Comfort+ on 2020’s
Discussion in '2.5 Gen Tundras (2014-2021)' started by mountainpete, Mar 29, 2020.
  1. Oct 17, 2020 at 7:31 AM
    #61
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I am thinking that they use a thermistor for the temperature sense, cause they are cheap and bulletproof (almost). It Is used in a voltage devider type of circuit, control wires can be thin, som thermistors come with 30 gauge wires. Some thermistors are just a chip for pc boards. More of a concern of vibration and handling.
    maybe a thermocouple, produces a voltage, wires can be thin also.
    my motorcycle grips and heated vest were just power on power off on the heating element. I did not have the optional temperature control.
  2. Oct 17, 2020 at 8:15 AM
    #62
    CrewMaxT
    CrewMaxT New Member
    Alberta
    2018 CrewMax SR5
    One of the techs I work with installed the in cab heater in a customers vehicle. They seem like a pita to install. Personally I would spend the money on a car starter instead. The unit is going to add some warm air to the cab, won’t be enough to warm up the seats/steering wheel or melt snow of the exterior. You only need a trickle charger if you drive your truck less than once a week. Also, block heaters get installed at the dealer during the PDI. Most of Canada gets them but not all provinces, BC is one of them. Lots of people like to idle their vehicles until they’re toasty warm inside. Excessive idling builds up moister and aids in sludge. The engine, trans and diffs will warm up much faster by driving. At the end of the day it’s your truck, so do with it what you like. Just dropping some extra info.
  3. Oct 17, 2020 at 8:23 AM
    #63
    blanchard7684
    blanchard7684 New Member
    Correct.
    Guessing Victor Shepherd did quite a bit of idling as well (million mile tundra guy)
  4. Oct 17, 2020 at 1:41 PM
    #64
    timsp8
    NY
    Yeah maybe the comfort + one if you are installing the plug in the bumper. But the other one you just plug it in the hole and hand the wire to your wife and then zip strip it in a few places. It took me longer to find the plug hole than to install it.
    This is the one I was talking about.
    https://www.ebay.com/i/170895576944...MI39arh7687AIViuazCh39WABxEAQYAyABEgLDkvD_BwE
    #64
  5. Nov 8, 2020 at 3:48 PM
    #65
    dgmtld
    dgmtld New Member
    Saskatchewan, Canada
    2019 Tundra Crewmax SR5 Off Road Cement
    I had one installed on my 2019 Tundra. It has a block heater and interior warmer that are controlled by a bluetooth app on your phone. The app allows you to have the system on, off, or scheduled. I can't tell if the block heater is always on or not, but I believe the block heater and interior warmer are only on when the system is switched on. The main reason I bought it was to get the windows heated up enough that I don't have to do a hard scraping job to get the ice off the windows, because that takes time and can scratch the windows. Trying it out for the first time as the snow is arriving in a blizzard right now. It's about -8C (17F), and the interior warmer made a big difference and I had to scrape much less and the ice that was there came off easier. We'll see how it does when it gets colder here as it goes down to -30C (-30F) and below.
    Warreng likes this.
  6. Nov 8, 2020 at 4:45 PM
    #66
    mountainpete
    mountainpete [OP] Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Welcome to the forum!
    Could you post some pics of the in cabin heater?
  7. Nov 10, 2020 at 10:20 AM
    #67
    dgmtld
    dgmtld New Member
    Hi, here are some photos. The heater and wireless hub look exactly like the one Oats87 posted the link for on April 1, 2020. It seems like the cabin heater just takes the chill off rather than heating the truck up like when the engine is running. We'll see how well it does when it gets colder. The Comfort+ system shuts off as soon as you start the vehicle and it gives you a warning if the cable is still plugged in.
    mountainpete[OP] likes this.
  8. Nov 10, 2020 at 10:39 AM
    #68
    mountainpete
    Very cool. What kind of warning does it give you? Is it on the center display of the gauge cluster?
  9. Nov 10, 2020 at 10:52 AM
    #69
    dgmtld
    dgmtld New Member
    Hi, the warning is actually on the app on your phone. It would be nice if it was on the dash too. Maybe the newer trucks will have that option on the dash.
  10. Dec 17, 2020 at 1:27 PM
    #70
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
    I optioned this on my MY21 and got the first chance to use it in some actual cold yesterday. It definitely takes the chill off in -21ºC weather. I had the preheat set for 3hrs and the inside was tolerable enough to get in, start up and drive off without having to let the truck run for 10mins. Tolerable meaning I couldn't see my breath inside the cab when I jumped in. Seems like a worthwhile investment so far
  11. Dec 17, 2020 at 2:17 PM
    #71
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I don't know. Seems like a lot of money for a car warmer. My grandmother had one in her car. It was plugged in on a timer so it warmed the interior.
