Clunking noise coming from front passenger side
Discussion in '1st Gen Tundras (2000-2006)' started by Slp82, Mar 27, 2019.
  1. Oct 25, 2019 at 7:00 PM
    Mytechguyri
    Mytechguyri New Member
    2004 Tundra 4x4 Access Cab step side
    Nah... I bought moog ball joints for my wife's Dodge... Figured Moog is a top brand... Both efective right out of the box....couldnt even tighten them up... The stem would just spin when you tried to tighten the bolt.... Returned them and got the cheap AutoZone brand and they lasted another 4 years at least (were fine when we sold the truck)
    bmf4069 likes this.
  2. Feb 25, 2020 at 6:18 PM
    Ob1
    Ob1 New Member
    Begs the question. Are only leveled or lifted trucks affected? Or are stock suspension trucks having this annoying issue as well ?
    revtune likes this.
  3. Feb 25, 2020 at 6:19 PM
    Ob1
    Ob1 New Member
    If yours is stock and having this issue, please chime in.
  4. Feb 26, 2020 at 7:35 AM
    Ob1
    Ob1 New Member
    Negatory, I'm on Bilstein 5100's top setting.
  5. Apr 23, 2020 at 3:15 PM
    Kyle700
    Kyle700 New Member
    2006 2WD Tundra DC
    None
    06 DC 2wd, was clunking stock, now with lift spacers on the front, still clunking. I have replaced everything except upper control arms.
  6. Apr 23, 2020 at 3:22 PM
    Kyle700
    Kyle700 New Member
    2006 2WD Tundra DC
    None
    It sounds and feels like someone hit the floorboard under the front passenger foot well area with a 3lb sledge. If I had to guess, maybe the spring catches on something. I remember when replacing the struts there wasn't much clearance from one of the springs to the steering knuckle. (I have not replaced the upper ball joints either)
  7. Apr 23, 2020 at 4:33 PM
    noahtibbetts
    noahtibbetts New Member
    Noah
    ‘06 SR5 Access cab
  8. Aug 30, 2021 at 9:40 PM
    Mallon3194
    Mallon3194 New Member
    Conor
    Tundra2020
    I’m having the same issue since fitting my 2020 tundra with Fox 2.5s RR , I had 5100s in before and never made a peep! Now I have a clunking noise front the front passenger side, metal on metal sounding when I articulate the passenger side up or down into a bump, I’ve been driving “slowly) onto a curb and stoping passenger side and it makes the clunk ever time! It’s definitely metal on metal! But I cannot see any marks or anything lose!
  9. Aug 31, 2021 at 8:51 AM
    shifty` Ten EV 12's so you know I raise hell
    Definitely may want to post about that over in the 3rd gen forum, someone with the same model of truck as you may have this issue too.
    Due to major differences between our 1st gen trucks and your 2rd gen, any advice you get in this 1st gen (best gen) subforum could lead to unexpected results or damage.
    PS - before anyone else replies .. ZOMBIE THREAD!
    N84434 and Mallon3194[QUOTED] like this.
  10. Aug 31, 2021 at 10:14 AM
    Mallon3194
    Conor
    Tundra2020
    Thanks man didn’t even realize there was as another forum for 3rd gen tundras lol
  11. Aug 31, 2021 at 10:37 AM
    Happens all the time. I think the 1st Gen guys are so accustomed to 2nd/3rd Gen folks replying on our threads we'd never hear the end of it if one of us did the same :D
  12. Aug 31, 2021 at 4:00 PM
    Slp82
    Slp82 [OP] New Member
    2005 Tundra RC 4.7 4x4; Toytec Boss 2.0 kit; SPC upper control arms; addicted offroad front bumper & 9k winch, Brute Force sliders & rear bumper, skid row skid plates, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    2014 Tundra 4x4 5.7L DC; Bilstein 6112s @ 1.9"; 35x12.50 Nitto Ridge Grapplers on 20x9 wheels with +25 backspacing; DV8 front & rear bumpers, Engo 12k winch (SOLD) 2005 Tundra RC 4.7 4x4 w/3" spacer, addicted offroad tube winch bumper w/9k Engo, homemade sliders, skid row skid plate, 285/75r16 Cooper AT3, Detroit trutrac in rear.
    I have been running those Moog for about 15k miles now, and that includes some off-road weekend trips to Barnwell Off-road park in Gilmer, Tx and the offroad park in Marble Falls, Tx. Most of it is rock crawling stuff. I have since added sliders, full underbelly skid row skid plates, cut the rear fenders, removed the factory tow hitch and rear bumper and replaced it with a custom high clearance rear bumper. I am in the process of trying to figure out how to gut the fender and fit 37s on it. If I can figure it out, I will regear to probably 4.88 gears. Yes I know I will have to probably beat the hell out of the firewall as well. I am fine with that. Anything that breaks is just an excuse to upgrade. I am also planning a solid axle swap in the next year or two.
  13. Aug 31, 2021 at 4:03 PM
    Slp82
    I wonder if yours is not a transmission (or maybe transfer case?) Mount from what you described...
  14. Aug 31, 2021 at 4:12 PM
    Slp82
    Mine was two different issues possibly combining to appear as one. The sway bar mount was causing some of the clunk and noise and I replaced that with a Moog bushing. That fixed it for about 6 months, then I split it again while offroad, so the noise is back, and I said the hell with it. I am about to pull the sway bar anyways.
    The other part was the steering rack bushing mounts. I put some silicone grease (silicone grease is the most water resistant and stays put better than any other grease) and that shut up the other part of the noise. Knowing what I know now, I would go through the suspension in the future, loosen anything or take tension off any bushing and spray silicone spray (liquid wrench makes one) on any rubber bushings. I would also inspect them for cracks to see if they need to be replaced. If you off-road like me, all bushing that are under a lot of stress are going to split fairly quickly. I will probably go with polyurethane bushings next time. They are supposedly tougher, but they make more noise and are harder so you feel more vibrations and road bumps which initially I didn't want. That's the trade off for durability though I guess.
    Dannydirtyfingers likes this.
  15. Mar 17, 2024 at 10:51 AM
    Brian2170j
    Brian2170j New Member
    2006 tundra crew cab sr5
    Just fixed the front end clunking on my 2006 tundra. Was four loose bolts on the crossmember where it bolts to the transmission. Found the fix tip on YouTube. Wish I could thank the the person that supplied the advice.
    Filthyphil likes this.
  16. Mar 17, 2024 at 10:55 AM
    This is only true for 2WD trucks. It's one of many topics covered in the megathread in the sticky section at the top of this 1st gen forum, which if you haven't read yet, you should...
  17. Mar 17, 2024 at 10:57 AM
    Brian2170j
    Don't rain on my parade, I'm still doing cartwheels I'm so happy with the fix hahahahaha
  18. Mar 17, 2024 at 10:59 AM
    Not raining, but check that thread, you may find other things that've been driving you nuts you can fix, turn those cartwheels into somersaults and backflips.
    Or you may find your truck is a death trap you need to stop driving :rofl:
  19. Mar 17, 2024 at 11:00 AM
    #49
    Brian2170j
    Thank you,
