Cant open my door with dead battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by stangless40, Jan 29, 2021.
  1. Jan 29, 2021 at 9:26 PM
  2. Jan 29, 2021 at 9:27 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Tomorrow I m going to try to rig up an alternate way of opening hood from the outside. Maybe a stout wire that runs from the latch to to one of the front fender wells. Just reach in there, pull the wire, and boom, hood opens. This could be a mod in the making:D
  3. Jan 29, 2021 at 9:28 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    So how much are windows :fenforcer:
    Rica25, Black Wolf and bleach like this.
  4. Jan 29, 2021 at 9:28 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    See post #23 above. :evil:
    EDDO[QUOTED], Rica25 and Black Wolf like this.
  5. Jan 29, 2021 at 9:37 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    How is that going to work if the lights are not on?
    TTund16, EDDO, Rica25 and 1 other person like this.
  6. Jan 29, 2021 at 9:39 PM
    ...about as easy as using the starter
  7. Jan 29, 2021 at 9:44 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    At least the starter has a direct connection to the battery, right?
    These new fangled machines confuse me...:eek2:
    My 1969 Ford Fairlane was so much simpler...
    No power door locks, no power windows, NO POWER STEERING...
    TTund16, EDDO, Cpl_Punishment and 2 others like this.
  8. Jan 29, 2021 at 9:49 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Yes, that's when they put all the power into the engine.
    Black Wolf and 1lowlife[QUOTED] like this.
  9. Jan 29, 2021 at 9:50 PM
    stangless40
    stangless40 [OP] New Member
    Alberta Canada
    17 Platinum
    lots
    Starter would be best, but impossible to get too, but need to run a second battery to try to get some voltage, hoping enough to open the door
  10. Jan 29, 2021 at 9:52 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    And I thought only the starter on a 4.7L was impossible to get to.
  11. Jan 29, 2021 at 9:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    A locksmith can get into it. It’s got electric door actuators, but also has manual door locks. If the driver’s side is failed in some way, the passenger side can still be done. I had to have it done once on my 2008 (locked the keys inside it). Thank God for keeping AAA on my rigs.
    BravoDeltaRomeo and 1lowlife like this.
  12. Jan 29, 2021 at 9:54 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    A battery charger if you have one, would also work.
  13. Jan 29, 2021 at 9:55 PM
    stangless40
    Alberta Canada
    17 Platinum
    lots
    getting some insight, but still doesn't answer why the key doesn't open the door, might as well throw in the garbage, funny this happen one year ago in Dec battery was dead but the key opened the door. Stumped
    TTund16 likes this.
  14. Jan 29, 2021 at 9:58 PM
    TILLY
    Massachusetts
    When you turn the key can you feel any resistance or hear any noise, or is it completely loose when you turn it side to side?
  15. Jan 29, 2021 at 9:59 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    What about the +/- terminals in the 7 pin trailer plug? Anybody know off hand if the aux pin is always hot or keyed hot? If it is always hot, then they are labeled and will make it easy to identify which is which.
  16. Jan 29, 2021 at 10:02 PM
    stangless40
    Alberta Canada
    17 Platinum
    lots
    Completely loose,
  17. Jan 29, 2021 at 10:13 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Good call...
    Is the + BATT or ACC?
    I think it is all the time or maybe not??
    pickeledpigsfeet likes this.
  18. Jan 29, 2021 at 10:32 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I am no electrician nor certified tech in any stretch or capacity, but...
    I strongly oppose the tapping of any circuit to jump start the battery... quickest way to make a hefty obligatory contribution to your local stealerships, as I'm sure they will be more than happy and willing to redo the entire electrical system as well as ECUs.. while voiding the warranty in the process.... in today's pandemic I'm sure they have an at your home service technician who can probably do whatever you want to do, except you can sue them for their screw up instead of bricking your truck.. and coming out of your pockets for repairs, and the electrical gremlins that will follow....
    deptrai and Cpl_Punishment like this.