    MaxMB likes this.
  12. Dec 17, 2020 at 4:49 PM
    #72
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
    Yeah, I can see that point of view, but it's subjective. For me, it was an added cost above the block heater that includes a trickle charger and cabin warmer. It is controlled by an app on my phone via Bluetooth, all the while being packaged up all nice and OEM like
    At the end of the day, it allows for a fresh battery and a somewhat toasty cabin. It'll reduce the idling time on my truck, which in turn will save fuel and arguably lessen wear and tear as a result. Will it be be a positive ROI? Maybe, maybe not
    Huckwheat likes this.
  13. Dec 17, 2020 at 5:03 PM
    #73
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It doesn't actually warm the motor so your warm up time shouldn't change.
    Cpl_Punishment likes this.
  14. Dec 18, 2020 at 7:00 AM
    #74
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
    Yes, I realize it doesn't warm my motor. Maybe I worded that funny...it warms the cabin enough I don't have to thaw my windows by waiting for the motor to get up to temperature before I drive off. So that reduces my idling time. Motor warm up time doesn't change
    Ruggybuggy[QUOTED] likes this.
  15. Dec 18, 2020 at 7:23 AM
    #75
    Warreng
    Warreng New Member
    If we want to get scientific about this, a block heater most certainly warms the motor.
  16. Dec 18, 2020 at 7:38 AM
    #76
    mountainpete
    Is the app free? I am assuming there is no monthly fee like the other Toyota connected services.
  17. Dec 18, 2020 at 8:39 AM
    #77
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    We aren't talking about a block heater. We are talking a interior car warmer.
  18. Dec 18, 2020 at 9:04 AM
    #78
    49ºNRTH
    49ºNRTH New Member
    2025 Limited MGM
    Yup, app is free and separate from the Toyota Connected Services stuff. You do have to be within Bluetooth range to set/adjust the pick up timer and how long the heater will run for before the pick up time
    i.e.- pick up at 13:00 and run heater for 3hrs beforehand
  19. Dec 18, 2020 at 11:50 AM
    #79
    Warreng
    Warreng New Member
    Gotcha, my bad
  20. Dec 18, 2021 at 5:29 PM
    #80
    dgmtld
    dgmtld New Member
    Hello, just an update on the alerts. I have a smart watch now, and if I start the truck with the cable plugged in, an alert comes up on my smart watch. Pretty handy. And it shows on the phone too, but the watch gets my attention.
  21. Feb 6, 2022 at 12:23 PM
    #81
    xuy
    xuy New Member
    2021 TRD PRO Super White
    After this cold winter here in Alberta, I finally pulled the trigger on the comfort + package. I bought my 21pro from BC and she doesn't come with a block heater. One day I had to drive her to work cuz wife needs to use the Honda. It was -37 plus wind chill feels like -48. She started with no problem but she didnt like it. She was MAD on the way home.
    I had the dealership installed for less than 1k. One year warranty. Electricity is free at work so I ll have it plugged in and run the whole time of my 12 hour shift everyday.
    I used the cabin warmer I bought from Canadian Tire on my 19 taco pro. And it is not bad. The only thing I dont like about it is that ugly cord hanging in the front. With OEM it looks way nicer. With the charger I can go with a more expensive battery later. In a long run saving the life a battery can save you lots money well.
    I don't really like the fact that the block heater doesn't go directly into the coolant. So it's kind like a partial area heating which is less sufficient. But what can you do. Better than nothing. But you have to realize that your engine is always little warmer closer to the back.
    Also there is someone mentioned that the cabin warmer is 12v instead of 120v AC. So that's the reason it needs a battery charger to keep up with it.
    When you look at the specs, block heater pulling 900-1000w, and your cabin heater is pulling another 900-1000w. So almost 2000w when I plug it in for 12 hours straight at work cuz electricity is free and I want my max comfort. That's a heavy load on the cord :)
    I need to check into this. If it's using 12v, I don't think it's gonna work nearly as good as the CT 120v little buddy.
  22. Feb 6, 2022 at 12:36 PM
    #82
    xuy
    xuy New Member
    Just checked the cabin warmer is 120v so I imagine it's sharing the AC power with the block heater. I had my truck scheduled in for Tuesday install. Will shoot some pics after if you guys need.
    Ruggybuggy likes this.
  23. Feb 6, 2022 at 3:26 PM
    #83
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    No worries about the block heater going into the coolant passage. All Toyota vehicles do it this way and for quite awhile. The bore that the block heater fits into is close to the coolant passage and with the aluminum block the heat transfers well.
