Cheap amazon light bar in hood bulge
Discussion in 'Lighting' started by TRDProLife, Apr 15, 2021.
  1. Oct 12, 2021 at 3:04 PM
    They came with the SDHQ mounts. I'll take pics and do a writeup when I pull the bulge off.
  2. Oct 12, 2021 at 3:29 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  3. Oct 12, 2021 at 4:52 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Curious how your hood bulge light bar is holding up? Anything you would change or do different?
  4. Oct 12, 2021 at 7:29 PM
    TRDProLife
    TRDProLife [OP] LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    It's been great. Wouldn't change a thing.
    Toe404 and Mike59 like this.
  5. Oct 12, 2021 at 8:32 PM
    ErikTRDTUNDRA
    Erik
    I may have to pic one of these up, nice write up.
  6. Oct 13, 2021 at 10:13 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    +1
    I really want a light bar in the bulge. I’m looking to do the front any time cam, hood bulge light bar, and rear window relocation switch all at the same time. Put them all on a 3 switch panel insert on that little credit card holder spot on the center console
    Gonna source all the parts. And door it on my day off
    Jjbernau likes this.
  7. Oct 13, 2021 at 10:28 AM
  8. Oct 13, 2021 at 10:32 AM
  9. Oct 13, 2021 at 10:41 AM
    ErikTRDTUNDRA
    Erik
    Which light are you looking to go with , there looks to be a ton of options. The reviews are all over the map on these. As well are the prices. Seems you can spend $100 or $1000. Seems $1100 for a light bar is a bit excessive IMO
  10. Oct 13, 2021 at 10:41 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I was wondering how you were going to be able to screw into the nutplates then I read this part. I'll stick with zipties and your JB Weld idea.
    TRDFerguson likes this.
  11. Oct 13, 2021 at 11:30 AM
    WonkyDonkey
    WonkyDonkey New Member
    Justin
    2019 Cement Tundra TRD offroad limited
    Bought it with a ARE camper and some factory TRD/Toyota bolt one's, otherwise mostly stock
    Where did you get that switch panel from?
  12. Oct 13, 2021 at 11:41 AM
  13. Oct 13, 2021 at 7:15 PM
    ErikTRDTUNDRA
    Erik
    Ordered my light bar just need a good wiring harness and switch set up, any good suggestions? I am not running any other lights so I don’t need anything fancy just good quality. Appreciate y’all’s feedback
  14. Oct 14, 2021 at 5:02 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    At the moment I’m looking at the 4WDKING light bar.
  15. Oct 14, 2021 at 5:43 PM
    Go for the BD S8 :D:D:D
    Toe404[QUOTED] likes this.
  16. Oct 14, 2021 at 6:28 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    haha at 8 times the cost I’m sure it’s a better product. Just trying to justify it. Although I did buy the ss3 Max fogs just because people said they were as bright as the sun lol
  17. Oct 14, 2021 at 6:36 PM
    Yes, definitely expensive. Most mods are lol.
  18. Oct 14, 2021 at 6:36 PM
    ErikTRDTUNDRA
    Erik
    I ordered mine yesterday
  19. Oct 14, 2021 at 6:42 PM
    #49
    ErikTRDTUNDRA
    Erik
    I watched enough YouTube side by side comparison videos that didn’t justify the extra $800. There’s enough folks on this forum that have also gave it a very positive review.
  20. Oct 14, 2021 at 7:53 PM
    #50
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    Let me know how it looks when you get it
  21. Oct 15, 2021 at 7:58 PM
    #51
    Nonor
    Nonor New Member
    Hey man, I ended up buying the same kit based on your recommendation, I also got a Toyota switch to replace the one that comes with it, but every time I try to turn it in it burns the fuse, do you have any recommendations on the install?
    this is the switch I got LED Light Bar Push Button Switch with Connector Wire Blue Backlit On/Off Kit Compatible with Toyota Tundra Tacoma 4Runner… https://www.amazon.com/dp/B07QLR175B?_encoding=UTF8
  22. Oct 16, 2021 at 12:16 AM
    #52
    Something isn't hooked up right if you are blowing a fuse.
  23. Oct 16, 2021 at 4:31 AM
    #53
    TRDProLife
    St.Louis
    You probably have your switch wired up wrong.
  24. Oct 16, 2021 at 7:46 PM
    #54
    Nonor
    Nonor New Member
    So after checking everything twice and buying a new harness, the problem was the actual bar I took it off the truck and dry fitted the harness and everything worked, as soon as I put it back on the bracket it shorted, the light must have something loose inside and it’s grounding/shorting with the bracket. Sent it back and I’m getting a replacement Monday, I’ll update then.
  25. Oct 19, 2021 at 4:53 PM
    #55
    ErikTRDTUNDRA
    Erik
    Any update ? Pictures? Come on man we’re all waiting
  26. Oct 19, 2021 at 5:06 PM
    #56
    Buy once cry once lol. :stirthepot:
    hi_rawb likes this.
  27. Oct 19, 2021 at 6:33 PM
    #57
    Nonor
    Nonor New Member
    Shiz, I’m also still waiting. Amazon send me a 21” bar replacement!!!! Now scheduled for Friday.
    mav7021234 likes this.
  28. Oct 19, 2021 at 6:36 PM
    #58
    ErikTRDTUNDRA
    Erik
    Just got mine today, I plan on installing this weekend
  29. Oct 19, 2021 at 6:47 PM
    #59
    RobertD
    Robert
    DFW, Texas
    Do you have a link for this light bar? I'm not seeing blue as an option...
  30. Oct 19, 2021 at 6:56 PM
    #60
    ErikTRDTUNDRA
    Erik
    The blue is a protective film, my apologies I should have noted that
