Changed my oil today... discovered this!?
Discussion in 'General Tundra Discussion' started by Tundra_361, Feb 8, 2019.
  1. Feb 8, 2019 at 8:49 PM
    #61
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    You mean being treated like the bone heads treat people in the quick lube, Sean? Don’t be frustrated. You have a trade that you took seriously, learned and worked hard and now you’re a professional. Someone in your line of work should take pride and do the best they can. I’m a Substation Master Tech. Plenty of training and hard work and I also do the best I can every day. Way to many quick lube guys/gals have zero training, get paid very little and could care less about doing their job well. It’s why I try to do as much as I can myself.
    Watt maker and 15whtrd[QUOTED] like this.
  2. Feb 8, 2019 at 8:53 PM
    #62
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    I am going in for my first service this month so I will try the silicone mark check.
    BTBAKER likes this.
  3. Feb 8, 2019 at 8:59 PM
    #63
    Rickard
    Rickard New Member
    Rick
    2012 Tundra 5.7l double cab 4X4
    Costco regularly has 6 qts of Mobil 1 0-20w on sale for $28. Four cases covers three oil changers. Toyota filters are available on Amazon for ~ $5 each if you buy five at a time. I love the Motiv drain tool, but the tool that comes with the filters works well if you use a drink bottle to push it into place.
    Joe Dirt and Watt maker like this.
  4. Feb 8, 2019 at 9:03 PM
    #64
    Tundra_361
    Tundra_361 [OP] New Member
    Victor
    2019 Black 1794 4x4
    That’s sort of a relief. Was thinking worst case scenario was they pull the whole engine. Not going to stress it to much. Could just be a minor flaw in the casting as others have stated. Will follow up on this and let you guys know what I find out. But knowing Toyota they will probably say it’s the “characteristic” of the truck.
    BTBAKER and Watt maker like this.
  5. Feb 8, 2019 at 9:09 PM
    #65
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Since they didn't change your filter the last two times (that you paid for), I'd have them spring for a new Oil filter housing...and put it in.
  6. Feb 8, 2019 at 9:12 PM
    #66
    Tundra_361
    Victor
    2019 Black 1794 4x4
    I didn’t think of using one to push it in :thumbsup: no Costco here.
  7. Feb 8, 2019 at 9:15 PM
    #67
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Right!? Well if it is a defect. I’m sure they will warranty it. Never had problems with management before there.
  8. Feb 8, 2019 at 9:20 PM
    #68
    Rickard
    Rickard New Member
    Rick
    Hmmm, you are in Texas, I doubt that you are more than a three hour drive from a Costco. You probably drive three hours to go to lunch.
    I went to Texas A&M and we would drive to Houston or Austin to get good food. That was a long time ago though.
    Joe Dirt likes this.
  9. Feb 8, 2019 at 9:31 PM
    #69
    Michael Tregre
    Michael Tregre New Member
    '14 Tundra SR5 CM
    Notta
    Since Ive had my Tundra its been to Toyota every 5k miles. The only reason I did so was because the previous owner had his service records. every 5k miles w/Toyota.
    I do however ask for the old filter to be bagged and the packing of the new filter left in the bed of my truck. Its a bit of piece of mind.
    NOW, my dealer did toss my K&N air filter, the air box has the "STOP" sticker on it and all. When confronted, they just gave me a $100 service voucher.
    Watt maker likes this.
  10. Feb 8, 2019 at 9:53 PM
    #70
    gs1197tx
    gs1197tx New Member
    TX
    Just playing devils advocate here:
    Without some kind of special identifier, you have no way of knowing for certain that filter was removed from your truck....or 1 they found in the garbage can behind the local spiffy lube.
    That said, I don't believe for a minute a dealership would risk their reputation by pulling some shady sh1t like that.
    Spiffy lube on the other hand.....
    Since most, if not all, service centers and dealerships don't allow John Q. Public to stand there and watch them work on your vehicle, the only absotively posilutely way to know it was changed....do it yourself.
  11. Feb 9, 2019 at 8:27 AM
    #71
    GrillCheesemo
    GrillCheesemo New Member
    Hybrid Camry
    I wouldnt worry about bottom of oil filter cup. If u see metal shavings in filter itself then u can worry. If filter wasnt changed it wouldve been darker. They get black when u dont change them. Ur filter and housing look good. I always run a lil xtra oil too. Like a 1/4 qt or half qt. Most dealers will always do a good job on oil changes. Gets pricey but really is best place to take ur truck.
    Tundra_361[OP] likes this.
  12. Feb 9, 2019 at 8:42 AM
    #72
    1999cutiger
    1999cutiger Top Flow Lifestyle
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels General Grabber ATX 275/60/20
    It’s very likely your filter was not changed.
    There is only one way to ensure it's done correctly every time. Unfortunately, nobody gives a shit about your truck...including the dealer.
    The average Joe is way too trusting. I don’t trust anybody.
    Do. It. Yourself.
  13. Feb 9, 2019 at 3:21 PM
    #73
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Right there ^^^. That's it.
    What was the famous P.T. Barnum quote?
    Trooper2 likes this.
  14. Feb 9, 2019 at 3:35 PM
    #74
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    For peace of mind, send an oil sample to Blackstone Labs for an analysis. They will send you free sample containers, and you send them oil with a $35 check. My first analysis at 2K miles showed a high amount of silicone in the oil. Must be the silicone that was supposed to seal my cam towers. LOL!! Seriously, it’s not a bad idea to get a baseline of what’s going on in terms of wear inside that motor.
  15. Feb 9, 2019 at 3:50 PM
    #75
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Having worked in a dealership, I would be really surprised if they were not changing oil filters. I bet you have a similar looking material around your fill cap. I do. Never really bothered to spray out the inside of the filter cap myself. Mine may look the exact same.
    Honestly I wouldn’t worry about it.
  16. Feb 12, 2019 at 9:58 PM
    #76
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Looks super clean! Can’t belive how dirty mine was. smh! Hopefully it isn’t that dirty innext oil change. If it is I’d think something is wrong.
  17. Feb 13, 2019 at 6:31 AM
    #77
    Tundra_361
    Victor
    2019 Black 1794 4x4
    If it is, I’ll be doing that.
  18. Feb 13, 2019 at 6:41 AM
    #78
    Tundra_361
    Victor
    2019 Black 1794 4x4
    I did use Lucas gas treatment/injector cleaner. I wouldn’t think it’s from that though.
