Catalytic Converter Stolen
Discussion in '2.5 Gen Tundras (2014-2021)' started by aRabidLunatic, May 7, 2022.
  1. Jul 16, 2022 at 9:18 PM
    #421
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Wednesday it is then! I hope your dealership is parking it inside until Wednesday. I would hate for it to get hit again! That would suck!
  2. Jul 16, 2022 at 9:28 PM
    #422
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Is it parked behind a locked gate..
    At first, they said they started the truck every 2 to 3 weeks.
    I didn't believe them so I'd go up there once a month and do visitation...:D
    Sure enough, the truck was parked in a different spot every time I checked on it..
    I'm either going to take a long drive and run that old gas out or fill it up with premium.
    I think the tank is about half full.
    I went up there in March and put a can of Seafoam in it, didn't think it would hurt.
    I would have put a fuel stabilizer in the tank when I took it in back in November if I'd had ANY inclination it would be there for 8 months..:confused:
    They told me 6 to 8 weeks when I dropped it off, and it has been 34 weeks....:eek2:
  3. Jul 16, 2022 at 9:49 PM
    #423
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m confident that a Tundra will happily burn whatever gas is in the tank. Running it to “zero miles range” low before filling it up is exactly what I’d do as well.
    1lowlife[QUOTED] likes this.
  4. Jul 16, 2022 at 9:52 PM
    #424
    1lowlife
    DADA
    2014 MGM DC SR5
    There were comments about the gasoline turning into varnish if sitting too long a few months ago.
    No idea if that has any merit.:confused:
    I asked my service guy and of course, he didn't seem too concerned with it..
  5. Jul 16, 2022 at 10:16 PM
    #425
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    I wouldn't worry about two months. I have vehicles that sit for up to six months with the same gas and have never had any problems.
  6. Jul 16, 2022 at 10:28 PM
    #426
    WBW
    WBW Resident lurker
    Bruce
    It'll be just fine. The risk is water separation when stored too long. Simply fill the tank right away then drive that tank as low as you dare before the next fillup. I have seven vehicles and some are stored guide some long times. Fuel has never given me issues. Batteries and tires would be what causes issues and my attention.
  7. Jul 16, 2022 at 10:32 PM
    #427
    1lowlife
    DADA
    2014 MGM DC SR5
    Thank y'all for the fuel reassurance.
    Dealer is giving me a new OEM battery, I told them I want my Interstate back as well.
    Kinda concerned about the tires too, they were only a year old..
    They are putting on a new OEM muffler since my 10" BAM got cut.
    Going to send it back to @dirtydeeds and have Keith make me a 12".
  8. Jul 16, 2022 at 11:10 PM
    #428
    WBW
    WBW Resident lurker
    Bruce
    Your tires may have flat spots from being parked so long. Ask the dealer to inflate them to maximum sidewall pressure and drive it to the gas station for fuel. Drive it at max pressure for a week. The ride will be rougher than you are used to but it will help the carcass return to its original shape quicker. After that week you can return to your normal pressures. Your tires will be perfectly fine. The rubber is still young. That's good.
    Look at your rotors to see how much surface rust is on them. If they are a slight rust color you'll be ok with normal driving. On the other hand, if the surface rust is heavy simply apply a little brake pressure at speed for a few seconds at a time to allow your brake pads to scrub them back down to fresh metal.
    Do a quick visual on all fluids kind of like your pretrip. Frankly, I'm not concerned about it being parked for eight months. Just some normal checks so you can head off problems should they arise.
  9. Jul 17, 2022 at 4:47 AM
    #429
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Best of luck with your test/back issue and, of course, getting your plates on.
  10. Jul 17, 2022 at 7:50 AM
    #430
    1lowlife
    DADA
    2014 MGM DC SR5
    Thank you.
    The plates are going on, no doubt about that.
    WBW likes this.
  11. Jul 17, 2022 at 11:12 AM
    #431
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    O & A was my favorite, followed them right up to Ant's firing. I never signed up for the compound, even though they weren't friends, the show dynamic was great and it worked ! The cast of comedians added to the hilarity, not to mention Martini Steve, Bobo, Steve from Yellowstone, Patrice ... Man what a run they had.... On road trips to Florida, I'd listen to the am show from 6 to 10 and then listen to the replay after Ron & Fez . Couldn't get enough of them two.
  12. Jul 17, 2022 at 12:58 PM
    #432
    Big Papi
    Big Papi New Member
    Massachusetts
    2021 Tundra TRD Pro Black
    Well for peace of mind my next purchase will have to be some type of shield. What's the opinion on steel vs aluminum?
