Catalytic converter skid plates & theft deterrent
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cat3ILS, Jan 7, 2017.
  1. Mar 30, 2021 at 2:59 PM
    #661
  2. Mar 30, 2021 at 3:23 PM
    #662
    biebs96
    PA
    @Classy63 im in for decals. What do they look like?
  3. Mar 30, 2021 at 3:24 PM
    #663
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Like this!
  4. Mar 31, 2021 at 7:15 AM
    #664
    vnatrundra
    vnatrundra New Member
    How to place an order. Do you've a website?
  5. Mar 31, 2021 at 7:18 AM
    #665
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Badass Tyler! Feel free to send me one!
    Classy63[QUOTED] likes this.
  6. Mar 31, 2021 at 7:21 AM
    #666
    Classy63 likes this.
  7. Mar 31, 2021 at 8:30 AM
    #667
    vnatrundra
    For 2 wheel drive I need to order this Transmission/front cat plate and 4 wheel drive I need this Transfer case/rear cat plate as well?
  8. Mar 31, 2021 at 8:36 AM
    #668
    The front plate will cover the front cats and the pipe going into the rear cats. The rear cats would still be exposed to show that cat itself and the rear pipe coming out of it. The rear plate is added extra protection to cover the rear cats and make the area harder to access. Bpth plates are for 2 or 4wd.
    yoshi82, RRR1C0 and JoshuaA like this.
  9. Mar 31, 2021 at 8:48 AM
    #669
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Decals??? Where??
  10. Mar 31, 2021 at 9:08 AM
    #670
    Classy63
    Tyler
    Cypress Texas
    I had a short run of decals made, I need to make a bigger batch, I could sell them here or on my website for like $5
  11. Mar 31, 2021 at 9:30 AM
    #671
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    What kind of corrosion would happen with the bare steel, would it be advised to powder coat steel or go straight to aluminum in the northern states?
  12. Mar 31, 2021 at 10:35 AM
    #672
    Classy63
    Tyler
    Cypress Texas
    There is no easy answer here, but it is why I offer aluminum. Those in the rust belt and those who spend a lot of time on salty beaches, would likely want aluminum
    JoshuaA[QUOTED] likes this.
  13. Mar 31, 2021 at 11:00 AM
    #673
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    For $50 bucks get the aluminum over the powder coated steel. Power coated steel without shipping is $500, Aluminum is $550 if picked up locally for both if I am interpreting the website correctly.
  14. Mar 31, 2021 at 11:03 AM
    #674
    Aluminum would be fine unless you are in a high cat theft area. They could cut through it easily if they stay around long enough.
    AggiePhil and JoshuaA like this.
  15. Mar 31, 2021 at 11:42 AM
    #675
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    hopefully they would use a regular grinding disc and it would plug with aluminum and explode the disc.
    GODZILLA and Bammer like this.
  16. Mar 31, 2021 at 7:19 PM
    #676
    vnatrundra
    I am not using my truck for offroad or anything like that so I don't need the 3/16 skid plate. Do you think 1/8 plate thickness is sufficient? I think that they can use the grinding disc to cut through the 1/8 plates easily and quickly.
  17. Mar 31, 2021 at 8:26 PM
    #677
    Most are smash and grab so they won't stick around long. They will see the plates and keep moving. Some of us changed to true security bolts as well. 1/8 steel is sufficient.
  18. Mar 31, 2021 at 9:52 PM
    #678
    Puppypunter
    Puppypunter New Member
    Johnny
    Denver, CO
    2019 Tacoma
    I like the look of those plates! Any chance there is a Tacoma version in the works?
  19. Apr 1, 2021 at 5:04 AM
    #679
    Classy63
    Tyler
    Cypress Texas
    Once I get my feet on the ground, yes Tacoma and 4Runner will be coming
    GODZILLA likes this.
  20. Apr 1, 2021 at 5:59 AM
    #680
    vnatrundra
    Do you know where to buy the security bolts? Do you have specific size/type you can recommend? I am still waiting for my plates so I want to buy it ahead of time before my plates are ready.
    kingsxjt likes this.
  21. Apr 1, 2021 at 6:07 AM
    #681
    Puppypunter
    Johnny
    Denver, CO
    2019 Tacoma
    Nice. I’ll be keeping an eye out. You do good work it looks like :)
  22. Apr 1, 2021 at 7:59 AM
    #682
    I have these. They are out of stock currently but you can use 1.5 or 2 inch for the front plate. The rear plate would need 4 inch.
    https://screwdsecurity.com/collecti...screwd®-machine-screws?variant=32004809097325
  23. Apr 2, 2021 at 10:20 AM
    #683
    tundrasOO
    tundrasOO New Member
    After reviewing camera footage, when they stole the passenger side and were almost done with the drivers side with the last cut half-way, it took them more than 4 mins. I ordered from Tyler and received both 1/4" aluminium plates. I ordered aluminum since where I currently live , they salt the streets. I am worried though about motivated thieves cutting through aluminum with a good blade. My first choice would have been stainless steel and after finding one out there, they were discontinued. Can anyone confirm how easy it is to cut through 1/4" aluminum plate?
  24. Apr 2, 2021 at 10:49 AM
    #684
    With a good blade and sawzall, it wouldn't be that hard. The plates are designed to be a deterrent and most thieves would hopefully move on. Are they raw aluminum?....I would coat them black so it doesn't give it away at first sight of being aluminum....:notsure:
    I went with steel on mine. I wasn't worried about weight...truck didn't even notice it.
    AggiePhil and RitcheyRch like this.
  25. Apr 2, 2021 at 11:07 AM
    #685
    tundrasOO
    They are raw and good idea on the paint. Yeah, I wasn't worried about the weight, just the rust.
  26. Apr 2, 2021 at 11:54 AM
    #686
    Classy63
    Tyler
    Cypress Texas
    The paint is a good idea, there is a mix of steel and aluminum in this picture, but you would never know the difference looking at it.
    1/4 aluminum would be noisy as hell cutting, I don’t think a sawzall would cut through it like butter, I did a test on 3/16 aluminum, and I cut through it, but it wasn’t super quick.
    yoshi82, DaddyPete and Jim LE 1301 like this.
  27. Apr 2, 2021 at 12:02 PM
    #687
    Thanks for the input...I forgot about the noise. I should have remembered that as I was just recently cutting an aluminum stick to make a mount for my train horns.
  28. Apr 2, 2021 at 7:42 PM
    #688
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    I picked up my Shields from classy63 on Wednesday afternoon. He’s definitely a Great guy and making a Great product. After seeing how the Shields mount I can say it’s a Great design and will worth the cost compared to new Cats.
    I painted them with two coats of self etching primer and three coats Ristoluimn Hammered metal gloss, not my best work but will work. He was out of mounting hardware so I’m going back on Monday or Tuesday to mount them up with his help.
    AggiePhil and Classy63 like this.
  29. Apr 2, 2021 at 7:43 PM
    #689
    Classy63
    Tyler
    Cypress Texas
    I have the hardware now
    Patch999 likes this.
  30. Apr 2, 2021 at 7:48 PM
    #690
    kittyhawk
    Dave
    Great!!! I’ll give you a call Sunday to set up a time to get them mounted. Have a great weekend!
