Clay bar
Discussion in 'Detailing' started by Pudge, Mar 24, 2018.
  1. Aug 6, 2018 at 6:28 PM
    #61
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
  2. Aug 6, 2018 at 6:29 PM
    #62
    Pudge
    CT
    Nothing wrong with what you have. The synthetic is just a bit easier and quicker. especially the larger mitts
    MotoTundra likes this.
  3. Aug 6, 2018 at 6:42 PM
    #63
    Borgs
    Borgs New Member
    PA
    MotoTundra[QUOTED] likes this.
  4. Aug 7, 2018 at 5:01 AM
    #64
    MotoTundra
    MotoTundra The Ocho
    Don
  5. Sep 6, 2018 at 5:24 AM
    #65
    briarpatch
    briarpatch New Member
    If you want a product that doubles as an iron remover/clay lube, take a look at DoDo Juice supernatural Ferro Lube
    Pudge[OP] likes this.
  6. Sep 7, 2018 at 4:39 AM
    #66
    briarpatch
    I was lucky enough to get some in a giveaway on Autopia.....only down side to it is, like most fallout removers, the smell
  7. Sep 8, 2018 at 3:26 PM
    #67
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Those of you who use clay eraser mitt hex logic pad by CG instead of clay bar, you finding good results. Using the fine mitt.
    Seem like whenever I use it, pad scratches more than removing contaminants. I went back to my black CG bar and had better results.
    Wonder if I am doing something wrong. I am using clay CG clay lube. Should I lube the pad and surface?
  8. Sep 9, 2018 at 9:14 PM
    #68
    alpinepro4
    Pat
    I spray clay lube on the clean surface and then apply the mitt. 1st time I used it I marred up the surface slightly. Seems to me I need to use a heavy amount of lube in order to use the mitt safely. I used a fairly heavy clay bar with no marring. Heavy clay bar worked like a charm to remove contaminants.
    SouthBoundSteve likes this.
  9. Sep 10, 2018 at 9:22 AM
    #69
    alpinepro4
    Pat
    Used the clay Saturday, no there is no break in period for CG clay. I do spray some lube on the clay as well.
    Thinking I should purchase a nanoskin mitt. Sounds less harsh then CG mitt. CG uses this hex logic design that real harsh on soft Tundra paint. Anyone else having the same issues with CG mitt?
  10. Sep 10, 2018 at 9:41 AM
    #70
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    How often do you guys clay bar anyways?..:)
  11. Sep 10, 2018 at 9:56 AM
    #71
    alpinepro4
    Pat
    Clay to much, ubsessive compulsive when I wash and wax. Its real bad
  12. Sep 10, 2018 at 9:58 AM
    #72
    saybng
    Gary
    Ventura CA
    Are you saying you clay every time you wash?
  13. Sep 10, 2018 at 10:02 AM
    #73
    alpinepro4
    Pat
    No, every other time. Claying is a time suck. But I like my paint to look real nice:thumbsup:
  14. Sep 10, 2018 at 10:28 AM
    #74
    saybng
    Gary
    Ventura CA
    Thank you Steve..just the answer I was looking for..:thumbsup:
  15. Sep 10, 2018 at 10:35 AM
    #75
    War Machine
    War Machine SSEM # 5 3MW
    I don’t have experience with the CG mitt, but I use the Nanoskin mitt pretty regularly. I’ve used it on several makes and colors, with no marring I’ve noticed. A while back, I followed it up with actual clay to see if the mitt had left anything behind, and it hadn’t.
    I would say once or twice a year at most for claying. If you want to decontaminate more often, Iron-X may be an easier and safer option than running clay over the paint so frequently. I always use Iron-X before clay anyway. Makes it a lot easier.
    Skippy and saybng[QUOTED] like this.
  16. Sep 10, 2018 at 10:37 AM
    #76
    War Machine
    Since we’re on the subject, has anyone found a cheaper alternative to Iron-X with equal results? It’s a great product, but it is pretty pricey. I’ve heard of guys using Adams wheel cleaner in place of Iron-X, but haven’t tried it.
  17. Sep 10, 2018 at 10:45 AM
    #77
    Pudge
    CT
    I was just researching detailed image about 5 minutes ago looking for a less expensive iron remover. I didnt hace luck but am also interested
  18. Sep 10, 2018 at 12:46 PM
    #78
    War Machine
    Pudge[QUOTED][OP] likes this.
  19. Sep 10, 2018 at 1:02 PM
    #79
    Pudge
    CT
