CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Mar 10, 2018 at 9:11 AM
    #451
    TheBeast The Beach
    looks good . I think you need to shake it more on the trails to be sure :D:p
    Spvrtan and Y0TA PR0 like this.
  2. Mar 10, 2018 at 3:40 PM
    #452
    SNO BUS
    SNO BUS Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
  3. Mar 10, 2018 at 6:29 PM
    #453
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    You look good to go so far, how many miles?
    Spvrtan[QUOTED] likes this.
  4. Mar 10, 2018 at 6:31 PM
    #454
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    So how does this work? Are you submitting to Toyota in hopes they will actually do something? Or does it go to another outlet who will use it to battle Toyota on the issue?
  5. Mar 10, 2018 at 6:33 PM
    #455
    SNO BUS
    Nick
    Washington
    Going straight to toyota and nhtsa. As discussed in my thread about the petition, it's a long shot, but it can't hurt to try.
  6. Mar 10, 2018 at 6:50 PM
    #456
    n2deep
    n2deep Pavement Princess
    Why did you just put 2014+ Tundras since it affects Gen2 and Gen3?
    Y0TA PR0 likes this.
  7. Mar 10, 2018 at 8:21 PM
    #457
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    All clean and tech approved
  8. Mar 11, 2018 at 8:10 AM
    #458
    Updated OP with the petition link.
    TheBeast and SNO BUS like this.
  9. Mar 11, 2018 at 7:29 PM
    #459
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Well got around to changing the oil today, had the repair done monday-tuesday And put on a little over 200 miles since then. Looks like they didn't do a drain and fill after the repair, so my truck was about 3qts low. Hopefully no adverse effects from running like this. Filter also had a lot of debris in it, mostly gasket material it seems. Took some pictures of a few pleats as an example for you guys. Not sure if I'm going to do next oil change at 5k or run the full interval to 10k. What do you guys suggest?
    So for you guys who are going to have the repair done:
    Be sure to check oil level after
    Change oil and filter after 200miles like @TheBeast suggested.
  10. Mar 11, 2018 at 7:35 PM
    #460
    TheBeast The Beach
    yep. I would do the next one at 5K. cheap enough to do it earlier. Then you can get back to 10K.
    Watt maker likes this.
  11. Mar 11, 2018 at 8:14 PM
    #461
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Just over 66k on my 2014.
  12. Mar 11, 2018 at 8:58 PM
    #462
    Coppell
    Coppell New Member
    Issaquah, WA
    2015 CM LTD TDR
    GTR ultra led headlights RCI skid plate Curtis front hitch and xcr winch Back country all terrain 10ply tires
    Apologies in advance if this is a dumb question but.....I look into the engine and see chaos so really have know idea where I should be looking to see if I have this issue. Any pointers most appreciated.
    Second question , is this issue only a matter of time before it materializes or do some trucks not have the problem?
    Can you live with the problem , ie just keep feeding it oil?
    I love my Tundra , I have about 35k miles on it and when I bought it new I intended to keep it for many years but this has now got me worried, I don’t need a problem when I’m fishing in the middle of knowhere, MT.
    Thanks ,
  13. Mar 11, 2018 at 9:57 PM
    #463
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Just take a quick look through this thread and there should be some pics of the areas to look. It will be visible through your wheel wells. Also, not every Tundra gets this, but it seems to be not uncommon. That said, I don't think it's ever left anyone stranded. It seems to be one of those issues where if it happens, it gets fixed and very rarely happens again.
    TheBeast likes this.
  14. Mar 11, 2018 at 10:08 PM
    #464
    Coppell
    Coppell New Member
    Issaquah, WA
    2015 CM LTD TDR
    Thanks Buck, I had looked at pics but did not think to look from the wheel wells
    Cheers,
  15. Mar 12, 2018 at 9:26 AM
    #465
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Much easier to spot looking through the wheel wells, also look at your manifold heat shields. To answer your other questions it pretty much depends on the truck. Some seem to just seep and not loose much oil, others mine included leak pretty good. Mine was leaking on the passenger side rear and dripping onto the exhaust manifold and burning off there. So if you have a seep just monitor it, if its leaking that's your call if you want to keep adding oil or have it fixed. Since mine was going onto the exhaust manifold I was starting to smell it in the truck so it had to be fixed.