  19. Jan 29, 2021 at 10:50 PM
    #49
    1lowlife
    DADA
    2014 MGM DC SR5
    OP isn't trying to jump start the battery/engine.
    He can't even into his truck to get his key into the ignition switch to turn it on.
    He just wants to unlock the fu(king door with his remote and needs minimal power to the electrical system to do so....
    Pay attention..................................................
  20. Jan 29, 2021 at 11:09 PM
    #50
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Thanks for letting the guilty remain anonymous.:anonymous:
  21. Jan 29, 2021 at 11:16 PM
    #51
    necplusultra
    necplusultra New Member
    did you try changing the battery on the key fob
  22. Jan 29, 2021 at 11:28 PM
    #52
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    I know this doesn't get you out of your predicament but a future mod can really help if this ever happens again or to anyone else. I've got one of these cables in my shop I'm going to install on mine this weekend due to the OP's situation (it may save my tail later on).
    Wire this directly to your battery. Run the capped end somewhere behind your grill or hanging down behind the bumper (make it reachable with the hood closed).
    The idea is NOT to boost your truck with it, but to provide that little bit of charge so that your door lock actuators can unlock your door. OR/AND you can also connect a trickle charger (battery tender) and charge you battery over a few hours with it.
    SAE Motorcycle battery charger cable
    Since this comes in a 2 pack, the extra one can be used to hook up to a battery charger, battery etc.
    https://www.amazon.com/SPARKING-Motorcycle-Disconnect-Extension-Accessory/dp/B07KS2GCXJ
    I'm not sure what size fuse comes with it, but I would install a 20 or 30 amp fuse. That is what I run on my motorcycle anyway.
    Battery Tender - comes with the SAE connector on it.
    https://www.batterytender.com/Battery-Tender-Junior-12V-0-75A
  23. Jan 29, 2021 at 11:33 PM
    #53
    Devius1
    Devius1 5150 Member
    NorCal
    MGM 2019 Platinum
    Auto club would be my choice, lights n' stuff go thru relays which should be cold w/o any power.
    7 pin would be the logical choice if its a constant hot.
    G/L!
    TTund16 likes this.
  24. Jan 29, 2021 at 11:54 PM
    #54
    MentalBill
    MentalBill Mental in every state.
    Bill
    Oahu
    2015 Tundra Limited and 2018 Honda Civic
    Check your insurance company. Some polices have a lock out service.
  25. Jan 29, 2021 at 11:54 PM
    #55
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    Now the bad news. I assumed all the suggestions (back-feed electricity) through the license plate light, tail light, any light, or 7 pin connector would not work. So, sitting here at work with some REALLY smart avionics guys tonight, I asked one of them to look at the schematic in post #47 above and confirm what I had assumed. ALL of the lights, 7 pin connectors, etc are interrupted by a relay. Put plainly, none of the electrical current will get to the battery from those points without the relay being closed (they are ALL in the open position when the key is off or lights are off).
    The only chance you have is to connect to the positive wire on the starter to be able to charge the battery enough to be able to unlock your doors.
    If you can't get that done, a lock smith is probably your wisest choice.
    EDIT: Just read @Devius1 post (2 posts above). He is saying the same thing.
    TTund16 and Cpl_Punishment like this.
  26. Jan 29, 2021 at 11:56 PM
    #56
    MentalBill
    Bill
    Oahu
  27. Jan 30, 2021 at 2:17 AM
    #57
    Berettafan
    Berettafan New Member
    2017 CM
    This seems like a really good idea.
  28. Jan 30, 2021 at 3:57 AM
    #58
    kxed
    kxed New Member
    Pittsburgh PA
    2020 VooDoo Blue Crewmax Sport
    DO NOT USE 24 VOLTS!! Your truck is 12V.
    landphil likes this.
  29. Jan 30, 2021 at 5:27 AM
    #59
    ....and the starter and alternator in plain site. One coil. One voltage regulator. Simple bliss:thumbsup:
  30. Jan 30, 2021 at 5:38 AM
    #60
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Also not susceptible to damage from EMP weapons. Sooner or later this will become important.
