Cant open my door with dead battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by stangless40, Jan 29, 2021.
  1. Jan 30, 2021 at 9:10 AM
    #91
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Unless there is a baby or dog in the car, I wouldn't smash any windows, pry any doors, run any wires.
    Like many have already suggested, call a locksmith.
    You could have been in your car 22hrs ago by now
  2. Jan 30, 2021 at 9:47 AM
    #92
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Slim jims and inflatable door wedges still work without battery and a broken lock tumbler. It’s humbling just how fast an experienced lock smith can be inside of your car - typically faster than you can count out the three $20 bills he’ll charge you if you don’t have AAA.
  3. Jan 30, 2021 at 9:55 AM
    #93
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
    Oh, and if for any reason you DO decide to break a window....
    From previous experiences with domestic cars that have had side windows broken in, the front windshield is normally the cheapest to replace these days.
  4. Jan 30, 2021 at 10:00 AM
    #94
    KillaahCam
    KillaahCam New Member
    Cameron
    North East Texas
    2014 MGM 1794 Crewmax 4x4
  5. Jan 30, 2021 at 10:27 AM
    #95
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    So why hasn’t a locksmith or tow truck been called to open the door? Just out of pride?
  6. Jan 30, 2021 at 10:32 AM
    #96
    18" TRD Off Road Wheels
    Depends on the windshield and where you replace it. Mine has defrosters wired up to where the wipers rest. Not cheap. Also, some non OEM glass is not optically correct for the camera that is mounted on the rearview mirror base, so again, not cheap.
    Cpl_Punishment likes this.
  7. Jan 30, 2021 at 10:48 AM
    #97
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    You want to drive home from a trip with no windshield?
    bleach and GODZILLA like this.
  8. Jan 30, 2021 at 11:18 AM
    #98
    stangless40
    stangless40 [OP] New Member
    Alberta Canada
    17 Platinum
    lots
    Thanks everyone but i got it open, tried to charge it a bit no luck, took the battery out and found that a one year old battery has ice after i open the cap to see the acid, 5 of my cells are frozen with ice on the top.
  9. Jan 30, 2021 at 11:19 AM
    #99
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    How did you finally end up getting it open?
    TTund16 and BravoDeltaRomeo like this.
  10. Jan 30, 2021 at 11:20 AM
    #100
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    It had to be discharged already to freeze. Pretty sure you're getting a new battery.
    What worked to get the truck open?
    TTund16 and Cpl_Punishment like this.
  11. Jan 30, 2021 at 11:25 AM
    #101
    stangless40
    Alberta Canada
    17 Platinum
    lots
    Called a tow truck, he had one of the tiny little pumps, pryed the door and a long rod for the handle, bingo. $100 later.
  12. Jan 30, 2021 at 11:34 AM
    #102
    Snaz
    Snaz I <3 explosions
    SE CO
    '20 Limited Quicksand
    Could you charge though the trailer light plug?
  13. Jan 30, 2021 at 11:34 AM
    #103
    stangless40
    Alberta Canada
    17 Platinum
    lots
    Still doesn't explain why my key didn't work, last year my battery died and my key worked, this time it didn't, the only thing that changed beside of all the parts i bought was i took the chrome handles off and put the painted match handles on.
  14. Jan 30, 2021 at 11:40 AM
    #104
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Something didn't go back on right. Looks like you'll have dig into the door's inner workings.
  15. Jan 30, 2021 at 11:42 AM
    #105
    stangless40
    Alberta Canada
    17 Platinum
    lots
    Yep i know, i will deal with that in the summer.
  16. Jan 30, 2021 at 11:43 AM
    #106
    JohnLakeman
    It does seem like that should work, but the 12V+ BATT terminal has a relay in the circuit that is energized through the ignition fuse. If the ignition circuit is not hot, then that relay is open.
    Snaz[QUOTED] likes this.
  17. Jan 30, 2021 at 11:49 AM
    #107
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Doubt it. But worth OP trying rather than taking the sawzall to the grille or putting a rock through a window. Because he seems to really not want to call a locksmith.
  18. Jan 30, 2021 at 11:51 AM
    #108
    He already called and got into his truck....
    EDDO[QUOTED] likes this.
  19. Jan 30, 2021 at 11:52 AM
    #109
    JohnLakeman
    Yep. Quicker than he could count out $100. :D
    RainMan_PNW and bleach like this.
  20. Jan 30, 2021 at 11:53 AM
    #110
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    Missed that. Had high hopes for this thread.
  21. Jan 30, 2021 at 11:55 AM
    #111
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i'm just going to sit over here with my solar fed dual batteries and just watch... :cheers:
    BravoDeltaRomeo and Black Wolf like this.
  22. Jan 30, 2021 at 12:04 PM
    #112
    Lextech
    Lextech New Member
    05 Double Cab
    Has anyone ever been in that door. I've known of technicians leaving the rod off when replacing door lock actuators. Will work electronically but not manually.
    Black Wolf likes this.
  23. Jan 30, 2021 at 12:12 PM
    #113
    I did this exact same thing on my 09 Taco after I locked my keys in with all the windows up. Wasn't fun but was painless.
    .....and FREE
  24. Jan 30, 2021 at 12:19 PM
    #114
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My mistake, I only counted 5...:thumbsup:
    BravoDeltaRomeo likes this.
  25. Jan 30, 2021 at 1:16 PM
    #115
    BobsYourUncle
    No, I would probably call a locksmith and have them give it a go myself.
    I was just speculating based on previous experiences (side windows not in stock... had to order, more expensive than windshield, more labor, etc...), that IF the OP did decide to break glass, well then the front windshield would have been the easiest route. And his second stop would be a glass installer before going home... LOL
  26. Jan 30, 2021 at 1:42 PM
    #116
    stangless40
    Alberta Canada
    17 Platinum
    lots
    Found out what was wrong with my key, when i put my new handles on i must have not aligned the rod straight, now it works. Now for all people who want to change your handles just make sure your 4" rod is straight don't make the mistake i did.
    Anyway Thanks everybody for your input.
    bleach, TTund16, JohnLakeman and 7 others like this.
  27. Jan 30, 2021 at 1:50 PM
    #117
    RainMan_PNW
    Casey
    Clark County, WA
    If we can't learn from our mistakes, we are destined to repeat them. Glad you got it sorted out. Too bad that it cost you 100 maple leaves in the process...
  28. Jan 30, 2021 at 2:33 PM
    #118
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
  29. Jan 30, 2021 at 2:35 PM
    #119
    BravoDeltaRomeo
    Bruce
    MB Canada
    It's only like $43usd....so not bad.
    bleach and RainMan_PNW[QUOTED] like this.
  30. Jan 30, 2021 at 2:36 PM
    #120
    :rofl::rofl::rofl:
    smslavin[QUOTED] and RainMan_PNW like this.
