Clay bar
Discussion in 'Detailing' started by Pudge, Mar 24, 2018.
  1. Mar 25, 2018 at 3:43 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Ok ill get a gallon.....if u need to lube.....overlube!!!!
  2. Mar 25, 2018 at 4:01 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    @Kwikfish look into carpro hydro2 and/or reload instead of, or in addition to wax. They are easy to apply, long lasting sealants.
    Skippy and SouthBoundSteve like this.
  3. Mar 25, 2018 at 4:11 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Carpro brand?ill look it up.im not at all looking for a show quality truck but want to help keep it looking good when i do wash it,i reqd there are some aoaps for the lighter colored paints too so ill research that more as well....lots to learn and buy it seems...bleh
    Pudge[OP] likes this.
  4. Mar 25, 2018 at 4:16 PM
    Pudge
    CT
    Yes carpro brand. So easy to use and apply. Will save you time of time and effort. It'll do just what you want, keep it looking good when you get around to washing it. Carpro also makes ech2o, which is a nice waterless wash for in between washes or when it's too cold for a hose.
    Skippy and NewImprovedRon like this.
  5. Mar 25, 2018 at 5:17 PM
    Pudge
    CT
    @SouthBoundSteve any ideas about a product called YWax ceramic spray? It has 15% silica, compared to 5% for reload? Would this be considered a ceramic or just treatment for ceramic coating. Seems like maybe application would be tough at such a high percentage. Not much online about it..
    SouthBoundSteve likes this.
  6. Mar 25, 2018 at 5:51 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    So whats the best combo to use?wash and then clay bar then after that i read guys do a sealer then wax?
  7. Mar 25, 2018 at 5:53 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    I honestly just wash and dry lol...but im trying to get a bit more in depth to protect my paint but my time off is very limited as i work 3 different shifts every week and alot of hours and have only 1 day off a week
  8. Mar 25, 2018 at 6:04 PM
    War Machine
    War Machine SSEM # 5 3MW
    Hey brother, just a heads up. I bought a $16.00 foam cannon on Amazon, and it’s worked perfectly. I use it pretty often, and it’s solid. I’m no expert, but I can’t imagine those expensive ones are worth it.
    SouthBoundSteve and Pudge[OP] like this.
  9. Mar 25, 2018 at 6:11 PM
    Pudge
    CT
    Wash using the 2 bucket method, then clay bar, and it's ok that it's wet when you clay, then wash again, next apply a sealant like hydro2 or reload, lastly dry It off with a blower and or microfiber towels. You only need to clay maybe once every year or 2 depending on how rough your paint gets. As far as sealant maybe 2-4 times a year will do, since using hydro2, I no longer wax and I'm fine with that, it takes too long. Then wash as often as you can, maybe consider a drying aid or detail spray such as carpro ech2o or similar for some washes. The beauty of hydro2 is that a wash and hydro2 application will only take about an hour, it's a huge time saver, which I love. I work similar shifts as you do. Look into getting a bottle of aerospace303 for all you interior and exterior plastic, headlights, taillights, running boards, tires.... It's cheap and a great universal product. Again it goes on quick and easy.
  10. Mar 25, 2018 at 6:13 PM
    War Machine
    Check out Optimum No Rinse or Carpro Ech20. You can wash your truck pretty fast and effortlessly with those. You can also use them to make quick detailer.
    I use a foam cannon with Chemical Guys Honeydew foam when I have more time.
    After it’s clean, put your sealer on. Check out Carpro Hydro2. It’s expensive, but it’s a concentrate that will last a long time. That stuff is amazing. Carpro Reload is great also.
    Skippy, SouthBoundSteve and Pudge[OP] like this.
  11. Mar 25, 2018 at 6:20 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Roger that @Pudge,@War Machine ill check into that,ya i found the same foam cannon on Amazon prob lol,watched a YouTube on it and it seems the same as the name brand ones lol
    War Machine and Pudge[OP] like this.
  12. Mar 25, 2018 at 6:25 PM
    Pudge
    CT
    All these new products are so amazing. No more 8 hour days of washing and waxing. And these easy spray on sealants last longer than a wax.
  13. Apr 23, 2018 at 9:53 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I bought a clay bar kit last fall, but haven't had a chance to do my truck yet. I have never used a clay bar before, but after reading the stories of it, I'm looking forward to all of the pollen being gone before long, and really detailing my truck. After the re-wash, it's good to polish, and then wax on top of that?
