Conversion from center console to center seat
Discussion in '2.5 Gen Tundras (2014-2021)' started by Snoozer, Jan 22, 2018.
  1. Jan 22, 2018 at 1:49 PM
    Snoozer
    Snoozer [OP] New Member
    2014 MGM Sequoia Limited 4x4
    carseats
    I've read dozens of threads on TT, TS, and Tundras about this. I've done an online chat with a local Toyota parts counter guy. I've emailed Toyota corporate directly. I cannot find an answer on this topic.
    I KNOW it must be possible. And I'm confident that it isn't terrible to do either. It actually looks quite simple. Toyota isn't a manufacturer that reinvents the entire cab floor, the seats, the dash, etc. when configuring a 40/20/40 seat v.s. a bucket setup with the center console. In fact, no manufacturer today is; it just isn't cost effective. I have a HUNCH this conversion is simply the swapping of a few big pieces:
    • Steering Column (to move the trans shifter from the center console to the steering column)
      • Would the Tow/Haul button on the column shifter stalk have to be there, since I have a Tow/Haul button on my dash currently? Could I source a column without the Tow Package? I've discovered the Non-Tow Package columns are both cheaper, and more commonly found online.
    • Removing the Center Console
    • Installing a matching Center Seat and installing respective seatbelt.
      • possibly a "trim piece/panel" on the bottom of the dash where console was
    • Possibly a new wiring harness and/or shift cable if they are different between column and floor shifter configurations.
    As I said, I tried to get an answer on this from every viable source I could think of. I've spent plenty of time with wrenches in my hands, so I know I could do this swap! I've even found a steering column and center seat from a wrecking yard that are very affordable. The :ballchain: is that I DON'T know whether the steering column and associated wiring harness is compatible. There's also the heater vents coming out of the back of my center console that would have to be dealt with somehow, as I don't think the center seat has those. I can't afford to "buy parts and try it out and see".
    I've also considered doing a swap with someone who wants the center console setup.
    Has anyone done this conversion? Or has anyone seen a thread that covers this completely? (Not just talked about it and then the thread fizzle out with no closure)
    From this
    To this!
  2. Jan 22, 2018 at 1:58 PM
    Snoozer
    carseats
    More info:
    I actually WANTED to buy a Crewmax SR5 WITH the 40/20/40 front seat. The salesman adamantly told me that the 2016 Crewmax was NOT available in that configuration. I later learned he was full of :crapstorm:. That... or the fact that my CM SR5 has the "SR5 upgrade" package which includes the
    • 38 gallon gas tank
    • power rear window
    • center console.
    I read somewhere that mentioned the "SR5 upgrade" package including those features, and so the salesman MAY have been partially correct in what he was saying, but he sure didn't give me all the facts. :rolleyes:
    I could have gone without the 38 gallon tank. -(That could have been swapped in later, I've seen that swap covered) :gossip:. But the power rear window :cool: my wife loves that feature!
  3. Jan 22, 2018 at 2:01 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Just trade trucks with Almaboy. I dont think he has a woman to sit next to him anyway.:devil:
    You would probably need new carpet too.
    BlueBottle, 831Tun, geno0506 and 4 others like this.
  4. Jan 22, 2018 at 2:12 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    :rofl::rofl:
    Seeing that I was not officially tagged makes me believe you’re being a meany behind my back :smack:
    @Snoozer ive, too, pondered this....but in reverse of what you’re asking. I can live with the column shifter, but I’m interested in having the center console minus the shift box. I’ve even been told by a parts guy that I should go to a junkyard rather than purchase the parts
  5. Jan 22, 2018 at 2:14 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Carpet is fine. It’s the ceiling liner I’d be concerned about
    :oldglory:
    TheBeast and Tacogrande[QUOTED] like this.
  6. Jan 22, 2018 at 2:17 PM
    Snoozer
    carseats
    Alma is less than 2 hours from where I live. Would you entertain the idea of swapping columns and center console/seat?
    I also think it would be better to find the parts at a junkyard rather than buy them new from a dealer. The money savings is enormous. And the center seats don't get sat in very much anyway.
    What year is your Tundra, Almaboy? And what color is your interior?
  7. Jan 22, 2018 at 2:18 PM
    Snoozer
    carseats
    Is your ceiling liner embossed for more head room or something?
    TheBeast and Eclipsed & Floating like this.