  16. Mar 12, 2018 at 10:08 AM
    #466
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I had this happen on my 2013 CM with only 14,000 miles. Repair was covered and it is still holding up fine at 57,000 miles. I also called up Toyota Corporate and complained and they gave me a complimentary 100,000 mile warranty.
  17. Mar 12, 2018 at 10:49 AM
    #467
    Coppell
    Coppell New Member
    Issaquah, WA
    2015 CM LTD TDR
    good to know, thanks
  18. Mar 12, 2018 at 2:25 PM
    #468
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Seems like the guys with earlier model trucks had better luck getting the extended warranty, I tried this with mine and all they would offer was $350 towards parts or service.
  19. Mar 12, 2018 at 2:29 PM
    #469
    Atomic City Tundra
    Devin
    New Mexico
    They rejected me the first time as well. I called them again the next day and got someone different.
    Wynnded and TheBeast like this.
  20. Mar 12, 2018 at 2:53 PM
    #470
    TheBeast The Beach
    maybe because back then less vehicles had it and Toyota was willing to make a gesture. Now with all the gen3's having the same issue it's getting crazy expensive
    Wynnded likes this.
  21. Mar 12, 2018 at 4:09 PM
    #471
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    This was my thought as well, we already know they cut down on the tech's hours for repairing this job also. Must becoming an expensive fix for Toyota now, Maybe Gen4 will solve the issue.
  22. Mar 13, 2018 at 6:54 AM
    #472
    Atomic City Tundra
    Devin
    New Mexico
    I can't believe that it is still a problem. I think the addition of a hard gasket at the interface and maybe a slight change to the design of the mating surfaces would knock the problem out for good. Seems like it would be fairly easy to address for Toyota, but for some reason they don't.
  23. Mar 13, 2018 at 6:58 AM
    #473
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Agreed, or just start using the supposedly better black sealant at assembly and maybe that would solve the issue as well. My guess though is we are at the end of this platforms run and this motor will not carryover so they are not looking to spend money on actually solving the issue. Instead handling it as they leak at the repair shop is what they feel is more cost effective.
  24. Mar 14, 2018 at 12:25 PM
    #474
    Snipe06
    Snipe06 New Member
    Georgia
    2012 Magnetic Gray Tundra RWDC
    Ok Gents, one thing after you get your truck from the dealer and one morning you see the lovely combination of flashing lights for the AIP or secondary air pumps: make sure you check the vacuum lines from the air intake....:mad:
  25. Mar 20, 2018 at 5:47 AM
    #475
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Well, dropped it off this morning for the work to be done. I hope it goes well and I get the truck back for the weekend.
    Got a purple RAV4 service loaner this time. The seats are terrible and I get this weird vibration feeling through the armrest that makes me think my phone is going off. The interior feels cheaper than a Corolla as well. Not a fan. I would have just gotten a Corolla again, but with the upcoming snow storm wanted all wheel drive so I’m not stuck in my driveway.
  26. Mar 20, 2018 at 6:39 AM
    #476
    Atomic City Tundra
    Devin
    New Mexico
    Blech. When I had my truck fixed, they had a Corolla replacement slated for me. But then the service manager looked at me and said "I'm not sure you will fit" (I'm 6'8"), and called the back and had them bring me another Tundra as a replacement.
    Boerseun, TheBeast and Watt maker like this.
  27. Mar 20, 2018 at 7:09 AM
    #477
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    I’m 6’1” and I have the seat all the way back when I drive a Corolla.
  28. Mar 20, 2018 at 9:00 AM
    #478
    TheBeast The Beach
    they gave me a Nissan Sentra :facepalm::facepalm:
  29. Mar 20, 2018 at 1:51 PM
    #479
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I drove off with a 3/4 ton 4x4 Cummins, because I showed up with a trailer, because sometimes I pull a trailer.
    Boerseun, blizz86, ColoradoTJ and 3 others like this.
  30. Mar 20, 2018 at 8:14 PM
    #480
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Keep us updated on how the repair goes.
