Center console safe
Discussion in '2.5 Gen Tundras (2014-2021)' started by Boss hog, Oct 17, 2020.
  1. Jan 9, 2021 at 8:15 AM
    #211
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I keep thinking it wouldn’t be too hard to make with a little wood and maybe some aluminum flat bar for the two side rails to hold it up. I have not seen any in this shape/configuration that weren’t sold with the safe.
  2. Jan 9, 2021 at 9:30 AM
    #212
    TelemarkTumalo
    TelemarkTumalo New Member
    Mark
    Bend, OR
    2020 Tundra TRD Pro Double Cab Army Green
    Driver side grab handle Door sill protectors Falken WildPeak 295/70 R18 X-Pel clear front paint protection 20% front window tint Go Rhino RB20 side steps - Bedliner finish Lock'er Down 1/2 console safe Toyota bed cargo divider Toyota auto tail gate lock
    I'm going to see if I can find one and modify if possible. I was thinking doing one from scratch would be a great application for 3D printing, but that would be beyond my pay grade. The folks at Lock'er Down were not aware of anybody making one either.
    Hightide likes this.
  3. Jan 9, 2021 at 10:32 AM
    #213
    RainMan_PNW
    Casey
    Clark County, WA
    My fear with 3DP one (i thought the same thing) is that the axis of strength may not be good along the lips... but that does also depend on the print material too. The other challenge is finding a machine with adequate bed size for that tray unless you do it as two pieces.
    Your safe is the Lock’er Down one, right? Do you have exact dimensions on the opening that the tray would fit into?
  4. Jan 9, 2021 at 10:45 AM
    #214
    TelemarkTumalo
    Mark
    Bend, OR
    14 3/16" x 5 1/2". The Amazon safes have a metal frame that the tray rests on. Mine does not. So, anything riding on the top ledge would have to be thin material to avoid blocking the console lid. My other thought was to find one of the Amazon safe trays (sorry, I don't know what else to call these safes) and then fasten some braces for the tray to ride in. Probably just one in the front and one in the rear.
  5. Jan 9, 2021 at 11:19 AM
    #215
    RainMan_PNW
    Casey
    Clark County, WA
    I just took a look at the pictures of the Locker Down half-safe. I think you’re gonna have trouble with any of these trays because there’s no rim around the open side of the console for you to rest the tray on.
    If it were me, I’d make a long rail out of some 1/4x3/4 or so aluminum flat bar and then drill/tap it into the side of the safe down maybe 1” from the top using the short #6-32 machine screws (or drill through and attach with lock nuts or chicago screws - lots of options). On the drivers side of the open space on the console wall, I’d run another rail and probably just pop rivet it in place, level with the one on the safe wall.
    Then I’d use some 1/4 baltic birch plywood to make a tray with whatever dividers I wanted. Or go hardcore and do it with a piece of 5/4 hardwoord, a template, and a pattern bowl bit and router out the tray spots. Paint it all black if you want when you’re done.
    hope that all makes sense. I’ve got a wood shop, and do a bit of making custom jigs with aluminum and baltic birch so that’s why i lean in the direction I’m describing.
  6. Jan 10, 2021 at 10:26 AM
    #216
    Awac146
    Awac146 New Member
    Westfield IN
    2020 CM Platinum
    Anyone find a solution to the half safe without perimeter frame?
  7. Jan 10, 2021 at 12:15 PM
    #217
    TRDSnowInTX
    TRDSnowInTX New Member
    Ryan
    2021 Super White Tundra TRD Pro
    I am looking for this same solution. I have picked up a few trays off of Amazon based on the measurements of the open area but none seem to be a good solution yet. It may end up being a completely custom job.
    KingsAustin likes this.
  8. Jan 10, 2021 at 12:41 PM
    #218
    RainMan_PNW
    Casey
    Clark County, WA
    I don’t have that particular model (I’ve got the Amazon special that came with a tray), but based on what I’m seeing it looks like best bet is going to be attaching a rail to the side of the safe box and another to the side of the console and making a custom one out of wood, acrylic, or sheet metal.
