Code: P1445
Discussion in '1st Gen Tundras (2000-2006)' started by 2006Tundra, Sep 25, 2020.
  1. Sep 25, 2020 at 1:29 PM
    2006Tundra
    2006Tundra [OP] Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    P1445: Secondary Air Injection System Switching Valve No.2 Bank2 Stuck Closed
    I've been dealing with this code for about a year now. I clear it every time it comes on. I haven't had any issues with my motor or passing SMOG.
    Well, it came back a few weeks ago and I figure what the heck, lets see what my mechanic says about this code. He says parts alone for this job are going to be $1300 with labor being $500 :eek2:. He's a Toyota/Lexus specialist and he only uses Toyota parts. I've been going to this guy for years for major projects. He did say, if I don't have any issues, not to worry about it
    I see that Hewitt Tech has a bypass kit that is SMOG friendly. Anyone here have experience with this particular model below?
    https://hewitt-tech.com/store/index.php?l=product_detail&p=94
  2. Sep 25, 2020 at 1:33 PM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    They will fail again, just do the bypass and be done
  3. Sep 25, 2020 at 1:46 PM
    2006Tundra
    Lou
    Long Beach, CA
    yeah, $400 buck vs $1800 sounds a lot better but I would like to know if anyone else here has installed the bypass. I need to tap into the ECM and I don't feel all that confident playing with that. I need to do more research on that.
    HewittTech01 likes this.
  4. Sep 25, 2020 at 2:14 PM
    shifty` One great big festering neon distraction
  5. Sep 25, 2020 at 2:32 PM
    Professional Hand Model
    Hand Protectors
    Survey says: Doable!
    HewittTech01 and revtune like this.
  6. Sep 26, 2020 at 5:11 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
  7. Sep 26, 2020 at 2:23 PM
    2006Tundra
    Lou
    Long Beach, CA
  8. Sep 28, 2020 at 6:19 AM
    This is probably the answer to your question:
    Brand: maXpeedingrods
    Country/Region of Manufacture: N/A
    Usually when vendors won't list the country of origin, it's because it's made in a sweathouse workshop somewhere in Asia. If they're offering less than 1-2yr warranty or not listing the warranty at all, assume it will be failing sooner than later. This one lists it, but look at the page: Do you see any indication there'll be anyone to warranty with if it lasts less than 2 years? Yeah, I wouldn't trust it.
    tl;dr - Be ready to tear things down and replace it again in less than 12-18 months. This isn't the rule, it's just common enough to be aware.
  9. Sep 28, 2020 at 6:34 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I have the Hewitt plug and play bypass and the proxy pack on my 2006. It’s been working great so far.
  10. Sep 28, 2020 at 6:36 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    HewittTech01 and hewitttech like this.
  11. Sep 28, 2020 at 7:48 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    Will the bypass get rid of the check engine light or does it stay on?
  12. Sep 28, 2020 at 8:01 AM
    FrenchToasty
    Mo
    The SoAz
    None
    You would have to clear the code, but no it shouldn’t ever come back. The system tricks the computer to think its above the temp that it needs to be ran at. If the computer never sees the need to run it, it won’t have the possibility to to come up as stuck or failed system code
  13. Sep 28, 2020 at 6:36 PM
    2006Tundra
    Lou
    Long Beach, CA
    Did you have to take the intake manifold off? Hewitt told me that I need to take it off in order to install the plug n play.
  14. Sep 29, 2020 at 4:20 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Nope, I did not touch the intake manifold. Check out this video showing and explaining the bypass and installation. Very helpful video.
    https://youtu.be/WDzNfW7Ti5g
  15. Sep 29, 2020 at 4:31 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Yes, it does get rid of certain CEL’s, but I also installed the proxy pack to get rid of an additional code got that kept coming up. Everything’s been working well since February.
    It’s just very frustrating that the stupid pump was installed under the intake manifold. It should of been off to the side, like around the air box and power steering reservoir.
    Stuck in the '00s likes this.