  14. Apr 23, 2018 at 9:58 AM
    Pudge
    CT
    Id recommend getting carpro hydro2 or reload. These are sealants and very easy to use
  15. Aug 3, 2018 at 6:19 PM
    Borgs
    Borgs New Member
    PA
    I used Griots synthetic clay on my wife’s Subaru tonight. Awesome.
    MotoTundra and Pudge[OP] like this.
  16. Aug 3, 2018 at 6:22 PM
    Pudge
    CT
    Nice, is that the little round pad looking thing? I used a mint and loved it. This detailing stuff is getting simpler every day. I cant imagine I'll ever use a bar of clay on a full vehicle again.
  17. Aug 3, 2018 at 6:42 PM
    Borgs
    Borgs New Member
    PA
    Yeah, it’s round - kind of feels like a rubber pot holder.
    Pudge[QUOTED][OP] likes this.
  18. Aug 3, 2018 at 7:00 PM
    Borgs
    Borgs New Member
    PA
    @SouthBoundSteve - is the synthetic clay too good to be true?
  19. Aug 4, 2018 at 5:42 AM
    #49
    War Machine
    In a test for another member, I used a Nanoskin mitt, and went back over it with clay to see if it picked up anything the mitt left behind. It didn’t at all. I see no reason to ever use real clay again.
    Pudge[OP], Skippy and NewImprovedRon like this.
  20. Aug 4, 2018 at 6:47 AM
    #50
    Borgs
    Borgs New Member
    PA
    It’s a red sponge disk with a black rubber surface. I only got the hood and one door done last night before the rain hit - and it still hasn’t stopped. Hopefully I can get back at it today. I will see if I can snap some comparison pics.
  21. Aug 4, 2018 at 7:07 AM
    #51
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    What lubricant did you use, or would you recommend?
  22. Aug 4, 2018 at 7:12 AM
    #52
    War Machine
    I always just use a detail spray. Whatever I have on hand.
  23. Aug 4, 2018 at 8:47 AM
    #53
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I used the Adams clay mit and it marred the trucks all over the place :mad:
    I had to spend another hour taking those off. Had plenty of lube and truck was out of the sun, still did it. Won’t use it again. Might use Adams new stretchy clay.
  24. Aug 4, 2018 at 9:06 AM
    #54
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I first GooGone'd any visible tar and tree sap off first. For claying, I use Mother's, was on sale at my local CrappyTire, a good wash, detailing spray to lube. Comes with 2 bars and I still have 1.5 left. Roll as you go, throw it out if you drop it or you can't get a fresh surface anymore. After polish and Collinite 845:
  25. Aug 4, 2018 at 6:27 PM
    #55
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Another Canadian here called it Cambodian Tire, never heard that one before:rofl:
  26. Aug 4, 2018 at 6:54 PM
    #56
    Borgs
    Borgs New Member
    PA
    I got all but the passenger doors done on the Subaru. Gotta say, the synthetic clay is pretty dope (that’s a compliment). Did a total detail (compound, polish, wax - all Meguiars) on the finished panels and this 2014 Subaru looks $$$. We bought it new - this is the first time it has seen any product other than a local pressure wash and some simple green on the wheels. Looks new. Need to keep up with it better. My Tundra gets much more attention FYI.
  27. Aug 4, 2018 at 8:02 PM
    #57
    Pudge
    CT
    I lived my clay mitt. Everyone should invest in some form of synthetic clay, it's so easy to use and you wont believe how smooth your paint will be. I've used real clay several times and I really dont see it being any better than synthetic. I still have some for glass and tight areas but it 99% synthetic for me from now on. The mitt takes no time to do the full truck, before it would have been hours
    driverdog and T-Rex266 like this.
  28. Aug 5, 2018 at 12:19 AM
    #58
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Just sprung for the NanoSkin 6" fine pad and Glide spray. Gonna give it a shot.
  29. Aug 6, 2018 at 5:39 PM
    #59
    Borgs
    Borgs New Member
    PA
    Here you go!
    A92ABA8F-418E-4A0E-A5D6-AD1D00A786B0.jpg 97EBFDBE-019D-445D-9FFB-F92DC9F8C03A.jpg 95776B12-420B-4B11-8607-349B548F6D17.jpg
    SouthBoundSteve and MotoTundra like this.
  30. Aug 6, 2018 at 5:47 PM
    #60
    MotoTundra
    MotoTundra The Ocho
    Don
    Alright, so I am using a Meguiars clay bar with Meguair's Quick Detail spray.
    Looks like I should be using a Synthetic clay bar, @Borgs and everyone else, what kind should I pick up?
    Pudge[OP] and SouthBoundSteve like this.
