Conversion from center console to center seat
Discussion in '2.5 Gen Tundras (2014-2021)' started by Snoozer, Jan 22, 2018.
  1. Jan 22, 2018 at 6:05 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I get that lol. That’s old school. I haven’t had a bench seat since the early 90s when I had my Delta 88.
  2. Jan 22, 2018 at 6:16 PM
    geno0506
    geno0506 New Member
    Michael
    You just threw Almaboy
    Eclipsed & Floating likes this.
  3. Jan 25, 2018 at 7:01 AM
    Rotty23
    Rotty23 New Member
    Phil
    Upstate SC
    2014 1794 CM 4x4 Blue Ribbon Blue Metallic
    TRD Pro grill, TRD rear sway bar, Bilstien 6112 up front set at middle setting, Bilstien 5160s on rear, BFG KO2s on Method 20x9 wheels, drilled and slotted rotors, color matched front bumper caps, mirror caps and door handles, BA 8" stainless exhaust, TRD Pro skid plate, drivers side grab handle
    You guys are crazy...lol
    MotoTundra likes this.
  4. Jan 25, 2018 at 7:07 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I agree. I wouldn't dare try that swap.
  5. Jan 28, 2018 at 8:32 AM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    I'm fairly certain it would be cheaper (let alone way easier) to just trade your truck in on one that had what you're looking for.
  6. Jan 28, 2018 at 9:15 AM
    ToyotaTundraMike
    2015 Tundra
    I have the configuration you want and I hate it. The big raised area in the middle of the floor makes it very uncomfortable for someone to actually ride in the middle unless it’s a small child or something which is illegal in most states.
    I will trade you trucks if you want a bench seat. It is completely useless. I would MUCH rather have the extra storage, ability to upgrade to a badass shifter, and cup holders in a better location.
    Pudge and epa4wd like this.
  7. Jan 28, 2018 at 11:11 AM
    epa4wd
    epa4wd New Member
    Ed
    Agree, I wouldn’t go as far as hating it, but yeah it is uncomfortable and pretty useless. I don’t mind as the storage is enough, at least for me and I do like the storage under the bottom seat as it is pretty stealth.
  8. Jan 28, 2018 at 12:30 PM
    ToyotaTundraMike
    2015 Tundra
    Yeah hate was a strong word but it is pretty useless. I like the idea of the stealth storage but it’s a pain in the ass to access it if you keep things on your console (drinks etc) because you have to move everything and the when you lift the middle part up all your stuff in the tiny storage areas moves around. Toyota definitely could have put more thought into the design.
  9. Oct 8, 2018 at 8:30 PM
    Hatric
    Hatric New Member
    2015 Gray Tundra SR5 4X4
    So... Speaking of "(Not just talked about it and then the thread fizzle out with no closure)"
    Did you ever find a solution? I'm not looking to get rid of my truck... And I've got a 4th boy on the way. So I would really dig a 6th seat at this point.
  10. Nov 6, 2018 at 6:39 AM
    aw113sgte
    aw113sgte New Member
    Has there been any update on this? I haven't been able to find any definitive info.
  11. Nov 7, 2018 at 6:48 AM
    solidsnake
    solidsnake New Member
    Colorado Springs
    2017 Lexus RX 350
    14srAKH and Pudge like this.
  12. Nov 7, 2018 at 9:31 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Whats up with that rear window frame?
  13. Nov 7, 2018 at 9:32 AM
    ToyotaTundraMike
    2015 Tundra
  14. Nov 7, 2018 at 9:38 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Looks Like maybe he made a screen frame for it. Maybe for sleeping inside the cab?
  15. Dec 2, 2018 at 2:21 PM
    BIGED1975
    BIGED1975 New Member
    Massachusetts
    2018 Super White Sr5
    Level kit WHeels/Tires Exhaust center console conversion
    just did the opposite this weekend put a center console in....console only at moment but, all that is needed to convert to center console shift from column shift is the shift assembly along with the shorter cable ...the cable goes thru same hole on the floor as far as tow haul button that also can be purchased and wired to the spot on dash and change column or just cut/disconnect remove cable and keep same column i will be doing this in the spring (console shifter)
  16. Dec 2, 2018 at 2:25 PM
    Tacogrande
    Jeremy
    Pics?
  17. Dec 2, 2018 at 2:26 PM
    BIGED1975
    Massachusetts
    working on it as i type
  18. Dec 2, 2018 at 2:40 PM
    BIGED1975
    Massachusetts
  19. Dec 2, 2018 at 2:40 PM
    #49
    BIGED1975
    Massachusetts
  20. Dec 2, 2018 at 2:41 PM
    #50
    Pudge
    CT
    I think that looks just fine without the shifter. Make that space into a phone charging pad or something
  21. Dec 2, 2018 at 2:42 PM
    #51
    BIGED1975
    Massachusetts
    was thinking same thing i made a filler panel in place of shifter
  22. Dec 2, 2018 at 2:43 PM
    #52
    BIGED1975
    Massachusetts
    as far as the actual full conversion i dont believe it is as hard as everyone here is making it to be looks pretty straight forward
  23. May 5, 2019 at 5:40 PM
    #53
    Hatric
    Hatric New Member
    Nice... Said boy is here now it's time to get serious!
    It's a problem getting my truck with the bench because the SR5 deletes the bench for the console. I need to start buying parts.
  24. May 5, 2019 at 7:10 PM
    #54
    Hatric
    Hatric New Member
    @BIGED1975 you don't happen to still have your center seat and belts do you?
  25. May 5, 2019 at 7:22 PM
    #55
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I was just thinking about this for my '08. Have bench seat with column shift. Want console with floor shift....
  26. May 5, 2019 at 7:26 PM
    #56
    Hatric
    Hatric New Member
    2008 though? Not sure if we're a compatible swap. 2017 here.
  27. May 5, 2019 at 8:16 PM
    #57
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    I'm kinda with ya @Snoozer - had a bench seat front in my '14 tundra and liked it, miss it most times.
    Who needs two and a half cup holders when you have an elevated twelve pack holder in the center with the bench (to be consumed later at home, of course). Can't set a case on the center console... End up scratching the chrome/plastic fancy pants trim and won't be able to shift...
    There are other benefits, but I hear there's a new moderator in town with a ban hammer, so I'll let everyone use their imagination. Hope you get this swap figured out, good luck.
    Ketchumj likes this.
  28. Mar 23, 2020 at 3:47 PM
    #58
    14srAKH
    14srAKH New Member
    2014 tundra sr white
    Wheels, center console swap, tinted windows,
    I dont have photos yet but I just did the center console swap no shifter yet though. All that was needed was the console assembly i got through lkq.
    Looks like it was meant to be there with zero modification.
    Has anyone figured out the shifter part of this yet?
  29. Mar 23, 2020 at 4:50 PM
    #59
    Hatric
    Hatric New Member
    Photos from my existing setup. While you were swapping did you see any extra cables that look like these. Likely behind the ECU panel?
    Plugged in cables are on Dash side, multi angle plug photo shoot plugs in on the back side (clcloser to rear seats)
    I still need to find out if there are cables buried in the dash for my reverse setup.
  30. Mar 24, 2020 at 2:06 PM
    #60
    14srAKH
    14srAKH New Member
    I honestly didn't even glance in the dash or under the carpet for plugs of any kind.‍♂️‍♂️
    I did on the other hand search the interwebs and I feel somewhat confident that the plugs are the same for the console shifter and the column shifter. From what I've seen for plugs they all look the same for both.
    So I just ordered the console shift assembly to see if I'm right. Lol
    Feeling committed now.
    YeeYeeTundra likes this.
