra sr white
    Wheels, center console swap, tinted windows,
    Crap!
    I didn't see your pics in the thread of the column shifter.
    Either way I'm in it deep now.
    I have the console and the shifter assembly.
    Once it comes in I'll do some searching inside the dash and under the carpet.:pray:
  3. Mar 24, 2020 at 2:36 PM
    #63
    Hatric
    Hatric New Member
    Did you pull a piece of plastic and expose the ECU while installing the console? I expect the cables will be shoved in there.
  4. Mar 24, 2020 at 2:43 PM
    #64
    14srAKH
    14srAKH New Member
    I did. I just was so excited to install the console I didn't even look. Lol
    But as soon as the shifter assembly comes and I have a minute I will search in Hope's everything I need is there.
  5. Mar 24, 2020 at 2:50 PM
    #65
    Hatric
    Hatric New Member
    Good luck.. Wait also did you get the actual shifter cable? They don't stock it at LKQ it attaches to the assembly goes out the floor of the truck and attaches to the transmission.
  6. Mar 24, 2020 at 2:57 PM
    #66
    14srAKH
    14srAKH New Member
    No I was hoping I could just reroute the one for the column shifter.
    I think I will need the little piece that holds the cable in place to keep it from moving the entire thing and just move the cable.
  7. Mar 24, 2020 at 2:59 PM
    #67
    14srAKH
    14srAKH New Member
    The column shifter cable has to go through the same hole as the cab is the same between the two options.
  8. Mar 24, 2020 at 3:02 PM
    #68
    Hatric
    Hatric New Member
    Oh nice! Can you post pictures of how yours is routed? That's kind of where I stalled on my swap. That and I need to tear my Dash out to see if the cables I need are stored in there anywhere.
  9. Mar 24, 2020 at 3:06 PM
    #69
    14srAKH
    14srAKH New Member
    Yes absolutely.
    I had originally planned on taking a lot of pictures and writing up a how to.
    But I'm like a little kid when it comes to new parts and I just install them as soon as I get them. Haha
  10. Mar 24, 2020 at 4:08 PM
    #70
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Interested! Look forward to hearing -- please post up pictures if possible
    14srAKH[QUOTED] likes this.
  11. Mar 25, 2020 at 5:39 AM
    #71
    14srAKH
    14srAKH New Member
    So this morning I took a couple minutes to remove the top portion of the console and I cut a little bit of the carpet and saw that the bolt holes for the shifter assembly are there.
    Couldn't see any harnesses but I need to remove the front portion of the console to see up under the dash.
  12. Mar 25, 2020 at 8:01 AM
    #72
    ezdog
    ezdog New Member
    Gateway To The West
    So I just went the other way with my 2015 and yanked the "Seat" and built a console.
    Just putting this here so that similat pics are together in case it helps anyone else.
    4DDA4178-2B23-494F-B225-28214EBEDAC0.jpg 23B06E2F-5656-4336-9CFD-901A654B781E.jpg 214C3C41-986F-4EBE-9A97-D5CEFA3ECB63.jpg
    Seafury, 14srAKH and YsoSeRiouS! like this.
  13. Mar 27, 2020 at 8:35 AM
    #73
    14srAKH
    14srAKH New Member
    Okay so did a little poking around and found a part number on a harness that I believe goes to the column shifter.
    Haven't tried searching on line yet but will after I post it up here.
    AB141-OC340-R1
  14. Mar 28, 2020 at 1:08 PM
    #74
    RPKEAN
    RPKEAN New Member
    Ryan
    Subbing to this as I’m curious how to swap the other way...console to column shifter....
  15. Mar 28, 2020 at 1:15 PM
    #75
    RPKEAN
    RPKEAN New Member
    Ryan
    Also question for those with the column shifter...
    Do you have steering wheel tilt and telescope and if so, is it powered?
    I would imagine the column shifter needs a new plastic collar for the steering column and I’m curious if there’s a hole for the tilt and telescoping column.
  16. Mar 28, 2020 at 2:04 PM
    #76
    14srAKH
    14srAKH New Member
    I have a base model and I have tilt but no telescoping.