  13. Jul 17, 2022 at 1:28 PM
    #433
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Steel is heavy. My payload might go negative with nothing else in the truck.
    Retired...finally and AggiePhil like this.
  14. Jul 17, 2022 at 2:53 PM
    #434
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Just got word that my local dealership had 2 Tundra's on the lot 1 was sold and needed to be prepped the other was not sold. Wednesday night the cats got cut out of the only 2 Tundra's on the lot. The A Holes tore up the one that was sold, cut out wires and gas line. Mine is due any day now and today I purchased a plate.
  15. Jul 17, 2022 at 3:57 PM
    #435
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    Hopefully my cats will be in soon based on what I have read. Just placed an order for my cat plates, security bolts and bolt head protectors..... F'n A_HOLES!!!!
  16. Jul 17, 2022 at 6:13 PM
    #436
    aRabidLunatic
    aRabidLunatic [OP] Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    I took my truck home to avoid all of this. I keep it parked in the garage and evey couple of weeks drive on the back roads.
  17. Jul 18, 2022 at 6:01 AM
    #437
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I live in the midwest where once the salt goes down on the road for the winter its pretty much there until spring. For that reason I went with the 1/4 inch aluminum and had it powder coated in an aluminum color along with my RCI front skid (bought before vahalla had a aluminum front skid option). Steel is better if you are wheeling seriously over rocks as it should technically hold up a little better to bumps and slide off rocks better. Just depends on your usage. I don't do much more than some logging roads up in northern Wisconsin and some job sites here where I live. That being said, these 1/4 aluminum plates are strong and I'm sure they would take some abuse.
    Big Papi[QUOTED] and AggiePhil like this.
  18. Jul 18, 2022 at 7:08 AM
    #438
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I went with aluminum for the lighter weight.
  19. Jul 20, 2022 at 7:50 AM
    #439
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    I bought the Valhalla cat shields and security bolts. The od of the bolt head key is 1.12. Were is everyone finding bolt head protectors that big?
  20. Jul 20, 2022 at 7:55 AM
    #440
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
  21. Jul 20, 2022 at 8:19 AM
    #441
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    The barnes aren't coated so they will rust, the ones from RockHard4x4 are powder coated to help prevent that
    https://www.rockhard4x4.com/product_p/rh-6000-sw-400.htm
    NewImprovedRon likes this.
  22. Jul 20, 2022 at 10:35 AM
    #442
    dkrou
    dkrou New Member
    dan
    2019 tundra
  23. Jul 20, 2022 at 10:39 AM
    #443
    Gaston
    Gaston New Member
    Gary
    SE MI
    I used them when installing my plates, they look/work great
    WBW likes this.
  24. Jul 20, 2022 at 11:17 AM
    #444
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I was killing time doing a Build/Price for a Tacoma and noticed that Toyota is offering a Cat Shield Accessory :rofl:
    Double that price for the Tundra Cat Shield.
  25. Jul 20, 2022 at 12:07 PM
    #445
    Gaston
    Gaston New Member
    Gary
    SE MI
    They only cover the front, but I do like the bolts used to secure the plate.
  26. Jul 20, 2022 at 4:14 PM
    #446
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    They have a "rear wing add-on" that protects "all four cats":thumbsup:
  27. Jul 21, 2022 at 5:39 AM
    #447
    Gaston
    Gaston New Member
    Gary
    SE MI
    Ah, I see it now, very similar to the Cat Security Cat Shields
  28. Jul 21, 2022 at 6:46 AM
    #448
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I got my tracking info from Tyler for my front and rear plates! I'm stoked! Comes in Monday 25th and I leave on vacation with the truck Wednesday 27th so I'll have to get these thrown on soon! Does Valhalla sell the security bolts too or is there another vendor folks are using?!
  29. Jul 21, 2022 at 6:55 AM
    #449
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Where was your truck when they took your cats?
    Mike59 likes this.
  30. Jul 21, 2022 at 7:08 AM
    #450
    Gaston
    Gaston New Member
    Gary
    SE MI
    Tyler does sell them, included in the purchase is the socket but you can also purchase an extra if you'd like
    https://valhallasshields.com/shop/ols/products/pentagon-security-bolts-for-rear-cat-plate-4
    I purchased the "TRD PRO 8" set because I was using the Nut Plate that he also sells
    Others have used SCREWD security bolts
    https://screwdsecurity.com/
    McMaster also sells the Pentagon bolts that Tyler sells
    https://www.mcmaster.com/screws/pentagon-head-screws/
    HulkSmurf14[QUOTED] likes this.
