Comfort+ on 2020’s
Discussion in '2.5 Gen Tundras (2014-2021)' started by mountainpete, Mar 29, 2020.
  1. Mar 29, 2020 at 8:35 PM
    mountainpete
    mountainpete [OP] Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Just did a build and price on a 2020 Tundra for fun and came across the Comfort+ add on. Did a search here but can’t find anything. Does anyone know how the cabin heater works?
    https://www.toyota.ca/toyota/en/owners/accessories#/al/comfort-plus
    From Toyota.ca:
    COMFORT+ Enhanced includes the Battery Trickle Charger, Cabin Warmer and Bluetooth Hub. For ultimate comfort, enjoy a warm cabin right from the start - no idling required. The Cabin Warmer is a sleek and compact interior heater that is permanently mounted inside the vehicle cabin. As the Cabin Warmer heats up the interior of the vehicle, ice and snow buildup on the exterior of the vehicle may be reduced, potentially eliminating the need to scrape away ice or brush away snow. By pairing the Trickle Charger unit with the Bluetooth Hub, the Trickle Charger unit can be used to control and schedule the Cabin Warmer through the Toyota COMFORT+ App.
    DIYDad likes this.
  2. Mar 30, 2020 at 6:03 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    This is quite interesting. Would never need this in Florida but would have liked it when I lived in NY.
  3. Mar 30, 2020 at 6:54 AM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Yeah it’s now a plug in EV :rofl:Kind of.......
  4. Mar 30, 2020 at 7:05 AM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I can buy a lot of idling gas for a grand to warm my truck up
    MaxMB, AggiePhil, kittyhawk and 3 others like this.
  5. Mar 30, 2020 at 7:35 AM
    mountainpete
    Agreed but that price is Canadian money, installed, msrp for a bunch of things. So, probably like a $500 usd add on?
  6. Mar 30, 2020 at 8:02 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Hmmm. Some of the critters might like the heated cabin also if you live in the country..:spy:
    NewImprovedRon likes this.
  7. Mar 30, 2020 at 8:54 AM
    Northern Toyota
    Tires and bilstein
    I live in the land of colourful money as well.
    plumber802 likes this.
  8. Mar 30, 2020 at 9:02 AM
    mountainpete
    Then I agree with you. Super pricey.
    But I am really curious if the cabin heater can be purchased and installed separately. If it's a reasonable price and can be connected via a timer to the block heater I may be interested in it.
  9. Mar 30, 2020 at 9:07 AM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Can't buy the less wear and tear though.
  10. Mar 30, 2020 at 9:09 AM
    Northern Toyota
    Tires and bilstein
    If that wears out my tundra, I'll re evaluate my Toyota purchases. 300k on my Tacoma and still going strong
    I'd consider it for a couple hundred dollars, but not what they want for it installed at least
    AggiePhil and Blue Thunder like this.
  11. Mar 30, 2020 at 9:12 AM
    mountainpete
    @Roman is this a Canada only thing? Any insight to the components and potential costs?
  12. Mar 30, 2020 at 9:17 AM
    GravityGear
    Aurora, CO
    I never said it would clap it out. You can't argue that MORE run time does not equal less or equivalent wear.
  13. Mar 30, 2020 at 10:17 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    What exactly is a Blue Tooth Hub?
    AggiePhil likes this.
  14. Mar 30, 2020 at 10:30 AM
    mountainpete
  15. Mar 30, 2020 at 10:43 AM
    Northern Toyota
    Tires and bilstein
    I am saying the extra wear from using a remote start and letting my tundra idle for 10 minutes would not be detectable over 10 years or however long you own it for.
  16. Mar 30, 2020 at 10:57 AM
    mountainpete
    Still trying to figure that out, but this is my current assumption:
    The Bluetooth hub is a small processor (computer) that the block heater, charger and cabin heater connect to. Using your phones Bluetooth connection and the Comfort+ app, you can program on/off times and other functions. It's not built into the navigation/radio or connected to Etune. Completely separate unit. It also appears that all functions rely on a 110 plugin to work.
  17. Mar 30, 2020 at 12:23 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    Eh..sounds complicated...doesn't get that cold here in SC. Sounds more like a cold weather package.
  18. Mar 30, 2020 at 12:37 PM
    mountainpete
    From what I am seeing so far, it's a Canada only accessory and definitely cold weather focused.
  19. Mar 30, 2020 at 12:46 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    What? No idle free AC????
  20. Mar 30, 2020 at 1:35 PM
    daven
    daven New Member
    2019 Tundra Double Cab Limited
    I like it, but would turn that on and idle the truck to get it heated up faster.. Takes forever to warm up in the cold.
  21. Mar 30, 2020 at 3:01 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Has to be a Canadia thing. Never seen it before.
  22. Mar 30, 2020 at 9:46 PM
    Millski
    Millski New Member
    2020 Sport Premium Crewmax
    Nada
    I'm in Calgary and ordered a truck just before this covid-19 business. When I ordered it they were forecasting delivery end of April but who knows at this point. This is the 1 accessory I am getting but likely wont know if it was worth it until next winter. My assumption is that the electric heat will heat the cabin much faster than waiting for the engine to warm up.
  23. Apr 1, 2020 at 12:19 AM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Doing a little bit of digging into this, it looks like this is a rebranded "DEFA AS" system, more information can be found here: https://www.defa.com - a Norwegian company so these guys definitely know cold.
    In cabin heater looks like a Termini II from the graphics.
    mountainpete[OP] likes this.
  24. Apr 1, 2020 at 4:32 AM
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    I’m from Canada and in one of the coldest areas. I never heard or saw such an option and both my Tundras were ordered.
    I think this is an option for certain regions of Canada “Northern Canada”. It would be similar idea to the TSS edition of the Tundras only sold in some regions of the States.
    Or it’s an April fools joke by OP :)
  25. Apr 1, 2020 at 4:34 AM
    timsp8
    NY
  26. Apr 1, 2020 at 4:42 AM
    timsp8
    NY
    You can find the defa heater that @Oats87 linked to on eBay for under $100. Toyota block heater is about $40. A good battery charger is maybe $100. Only thing you are missing is the Bluetooth. All for 1/4 the price.
  27. Apr 1, 2020 at 6:17 AM
    mountainpete
    That’s the one!
  28. Apr 1, 2020 at 6:19 AM
    mountainpete
    No joke. Build a Tundra on toyota.ca and it’s in the accessory list. I called my local dealer and they confirmed it but had almost zero info.
  29. Apr 2, 2020 at 5:42 AM
    Hostage81
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    That’s crazy. I’m on the site all the time and never saw it. I’ll check again.
  30. Oct 15, 2020 at 8:13 PM
    Millski
    Millski New Member
    Nada
    Plugged my truck in tonight so I can try this out in the morning for the first time. Not cold at all yet only -3C tonight I think but wanted to try it out and see how it works on the “auto” setting.
    Wrongside and Cpl_Punishment like this.
