CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Sep 23, 2019 at 2:37 PM
    #1951
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    my dealer told me that the "seep" is acceptable... You actually listen to their bullshit?
  2. Sep 23, 2019 at 2:42 PM
    #1952
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Not one bit
    Capt J-Rod likes this.
  3. Sep 23, 2019 at 2:51 PM
    #1953
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I found old gasket debris and even a few wire wheel bristles in mine for a few oil changes after. I took pictures of what the filter caught each time to document. I think its BS Toyota doesn't include an oil change with this procedure. I did my next few changes at shorter intervals after the repair.
  4. Sep 23, 2019 at 3:26 PM
    #1954
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    It's too bad they don't keep that crap from ending up in the crankcase. What you are finding getting caught in the filter was pumped there by the oil pump. Not healthy for the pump to deal with that stuff.
    Toyotoholic likes this.
  5. Sep 23, 2019 at 5:01 PM
    #1955
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Not one bit, you and I doing the work would make sure it didn't happen. Going into a shop, its get it in and out.
  6. Sep 24, 2019 at 3:50 AM
    #1956
    RitcheyRch
    RitcheyRch New Member
    Richard
    Star, Idaho
    TRD Lowered and Supercharged
    One of the reasons I would be hesitant to get this issue repaired. Might be better off just cleaning the oil off every few thousand miles.
    Moon Puppy, Cpl_Punishment and jtwags like this.
  7. Sep 24, 2019 at 4:49 AM
    #1957
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    I’m not sure mine is leaking, need to pull splash guards out of the way and get a better look when it stops raining here.
    As far as just cleaning the oil off and not repairing, depends on how old & how many miles are on it.
    A leak isn’t going to get better.
    While I’m totally with you that more care should be taken by the shop, there’s NO WAY I’m letting a leak go un-repaired.
    My ‘17 is still under warranty. (CPO buy)
    If my truck wasn’t under warranty I might think differently but No Way In Hell I’m letting it slide when they’re going to eat it.
  8. Sep 24, 2019 at 5:15 AM
    #1958
    neirbot
    neirbot New Member
    That's why I had mine done, but it wasn't without some concern.
  9. Sep 24, 2019 at 8:02 AM
    #1959
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Same here, plus mine was bad enough it was leaking onto the heatshield and smoking some. You could smell it in the cab, I also had concerns about it. Its a very extensive repair.
  10. Sep 24, 2019 at 8:14 AM
    #1960
    Bergmen
    Bergmen New Member
    Ukiah, California
    That is exactly how I will deal with this if it happens to my 2018. So far, 40,000 miles and totally clean (both sides). But if it starts to seep I can spray it down with some Gunk engine cleaner (once every two weeks or so) and hose it off. I should be able to stay ahead of it so it doesn't drip on the heat shields. This would only take five minutes each time. I am not going to pull the engine down to fix this and will absolutely not let anyone else do this either (dealer or independent mechanic).
    gjcarving likes this.
  11. Sep 24, 2019 at 8:20 AM
    #1961
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    https://youtu.be/bhNQ9cv5K7Q
  12. Sep 28, 2019 at 11:49 AM
    #1962
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    Just went out and checked No leek on either side 49K miles on my 14 CPO.
  13. Sep 28, 2019 at 6:16 PM
    #1963
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Just checked mine for the first time in i donno probably a year and it still looks about the exact same without even a drop. Just a little wet passenger side only. About 33k miles. So i though it would have gotten worse?
  14. Sep 29, 2019 at 4:03 PM
    #1964
    6XC
    6XC OPS4
    '18 MGM Tundra SR5 TSS Crewmax 4x4
    Is this what I'm looking at here?
    TheBeast likes this.
  15. Sep 29, 2019 at 4:56 PM
    #1965
    neirbot
    neirbot New Member
    Changed my oil yesterday with 600 miles since the procedure. Not a speck of anything but oil. And the engine is running great.
  16. Sep 29, 2019 at 5:04 PM
    #1966
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Looks like what the dealer/Toyota will call a "seep", but yeah.
  17. Sep 29, 2019 at 5:04 PM
    #1967
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Two ways to look at this, you got lucky and nothing fell in the motor, or its still stuck somewhere inside. Hopefully you got lucky, I would still shorten my next interval just in case, if comes out clean then go back to normal oil change interval.
    RitcheyRch likes this.
  18. Sep 29, 2019 at 5:05 PM
    #1968
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Yep!
  19. Sep 29, 2019 at 5:07 PM
    #1969
    6XC
    6XC OPS4
    Awesome. It's a 2018 with 26K miles I just bought three weeks ago. Any advice on how to proceed?
  20. Sep 29, 2019 at 5:08 PM
    #1970
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Hey, you made it longer than mine! Unless that's why the previous owner got rid of it and the dealer just wiped it off... I'd go have the dealer look at it and at least get it documented that it's in the beginning stages. Again, they'll probably call it a seep and won't do anything at this point.
  21. Sep 29, 2019 at 5:08 PM
    #1971
    neirbot
    neirbot New Member
    Agreed, planning to change it again in another 500-1000 miles. $40 well spent IMO.
  22. Sep 29, 2019 at 5:09 PM
    #1972
    6XC
    6XC OPS4
    Thank you. I'll give them a call tomorrow and hopefully can have them look at it Tuesday.
  23. Sep 29, 2019 at 5:10 PM
    #1973
    Alloutdrs1
    Andrew
    Virginia Beach, VA
  24. Oct 7, 2019 at 1:23 PM
    #1974
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Taking mine in tomorrow to have the techs look at mine... leaking both sides. Can’t wait to hear what kind of BS they toss my way.
    Waterboy45661 likes this.
  25. Oct 7, 2019 at 7:33 PM
    #1975
    Matt T Tundra
    Matt T Tundra New Member
    I got hit today for it. $3,200 for it. I have the 4.6L 2012 Tundra. The new sealant in the fix is completely different I've been told. Dealer was nice at least. I raised a stink with Corporate. We'll see what they do.
    There's a simple fix. We need several people nation wide to stand outside, on the sidewalk, out in front of Toyota dealerships with big signs and flyers on a given Saturday. You'll get local news followed by national news. This would be the first auto protest. Hand the flyers out to every Tundra that passes! It probably wouldn't take much to get on national news because it would be so odd and first ever.
    There is a legal firm looking into a possible class action lawsuit. Probably won't do anything.
    http://www.classlawdc.com/2018/07/18/toyota-camshaft-tower-seal-leaking-class-action-investigation/
  26. Oct 7, 2019 at 7:45 PM
    #1976
    Trdwillie14
    Billy
    2014 trd off road
    Great news glad they did it
  27. Oct 7, 2019 at 8:05 PM
    #1977
    TheBeast The Beach
    finally got to you...:(
  28. Oct 7, 2019 at 8:23 PM
    #1978
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Has anyone had this issue covered under CPO?
  29. Oct 7, 2019 at 8:26 PM
    #1979
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Took to dealer for 30K service and had the rep confirm no leak. I do have seeping from rear diff- they cleaned it and put notes about both in service record.
  30. Oct 8, 2019 at 12:53 PM
    #1980
    MatthewPTguy
    Eugene, Oregon
    The dealership confirmed both cam towers leaking... going to fix both sides. Service manager said she hopes to have my truck back by the weekend.. :(
