Cam tower leak
Discussion in 'General Tundra Discussion' started by TheBeast, Oct 1, 2017.
  1. Oct 7, 2017 at 2:03 PM
    TheBeast [OP] The Beach
    and the Beast is home. Picked it up this morning. They changed a bunch of gaskets and I now have black sealant on both sides. They also did an oil change and pressure washed the engine bay.
    Rental car for 3 days. Cost $0 total. Glad I had the warranty :) Thank you Toyota.
    Now to monitor if any issues but so far feel the same when driving it.
  2. Oct 7, 2017 at 2:29 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Nice! Good to hear.
  3. Oct 7, 2017 at 3:11 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Good to hear! Hopefully it's as good as new.
    Y0TA PR0 likes this.
  4. Oct 7, 2017 at 4:55 PM
    Vizsla
    Vizsla 2 = 2.5
    I am a repeat cam tower loser. My 16 is going in this week to have them done again at 9,000 miles, first repair at 3,000 miles. My 12 had it done as well. I doubt toyota ever did anything to remedy it, almost every Tundra I look under is seeping, both mine leaked much more than seepage at really low miles. I believe it is bad engineering, FIPG gaskets require perfectly clean surfaces, proper RA(surface finish), and the deck must be in tolerance. So it is a crap shoot at the factory, and even worse with your local dealership tech. I change my oil ASAP, usually around 100 miles, and all kinds of crap comes out, and the filter is full of debris(chunks of FIPG), so I strongly recommend oil change soon.
  5. Oct 7, 2017 at 5:31 PM
    not cool. what did the dealer say when you scheduled your second trip ?
  6. Oct 7, 2017 at 5:48 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    No good. Was it the same black sealant they use the first time?
  7. Oct 7, 2017 at 6:08 PM
    Vizsla
    Vizsla 2 = 2.5
    Well I’ve moved since the first repair, Denver to Phoenix, and even though the best guy for the job got it, it’s pretty obvious he sucked. Obviously my local dealer said workmanship issue, take it back(slim to no chance of getting it fixed right in Denver, and f that, too much trouble). There is a tight group of people here in AZ, and they put me in touch with the right people to sort it out, thanks @14burrito ! Bottom line, I won’t trust it after being taken apart twice, probably sell it and move on.
    14burrito likes this.
  8. Oct 7, 2017 at 6:10 PM
    Vizsla
    Vizsla 2 = 2.5
    If you have black sealant, they have already been done. The gray is factory, and supposedly better.
  9. Oct 7, 2017 at 6:51 PM
    duece292
    Greg
    Green Bay, WI
    Hmmm. All of a sudden I'm not feeling real warm and fuzzy about taking mine in to be fixed. Especially considering that the SA doesn't think they've ever done one before.
  10. Oct 7, 2017 at 7:54 PM
    Time will tell. The black sealant is the new stuff they put on. Some people have up to 25,000 miles on it with no issues. I want everything documented and taken care at the dealership under warranty. If things keep happening, at least Toyota corporation has paper trail.
    No matter what, it's leaking. Issue gotta be addressed.
    here is what it says on the service history:
    ~SEAL SPLIT AT EACH CAMSHAFT TOWER AND SEEPAGE FROM TIMING COVER ~|~REMOVED FRONT TIMING COVER AND BOTH CAMSHAFT TOWERS AND REPLACED ALL GASKET AND SEALS AS REQUIRED 3 DAY FREE CAR RENTAL
    duece292[QUOTED] and Y0TA PR0 like this.
  11. Oct 8, 2017 at 3:27 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Glad Grant got you taken care of! :D
    Vizsla[QUOTED] likes this.
  12. Oct 12, 2017 at 8:47 AM
    duece292
    Greg
    Green Bay, WI
    Well, mine went in this morning to be "officially" diagnosed with the cam tower and timing cover leaks. My comfort level went up a little after talking to the tech, he's done several of them. So, keeping my fingers crossed. At 56,100, as long as theyre that deep in it I'm thinking I'll have them change the plugs and serp belt. Any thoughts?
    TheBeast[OP] and Y0TA PR0 like this.
  13. Oct 12, 2017 at 11:44 AM
    you can still wait on those. Take care of the warranty stuff first .Get it documented. Drive it a lot after that to flush any potential issues then hopefully keep the truck for many years after that.
    duece292 likes this.
  14. Oct 12, 2017 at 11:54 AM
    so far I have 300 miles since the work. Truck handles the same. Engine is bone dry.
