Catalytic converter skid plates & theft deterrent
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cat3ILS, Jan 7, 2017.
  1. Mar 4, 2021 at 8:40 AM
    #451
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    It might be prudent to reach out to the staff and check up on Vendor status...
    RLHULK, TaquitoBandito and Classy63 like this.
  2. Mar 4, 2021 at 9:12 AM
    #452
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Yea I will be picking mine up locally, can't wait. It's nice that it works with my 6" Pro Comp lift. Thank You
    Classy63[QUOTED] likes this.
  3. Mar 4, 2021 at 9:36 AM
    #453
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    It is a simple plate to adapt. The procomp and ready lift almost all use the same thing so I made a plate for it, I can make them for the rough country lifts, but that adapter gets weird. BDS cuts too much away and leaves me nothing to bolt a plate too
  4. Mar 4, 2021 at 10:09 AM
    #454
    TaquitoBandito
    Joel (AKA Bif)
    I'm waffling a lot on installing the DE plate. The bolt seizing really threw me for a loop. I had threaded it by hand and it wasn't even close to being tightened. Still waiting to hear back from the Service guy at Don McGill which doesn't make me too happy. Carlos in the parts department said it's the same price to install ($78) whether it's a pro or not and said the service department does it. Service department told my wife that they don't do it, Make Ready does. He was supposed to doublecheck the price last night and we're still waiting to hear back. Our dealer in Austin, Charles Maund, said they've installed plates under the Prius (apparently they are the gold standard in cat value) but never for a Tundra. Said it'd probably be anywhere from $100 to $300 to install, depending on how long it takes them.
    But again, I'm worried about putting the plate on there and then something happening where it needs to be removed to get to whatever needs to be fixed and the bolts seizing up. Somebody earlier in this thread said using stainless could cause a reaction blah, blah, I don't understand but they could fuze or something. @crewmaxlmt said something similar. So the easy solution would be swapping out the bolts.
    But then there's the install with the TRD skid plate (which many of you Tundra ninjas were able to do). I hate to pay somebody to do it and then get dinged later on because if I have to pay extra as some kind of covered maintenance was required on my Tundra and the plate removal wasn't covered.
    At the same time, I'm tempted to call a buddy who can cut a hole in the plate to make it easier to get to the top of the crossmember the skid plate is attached to... Or maybe I should just take the loss.
    I'm probably thinking too much. The only plus I have going for me is that I have a zillion cameras outside. If they try to take mine, they'll probably get caught.
  5. Mar 4, 2021 at 10:12 AM
    #455
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Is there an issue with the skid plate on a SR5 TRD package, NOT a TRD skid plate? I am going to be traveling south this summer and want to have piece of mind when I'm in my hotel room.
    TaquitoBandito likes this.
  6. Mar 4, 2021 at 10:35 AM
    #456
    You shouldn't have any issues installing the DE skid.
  7. Mar 4, 2021 at 10:37 AM
    #457
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    If I remember correctly, the stock skid plate does not go all the way to the crossmember like the TRD Pro skid does. You will just mount the DE skid using the 4 mount points and there should be no issues and nothing to modify.
    LA184, RLHULK, Bammer[QUOTED] and 2 others like this.
  8. Mar 4, 2021 at 1:24 PM
    #458
    RainMan_PNW
    Casey
    Clark County, WA
    Wowser Joel - you are over thinking it. That's ok though - we all do that from time to time, and having a bolt cause issues doesn't help.
    On the stainless bolts - there's two things to consider.
    One is that dissimilar metals (such as the stainless in contact with bare aluminum) can cause galvanic corrosion where the differences in electrical "potential" of the two metals causes them to react and transfer metal from one object to the other. This is really only a serious problem in situations where other factors like constant moisture or presence of ionic catalysts (think salt or similar materials) - essentially it is the process of electroplating, only done when you don't want it to happen. It's a common problem in piping systems, but in this case I'd have a hard time expecting it to really present a problem.
    The other is that threaded stainless steel has a tendency to gall when the metal is tightened and the mating surfaces pass over each other at the faces of the threads. It's actually an issue with the microscopic structure of the surface of the metal and the concentrated stress that is present where the two surfaces of the male and female thread pass over each other. Think of it like trying to force two pieces of 60-grit sandpaper to slide over each other. The metal will catch and tear, which then creates more friction and effectively the two surfaces bond together. The solution here is to use a thread lubricant that will fill in the microscopic pits/gaps and keep the surfaces from galling on each other. "Never-Seez" and other brands are out there - and different formulas are used for different applications (such as what metals are being joined, or what temperature/conditions the joint is being used in, etc.). It just takes a little to coat the threads before making the joint up, and that will improve your chances by 1000% that you can easily break that joint free later. It DOES, however, change the amount of torque needed to correctly tighten a joint (reduces it dramatically), so if you use never-seez on a bolt, never torque it to the published torque values unless that torque value is listed as being a "lubricated" torque value.
    Hope that makes sense...
    If it were me, I'd bust the rest of those bolts off your TRD skit plate, figure out what new hardware you need, and get to putting the new one (and the DE skid) back on! You're probably looking at <$20 in new bolts and a small tube of neverseez, and you'll be good to go.
  9. Mar 4, 2021 at 1:43 PM
    #459
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    correct, if you have the stock skid plate, just bolt on the DE plate.