  9. Jan 10, 2021 at 12:53 PM
    #219
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Yup. My design concept has a couple of rails that will be printed up to create that ridge needed. We'll see how it turns out. I have spoken to the 3d printer a couple of times to plan it out.
  10. Jan 10, 2021 at 8:43 PM
    #220
    RainMan_PNW
    Casey
    Clark County, WA
  11. Jan 11, 2021 at 10:24 AM
    #221
    KingsAustin
    Morgan County, AL
    RainMan_PNW[QUOTED] likes this.
  12. Jan 11, 2021 at 12:58 PM
    #222
    KingsAustin
    Morgan County, AL
    Here is my layout with the modified OCD product. Don't mind the mags usually empty.
    TelemarkTumalo likes this.
  13. Jan 11, 2021 at 3:43 PM
    #223
    RainMan_PNW
    Casey
    Clark County, WA
    I think it was your pictures I saw somewhere of the OCD that got me started on the setup I did. I was worried about the OCD unit being a bit "wobbly" and wasn't entirely excited about the layout of the space when split by the OCD. I may revisit mine with another divider running front/rear in the big section, but for now it's much better than what I had.
  14. Jan 11, 2021 at 5:16 PM
    #224
    KingsAustin
    Morgan County, AL
    There are a couple of dividers that are a bit loose, but those that look crooked are actually tight. I didn't feel like trying to sand them down some more for fear that it would end up loose. It fits my current needs and actually, I do not see me changing them out. I am hoping my tray design will fit perfectly once it is completed. Thanks.
    RainMan_PNW and TelemarkTumalo like this.
  15. May 20, 2021 at 12:52 PM
    #225
    TxGnRnr
    TxGnRnr New Member
    2021 Silver 1794
    Peragon Cover, AMP Bedstep, OPT7 LED Bar, Yaesu FTM400XDR, Wouxun KG-1000G
    I purchased one of the cheap Chinese safes off Amazon (bent corner and all). Does anyone have a way to keep the lid open? Once installed, the center console armrest pushes the lid forward just enough that the safe lid wants to fall closed. Thanks.
  16. May 20, 2021 at 1:04 PM
    #226
    TXTundra2722
    2015 Black Tundra
    Just came across this thread and was wondering why you'd need to rack the slide, you don't keep one in the chamber? I'm always interested in why people don't keep a round chambered.
  17. May 20, 2021 at 6:59 PM
    #227
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    No safety on edc.
    Child with autism.
    Some training involves carrying without having one in the chamber.
    It’s actually fairly common.
    Personal choice.
    bulldog93 likes this.
  18. May 20, 2021 at 7:36 PM
    #228
    TXTundra2722
    2015 Black Tundra
    I think in the end... it is just personal choice, because if its in a safe then that negates the issue with the child. I haven't had a pistol with a selectable safe in almost 15 years and I carry everyday (yes on my person). No, not that I'm better, but it's a training issue, but if it makes you feel comfortable then that's what matters.... at least you carry! If you've never played the 21 foot rule... what I'll call "game". You'll never draw your pistol, chamber and round and fire before being stabbed. While getting off the "X" is the most important part.... along with drawing your firearm....multitasking in a high stress environment opens the door for all sorts of issues..... but I'll get off my soap box... I'm always curious of the "why" when I come across this. I do have one more question... name one profession that carries a gun on duty/ while working and doesn't have a round chambered.
    :crapstorm:
  19. May 20, 2021 at 7:43 PM
    #229
    Hightide
    Abalama
    Magic School Bus
    The safe is not locked when traveling.
    That would negate the purpose of carrying while traveling.
    That does not protect the child.
    If I have to unlock the safe while in the vehicle, chambered or not doesn’t matter.
    I’ve been carrying for over 30 years, have had countless classes, training and practice.
    I’ve served in the military and was an MP.
    I completely understand the 21’ rule and drawing.
    Thanks for your feedback, but yes, it’s a personalized preference.
    P.S. If you can’t draw and chamber a weapon within the time limit you’ve described, you’re not practicing enough.