  16. Sep 29, 2020 at 5:47 AM
    2006Tundra
    Lou
    Long Beach, CA
  17. Sep 29, 2020 at 7:01 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
  18. Sep 29, 2020 at 11:12 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    I concur.
  19. Sep 29, 2020 at 11:38 AM
    FrenchToasty
    Mo
    The SoAz
    None
    It’s funny, I wouldn’t recommend anyone move to AZ, not because it’s terrible but the complete opposite. It’s completely awesome and I don’t want to share!
  20. Sep 29, 2020 at 1:12 PM
    2006Tundra
    Lou
    Long Beach, CA
    I've been eyeing Texas. If you know anyone who is hiring for a commercial electrician, let me know. LOL :help:
  21. Sep 29, 2020 at 1:14 PM
    FrenchToasty
    Mo
    The SoAz
    None
    @bmf4069
    bmf4069 likes this.
  22. Sep 29, 2020 at 1:21 PM
    FirstGenVol
    East TN
    2002 AC
    I'm not sure TX can handle any more Californian's moving there. :rofl:It is crazy how rapidly Texas is changing.
    Sundown5oh and revtune like this.
  23. Sep 29, 2020 at 1:27 PM
    2006Tundra
    Lou
    Long Beach, CA
    I just hope that the people who are fleeing to Texas remember why they're leaving CA and NY.
    bmf4069 and revtune like this.
  24. Sep 29, 2020 at 2:34 PM
    Hand Protectors
    Yanks and Coolifornians. Please.
  25. Sep 29, 2020 at 8:59 PM
    bmf4069
    TX
    02 AC sr5 4wd v8
    I happen to have my masters and my (not MINE mine) company is looking for help. Pay wont compare to CA pay, but you can also get a 2500 sq ft home on an acre for around $200k here.
  26. Sep 29, 2020 at 9:26 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I used the Rutech kit. Its a little cheaper. I cleared the codes first then installed the bypass kit and block off plates. No codes since. :D
  27. Sep 30, 2020 at 7:14 AM
    flyfisher
    flyfisher Member
    David
    Sunnyvale, CA
    2005 Tundra SR5 Double Cab 4x4
    I have the Hewitt Gen 1 version on an '05 Tundra and I live in California and have no problem with smog checks.
    hewitttech and revtune like this.
  28. Oct 27, 2020 at 8:05 AM
    hewitttech
    hewitttech New Member
    Paul
    Toyotas/Lexus
    Secondary Air Injection System Bypass Kits
    I think you may be confusing our versions of the bypass kits. Our Gen-I kits (V36H and V54H) are 100% plug and play. The Gen-II-3V kit for the 4.7L requires three wires to be soldered into the ECM wiring behind the glovebox since those three connections are only also accessible under the intake. o make a Gen-II kit 100% plug and play you would have to remove the intake manifold but there is still no reason to remove it for any of our solutions.
    revtune, Rdway60 and shifty` like this.
  29. Nov 2, 2020 at 5:56 AM
    2006Tundra
    Lou
    Long Beach, CA
    Will your Gen 1 kit pass California SMOG?
  30. Nov 2, 2020 at 7:22 AM
    hewitttech
    Paul
    Toyotas/Lexus
    First I have to say again that we sell our kits for off-road or emissions exempt use only and that it is illegal to bypass or otherwise make inoperable an emissions system required for on highway use.
    Having said that, what you do with it is up to you and the short answer is Yes. As long as you don't have any other issues and drive it enough after reset that all the emissions monitors will show as complete/ready it is not a problem.
    The Gen-II kit is a much more friendly solution for getting an emissions exempt vehicle to pass smog if it had to. When installed, it looks like a factory part and there are no visual connections to the MAF, ECT or the starter relay to draw attn to it like the GenI kits. Also the Gen-II will actually let the emissions monitor for the system show as complete/ready while the Gen-I kit will just show as not ready/incomplete. Both can pass but it is much easier to not raise any eyebrows with the Gen-II kit.
