Can Poor Cornering Be Improved?
Discussion in '2nd Gen Tundras (2007-2013)' started by rustytoys, Jan 3, 2021.
  1. Jan 4, 2021 at 7:33 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Corvettes have leaf springs....
    Black Wolf likes this.
  2. Jan 4, 2021 at 7:34 PM
    ...and low profile, no room for a decent rear coil setup.
  3. Jan 4, 2021 at 7:38 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Grafting the IRS from a Sequoia onto a Tundra would be ideal.
    rustytoys[OP] and Black Wolf like this.
  4. Jan 4, 2021 at 7:39 PM
    Just maybe it might be happening........
  5. Jan 4, 2021 at 7:40 PM
    rustytoys
    rustytoys [OP] New Member
    Only the slow ones!
  6. Jan 4, 2021 at 7:42 PM
    No such thing as a slow Vette....ha
    rustytoys[QUOTED][OP] likes this.
  7. Jan 4, 2021 at 7:52 PM
    rustytoys
    If you could buy the entire sequoia axle with trailing arm mounts it seems like it could be fairly straight forward.
  8. Jan 4, 2021 at 7:57 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    RAM uses rear coils on the 1500 and 2500, goes back to leaf springs on the 3500.
  9. Jan 4, 2021 at 8:01 PM
    A-A-Ron
    Aaron
    Seattle
    ^This is the true answer
    Tundyfundy[QUOTED] likes this.
  10. Jan 4, 2021 at 8:06 PM
    rustytoys
    New Honda Ridgeline also running full independent rear suspension.
  11. Jan 4, 2021 at 8:19 PM
    rustytoys
  12. Jan 4, 2021 at 8:37 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    The TRD sway bar (rear) can be run in two configurations. I have a 1.75” lift in rear and an still running it in factory config, the alternative config can be used for higher lifts but not sure how high. Maybe somebody with the Hellwig can chime in.