  20. May 20, 2021 at 7:54 PM
    #230
    TXTundra2722
    2015 Black Tundra
    I gotcha... yeah.... when I say carry....I mean on my person. I was infantry before becoming a Leo and going SWAT.... I'm quite clear on the "to carry loaded or not debate" and can guarantee that in my line of work, you won't find one person that doesn't carry hot. I'm not going to say it's not a time issue... we've done the drill several times and most of us have two rounds on target before the other can chamber a round, the issue is when there is legit stress added. And this is in a low stress environment where the only stress is beating your buddy. Add in real life and death and the issue is even more pronounced. While I do appreciate your service...I have to give you a hard time still.
    :oldglory:
    Hightide[QUOTED] likes this.
  21. May 20, 2021 at 8:34 PM
    #231
    pnw tall trees
    pnw tall trees New Member
    Pacific Northwest
    07 Limited Crewmax
    Carrying with a round chambered, or not, or with the piece locked in a safe, or not, seems to be the issues that really get guys drawing lines in the sand. I read an article a couple years ago from an old-timer enthusiast. Really enjoyed his wisdom and down-to-earth common sense. On these questions he was Switzerland. It depends on the individual. It depends on the risk. It depends on the circumstances. It depends on the comfort level. It depends on the ramifications of a mistake.
    These are not static questions unless you are at defcon 1 all day every day. Most people living normal lives aren’t in that scenario. Adjustments are necessary and a good thing.
    So, for example, when I go to the big box store, or mall, or other mass collection of humanity, I view that as a high risk environment and adjust accordingly. Everything. What I carry, how I carry, my situational awareness, etc.
    On the other hand, when I go to a company picnic, everything is more relaxed. I probably wouldn’t carry chambered in those circumstances (or carry at all) because I calculate the risk to be much lower than the catastrophic result of any mistake. Could I be caught off-guard? Sure. But I don’t want to live my life in a constant state of readiness for armageddon in every single situation.
    So I think the lesson I took from the wise old-timer, was this: do what works for you. Be thoughtful. Be prepared. Be safe, and be well-trained with your equipment.
    Your mileage may vary, but we’re all doing our best and what we think works for us under our individual circumstances.
    Uhhhh.... and Hightide like this.
  22. Oct 9, 2021 at 8:26 PM
    #232
    TRD PRO 17
    TRD PRO 17 New Member
    Tyler
    2015 Inferno Crewmax TRD PRO
    Sooo… did anyone ever figure out where this goes?!
  23. Oct 9, 2021 at 9:47 PM
    #233
    RainMan_PNW
    Casey
    Clark County, WA
    Nope - just tossed it
  24. Oct 9, 2021 at 9:56 PM
    #234
    Hightide
    Abalama
    Magic School Bus
    I think it’s to protect that bent corner everyone likes.
    TRD PRO 17[QUOTED] likes this.
  25. Mar 24, 2023 at 5:48 PM
    #235
    cjscinta
    cjscinta New Member
    Nashville TN
    I just bought one of these second hand with no instructions so I am trying to remove the rails from the console tray and I can’t figure what type of screw head they are. Does anyone have any idea? Torx, Phillips, etc. none seem to fit. Thanks. 95D41D91-A5E5-43FC-B7D1-0D31F4792B23.jpg
  26. Mar 24, 2023 at 6:11 PM
    #236
    If I recall, those are rivets.
    Ruggybuggy and Randy Morton like this.
  27. Mar 24, 2023 at 7:17 PM
    #237
    cjscinta
    cjscinta New Member
    Nashville TN
    So just pop them out with a screwdriver or something? I’m not real confident in my ability to keep this install clean if that is the case. Haha.
    TaquitoBandito likes this.
  28. Mar 24, 2023 at 7:31 PM
    #238
    TaquitoBandito
    Joel (AKA Bif)
    Tundra234 likes this.
  29. Mar 24, 2023 at 8:31 PM
    #239
    cjscinta
    cjscinta New Member
    Nashville TN
  30. Apr 2, 2023 at 3:34 PM
    #240
    eagleguy
    eagleguy New Member
    I just installed the Tuffy #323 full safe with Combo lock #082. Everything fit like a glove and I retained my top tray and most of the whole console interior!
    TaquitoBandito and TundraPJ like this.
