Clarify gear ratio questions
Discussion in 'Performance and Tuning' started by lsaami, Oct 14, 2018.
  1. Jul 5, 2019 at 11:32 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    The most accurate way to find out is what I did , remove pumpkin from housing and count the number of teeth on gears in ring and pinion . Also should be stamped from factory