  10. Mar 4, 2021 at 2:32 PM
    #460
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Just use a grade 2 or 5 bolt and you won't need the anti seize. Stainless bolts have their place, on boats and in clean rooms.
    Stainless bolt tensile - 75KSI Min, non heat treatable stainless steel
    Grade 2 steel - 74KSI Min, non heat treatable steel
    Grade 5 steel - 120KSI Min, Quench and tempered steel
    Grade 8 steel - 150KSI Min, Quench and tempered alloy steel
  11. Mar 4, 2021 at 2:57 PM
    #461
    TaquitoBandito
    Joel (AKA Bif)
    Thanks Casey, for breaking it down. That makes a lot of sense and I've learned something so we'll call today a good day. I tend to over think, especially when I don't know what the hell I'm doing.
    I'll have to look for somebody around here with a lift because I won't be climbing under for a while. One of the side effects of my military disability is that I can clot or bleed a lot. I'm not supposed to do things where I can get really bruised up. Rolling around under the Tundra on a blanket over pebbles and brick wasn't the smartest move. I've got marks and bumps all over my body.
  12. Mar 4, 2021 at 2:59 PM
    #462
    TaquitoBandito
    Joel (AKA Bif)
    Thanks Scott!
  13. Mar 4, 2021 at 3:00 PM
    #463
    RainMan_PNW
    Casey
    Clark County, WA
    That sucks you guys have to pay for so long for the commitment you gave. If I was closer, I'd offer to help.
  14. Mar 4, 2021 at 3:30 PM
    #464
    TaquitoBandito
    Joel (AKA Bif)
    Thank you - I have it so much better than a lot of Vets as far as disabilities go. I appreciate the offer. I plan on storming Canada soon with @Azblue so maybe we can swing by Washington on the way up and I can take you up on your offer... :)
  15. Mar 4, 2021 at 3:56 PM
    #465
    RainMan_PNW
    Casey
    Clark County, WA
    :headbang:
    :canada:
  16. Mar 5, 2021 at 3:32 AM
    #466
    Bammer
    Monroe, CT
    Thank you for your service sir.:oldglory::hattip::threadjacked:
  17. Mar 5, 2021 at 6:25 AM
    #467
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Yep wish I was closer, I’d give ya a hand. Free work for bacon burgers.
    RLHULK and TaquitoBandito like this.
  18. Mar 5, 2021 at 8:43 AM
    #468
    Bammer
    Monroe, CT
    Just ordered a plate from Tyler.. :thumbsup:
    Damn this site..:spending: :rofl::rofl::rofl:
    Classy63 and TaquitoBandito like this.
  19. Mar 5, 2021 at 9:17 AM
    #469
    I have the DE skid and ordered the rear plate from Tyler. Cheaper that replacing the cats.
  20. Mar 5, 2021 at 9:23 AM
    #470
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I almost don't care if someone gets my cats. I have comp on my truck. My deductible is less than what most of the good shields will cost with installation. I could probably use new cats by now since my truck has over 140K miles.
  21. Mar 5, 2021 at 9:53 AM
    #471
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Suppose someone cuts em out. What would you do for the two months or more it takes to get replacements?
  22. Mar 5, 2021 at 10:03 AM
    #472
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    I have another vehicle as a back up so that wouldn't be too big an issue. I would still contrive a way for my insurance to provide me a free loaner.
  23. Mar 5, 2021 at 11:21 AM
    #473
    RLHULK
    Rich
    2022 Silverado LT.
    unless you have a rental coverage add on no insurance company is going to pay for a rental vehicle for a comprehensive repair. Your insurance company will pay out what your policy says is covered and no more.
  24. Mar 5, 2021 at 12:12 PM
    #474
    bwh
    bwh New Member
    And then your rates will magically go through a "market adjustment" to account for the fact you now cost them more money.
    Terndrerrr and Cock-A-Doddle-Do like this.
  25. Mar 5, 2021 at 12:15 PM
    #475
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    If that happens, my insurance agent will have to do some work finding me a better rate. There are plenty of other insurance companies that want my business.
  26. Mar 5, 2021 at 1:56 PM
    #476
    Funnyguy713
    Houston TX
    bleach[QUOTED] likes this.
  27. Mar 5, 2021 at 2:02 PM
    #477
    RLHULK
    Rich
    2022 Silverado LT.
    Nope. I filed a comprehensive claim last year, large tree limb fell across my truck hood during a storm.
    My rates have actually dropped.
    I notified my carrier, state farm, started a claim, they said pick a body shop, one I chose was highly recommended by toyota and state farm, they did the estimate, sent everything to state farm, I had the OK for work to begin in about a week, money deposited into my account, truck in body shop week and half. I paid the shop my deductable and the funds state farm gave me.
    TaquitoBandito and bleach like this.
  28. Mar 5, 2021 at 6:41 PM
    #478
    Saw this in another thread.
    TxLock21 and Rex Kramer like this.
  29. Mar 5, 2021 at 7:12 PM
    #479
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Damn sure hope this Thug, thief, PoS got reported and arrested - Wheres the video of that?
  30. Mar 6, 2021 at 5:33 AM
    #480
    biebs96
    PA
    I just scrolled through this entire thread and I am assuming I simply missed it... but what contact info/website did you order the plate from? I’d like the piece of mind as well.