    Will keep updating this thread when I have couple more thousand miles on it.
    Y0TA PR0 and duece292 like this.
  15. Oct 12, 2017 at 11:59 AM
    duece292
    Greg
    Green Bay, WI
    I just got mine back from the dealer, cam tower and timing cover leaks are confirmed and it's scheduled for repair on the 25th. I couldn't talk them into giving me an '18 Tundra to drive for the three days though lol. I am going to have them do new plugs and belt while everything is torn apart.
    Y0TA PR0 and TheBeast[OP] like this.
  16. Oct 18, 2017 at 2:38 PM
    TundraX1
    TundraX1 New Member
    2012 White Platinum
    Need Direction ;
    I bought a certified used 2012 Platinum Tundra with 32k miles and 2 years later with regular maintenance and your cam seal leak with head gaskets changed by the dealer, I have found a very hard rod knock, flutter from the engine. I took my truck back to the dealership to have the oil and filter changed with 114.8k miles on it at this time and was told I will need to replace the engine. I believe something isn't smelling right. Does anyone know any issues with the connection of the cam seal leak and the rod ready to blow ?
  17. Oct 18, 2017 at 2:41 PM
    can you confirm the sealant color used to repair or take a picture ? so you had the "fix" for about 90,000 miles already ?
  18. Oct 18, 2017 at 3:05 PM
    TundraX1
    TundraX1 New Member
    2012 White Platinum
    the repair was done at the 72k mark, while I was in for a normal oil and filter change they found water pump leaking - replaced, cam carrier leaking - replaced 1 cylinder head gasket, 4 camshaft bearing gasket, 2 manifold gasket, 2 water outlet gasket, 1 cylinder head gasket, 2 fipg oil pan, 1 type t oil seal, 1 water inlet gasket, 2 camshaft bearing gasket, o rings. I had no problems that I had recognized until lately. regular oil changes on time, no truck doggin. heavy highway miles. I am at 115.8k miles mark now. The truck still runs strong but the flutter, knock, ping is getting worse.
  19. Oct 18, 2017 at 3:06 PM
    #49
    TundraX1
    TundraX1 New Member
    2012 White Platinum
    i will get a picture or color of the sealant
  20. Oct 18, 2017 at 3:08 PM
    #50
    I doubt it's related to the cam leak fix. You have been driving 40K miles since they fix it. Could it be a bad batch of gasoline ? is it recent issue ?
  21. Oct 18, 2017 at 3:11 PM
    #51
    I've been lucky so far with my 07. Zero leaks. Anywhere. Knocking on wood now. For the gutter heads.....my wood picnic table.........heh
  22. Oct 18, 2017 at 3:15 PM
    #52
    Try some Lucas Upper Cylinder Treatment. It works in most cases. Gets rid of my cold weather startup knock ping. Used it in my 09 Taco when I was up in AK too.
  23. Oct 18, 2017 at 3:22 PM
    #53
    TundraX1
    TundraX1 New Member
    2012 White Platinum
    not a recent event. I appreciate the assistance.
    Black Wolf likes this.
  24. Oct 18, 2017 at 3:29 PM
    #54
    I add the Lucas UC treatment with every gas fill up and MotorKote in the crank case with every oil change.
  25. Oct 18, 2017 at 3:30 PM
    #55
    TundraX1
    TundraX1 New Member
    2012 White Platinum
    not buying bad gasoline, drive 800 to 1000 miles a week. oil level has always been checked daily or biweekly
    buy an extended warranty ?
  26. Oct 18, 2017 at 3:34 PM
    #56
    I bought an extended warranty when I bought my Tundra three years ago. Never needed it. It's a matter of comfort level. I could bought a lot of goodies for my truck. Was a full warranty. Covered pretty much everything. $2500. Would I do it again? Not too sure about that now. Maybe better to save the money for a rainy day. Then use it if something breaks.
  27. Oct 18, 2017 at 3:48 PM
    #57
    seems to be from 2010 to 2016.
  28. Oct 18, 2017 at 3:53 PM
    #58
    TundraX1
    TundraX1 New Member
    2012 White Platinum
    i am out of Warranty. So do you think I need protection ? bad question ....
  29. Oct 18, 2017 at 3:58 PM
    #59
    My warranty was with Zurich. Very good but very pricey. Zurich has different levels of coverages. I went for the top coverage. You can shop around. Maybe others can chime in with their aftermarket warranty experiences.