  8. Jan 22, 2018 at 2:22 PM
    Tacogrande
    Jeremy
    Im not that cool so i dont know the procedure of how to tag someone but i am cool enough to know that yea i would need to steam clean the headliner.:D
  9. Jan 22, 2018 at 2:23 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I’d entertain it. Where are you?
    2017 double cab
    Grey interior, black carpet
  10. Jan 22, 2018 at 2:24 PM
    Eclipsed & Floating
    Voluptuous Whitey
    You’re cool enough, you took a pretty fly stab at someone that talks enough s*** to drive everyone away :D Nice work!
    Tacogrande[QUOTED] likes this.
  11. Jan 22, 2018 at 2:26 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Are you savy enough to swap a column shifter?? I’m not but can see the possibilities if you are...as long as we aren’t screwing anything up
  12. Jan 22, 2018 at 2:33 PM
    Tacogrande
    Jeremy
    :hattip: :militarypress:
    Im actually interested in swapping to the column shift but keeping my center console... only if its easily doable. I would delete the console shift and custom build something or other in place of it.
    epa4wd likes this.
  13. Jan 22, 2018 at 2:34 PM
    Eclipsed & Floating
    Voluptuous Whitey
    My exact thoughts, but @little_pansie_joonbug claims I’m crazy for even thinking about it
  14. Jan 22, 2018 at 2:43 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Try it!!! I dare you.
  15. Jan 22, 2018 at 3:02 PM
    Snoozer
    carseats
    Yes...
    IF I can figure out all the chess pieces involved; mainly the wiring "edits" (if any). The rest "looks" fairly straightforward. Again, I doubt Toyota "reinvented the cab" when configuring 2 v.s. 3-passenger front seats. But I don't know that either. The trans hump in the floor might sit taller on a console truck for some reason. :notsure:
  16. Jan 22, 2018 at 3:05 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I certainly haven’t committed yet, but I’m very interested in hearing what you come up with
  17. Jan 22, 2018 at 3:10 PM
    Snoozer
    carseats
    Certainly not.
    What year and grade is your Tundra? -You list no specs at all in your profile page or in a signature... :spy:
    Are you a pretend Tundra owner? :typing:
    TheBeast likes this.
  18. Jan 22, 2018 at 3:13 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Yep, I’m with the IRS and lurking for pertinent info on all the Tax dodgers
    2017 TRD OFF-ROAD 4x4
    5.7
    Double cab
    White
    3/1 Lift
  19. Jan 22, 2018 at 3:26 PM
    Snoozer
    carseats
    I totally missed that in the beginning.... my bad. :oops::)
    The 2017 should work. Gray interior?..... :facepalm: Mine is the black cloth. Looks exactly like this:
    Although, there's a lot of two-tone black/gray/silver in my interior. A center gray seat might not look totally out of place... :notsure:
    :rain:
  20. Jan 22, 2018 at 3:33 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Mine is all black
  21. Jan 22, 2018 at 3:44 PM
    Snoozer
    carseats
    Post #9 you say "Gray interior"...
  22. Jan 22, 2018 at 3:45 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Oops
    Black with gray trim is actually the color
  23. Jan 22, 2018 at 3:47 PM
    Snoozer
    carseats
    Okay. So what does it look like? Like the picture I posted above?
    Edit: Sent you a PM @Almaboy
  24. Jan 22, 2018 at 3:50 PM
    Eclipsed & Floating
    Voluptuous Whitey
    It’s black, with grey trim
    The pattern on all gen 3 cloth is the same. It’s just like yours. I thought you would’ve figured it out after I said black w/ gray
  25. Jan 22, 2018 at 3:56 PM
    Snoozer
    carseats
    :ohsnap: :rimshot:
    "Trim" and "accent" or "stitching" are 2 different things. Why would I assume anything you're describing in a conversation like this?
    You're wearing a blue shirt!!! Ah... but its a plaid shirt, which the main color scheme IS blue, but there's also white and gray in the pattern, and it has red stitching...... :poking: But wait,... I'm wearing a shirt with red stitching too! So it must be a blue shirt! Nope, its just a solid red t-shirt.
    :playball:
  26. Jan 22, 2018 at 4:01 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Sorry, Martha Stewart. I didn’t mean to confuse you with my trim talk
  27. Jan 22, 2018 at 4:04 PM
    Snoozer
    carseats
    Its okay, Shirley. :pccoffee:
    Eclipsed & Floating likes this.
  28. Jan 22, 2018 at 4:15 PM
    Eclipsed & Floating
    Voluptuous Whitey
  29. Jan 22, 2018 at 4:48 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Sooooo.....
    What’s the purpose of this?
    Extra kids?
  30. Jan 22, 2018 at 4:53 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    hells no. outside the city it's called "riding bitch" and it's where the girlfriend used to sit back when every truck had a regular cab with a bench seat.