    I took out the center console today to dig under the carpet and behind the dash.
    No luck at all.
    No plugs.
    And I rerouted the cable to come from the proper spot to connect to the console shifter and there is a rod that is too short. The rod connects the shifter cable to the shifter and a bracket on the shifter but the shifter was in reverse and the truck was in park.
    So a cable is definitely needed.
    And I would assume there is an entirely separate harness to go from the ecu/tcu to the shifter and the transmission.
    I need to find a junk tundra. ASAP
  17. Jun 19, 2020 at 11:02 PM
    #77
    Gdry06
    Gdry06 New Member
    15" on 40s and charged
    Any updates on this? I'm in the process on doing the swap but will be keeping the shifter on the floor. Simple and easy currently got the seat bolting down.. next step is make a bracket to move shifter over 2inches and build a console to cover shifter and add cup holders.
  18. Jun 21, 2020 at 1:09 PM
    #78
    BlueYourMyBoy
    BlueYourMyBoy New Member
    2016 TRD Off-Road
    Got any pictures of your set up? Wanna do the same thing without going column shifter
  19. Jun 21, 2020 at 4:47 PM
    #79
    ekinnee
    ekinnee New Member
    North Central Texas
    2020 Tundra Quicksand SR5 TSS
  20. Jun 21, 2020 at 7:41 PM
    #80
    YeeYeeTundra
    Ohio
    .... I miss my front bench column shifter in all honesty.
  21. Jun 22, 2020 at 10:27 PM
    #81
    Gdry06
    Gdry06 New Member
    Sorry I haven't made much progress.. seat is useable but that's it.. I still need to get material to finish up the shifter/ console
  22. Jun 23, 2020 at 5:14 PM
    #82
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I ve always wanted to stick a sub in the center console. I would seal it up, and point it to the back. That solves location problem, and not limited to shallow sub.
  23. Jun 23, 2020 at 8:53 PM
    #83
    Gdry06
    Gdry06 New Member
    Little update.. all bolted down.. just need to made a few covers to clean up the look. Last top pictures are what I need to cover up.
  24. Jun 24, 2020 at 4:37 AM
    #84
    BlueYourMyBoy
    2016 TRD Off-Road
    Nice! Thanks for the update. Any ideas to how your gonna move the shifter?
  25. Jun 24, 2020 at 10:33 AM
    #85
    Gdry06
    Gdry06 New Member
    It's already been moved. Just needed to push it forward and centered as I'm keeping it on the floor for a easy swap back if I ever wanted to.
  26. Jun 24, 2020 at 11:23 AM
    #86
    Redcon41318
    Redcon41318 New Member
    The benefit is the center passenger has
    Something to hold onto.
  27. Jun 30, 2020 at 9:01 AM
    #87
    Kyler703
    Kyler703 New Member
    14 limited crewmax
    I think I’m going to do the same as you! It would be nice to fit my family of 6 in my truck instead of always having to take my wife’s van places. May I ask where you found your center seat?
    Terndrerrr likes this.
  28. Jul 1, 2020 at 8:46 AM
    #88
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I wish the Tundra had the option of the column shifter w/ 6 seats in the upper trim levels.
    I haven’t bought a truck yet, and honestly this is probably the biggest strike against the Tundra for me.
    RPKEAN and Rex Kramer like this.
  29. Jul 3, 2020 at 11:30 PM
    #89
    Gdry06
    Gdry06 New Member
    I would just get a sr5 with the bench seat and upgrade it frm there.. your not missing out of anything with the added trim levels that you can't add aftermarket or oem swaps..
  30. Jul 3, 2020 at 11:52 PM
    #90
    Gdry06
    Gdry06 New Member
    That was my whole delima as well. Family of six and rather take the tundra most places as well. I got lucky and found a guy local that did a swap for a center console. But you can get them off ebay or check your local wrecking yard or car-parts.com. 07- up will fit.. best to look for one that has the same Interior or just get a seat cover like I did.
    #90
