CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Mar 21, 2018 at 2:53 AM
    #481
    Adam New Member
    Thats a good idea to get a truck as a loaner. Just pull my boat behind as I am dropping it off.
    Watt maker and Wynnded[QUOTED] like this.
  2. Mar 21, 2018 at 6:18 AM
    #482
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Coincidentally, it was legit. I was bringing my motorcycle in to the dealer for a couple TSBs.
  3. Mar 21, 2018 at 9:12 AM
    #483
    shopdogguy
    shopdogguy New Member
    Bozeman, MT
    2023 Tundra Platinum Hybrid
    Lomax Stance Tonneau Cover RB20 Slim Running Boards Window Tint Bedrug
    Just curious, and sorry if this has already been answered. Those of you who have been getting the leak, what have your oil change intervals been? TIA
  4. Mar 21, 2018 at 12:03 PM
    #484
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I change mine every 5,000 miles. Intervals has nothing to do with it. It is just a combination of a poor design and poor assembly procedure.
    Blueline, 757TUNDRA, T-Rex266 and 2 others like this.
  5. Mar 21, 2018 at 3:56 PM
    #485
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I saw online some people came up with the theory of oil type, but that seems to not be the case either. This is bad design and poor assembly/ quality control on Toyotas part as @Atomic City Tundra stated.
  6. Mar 23, 2018 at 2:09 PM
    #486
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Just picked up my truck. They had it from Tuesday morning and finished the job earlier today. I confirmed they did both sides based on the black sealant on both engine banks. Let’s hope this never happens again.
    equin, Watt maker, TheBeast and 2 others like this.
  7. Mar 23, 2018 at 5:36 PM
    #487
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Nice, lucky to have both sides done.
    Make sure to check your oil level and don't forget to change oil in about 200miles.
    Upgrayedd[QUOTED] likes this.
  8. Mar 23, 2018 at 7:21 PM
    #488
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Yeah I was thinking of doing an oil change pretty quick.
    Very happy to have my truck back after being in that RAV4 all week.
    Watt maker, Y0TA PR0 and TheBeast like this.
  9. Mar 24, 2018 at 6:11 PM
    #489
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Recently purchased mine used with 57k. After reading about the issue here, took it to my local dealer. They said both sides had minor leaks. Tore into it the next business day fixed it and assured me it wouldn't leak again. No cost to me, powertrain warranty covered it.
    Awesome customer service Toyota!
  10. Mar 24, 2018 at 6:48 PM
    #490
    TheBeast The Beach
    right on time before you hit 60K :)
    Hondoman[QUOTED] and Y0TA PR0 like this.
  11. Mar 24, 2018 at 7:17 PM
    #491
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Yup
  12. Mar 24, 2018 at 7:46 PM
    #492
    tundrathr0w
    tundrathr0w New Member
    2018 Silver Sky Metallic Tundra CrewMax 4x4 5.7L
    I'm about to buy a new Tundra and I was planning on getting the underside sprayed by Linex. Is that going to impact the access or ability to fix the cam tower leak, if my Tundra turns out to have the problem?
    Y0TA PR0 likes this.
  13. Mar 24, 2018 at 7:54 PM
    #493
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome!
  14. Mar 25, 2018 at 4:14 PM
    #494
    tundrathr0w
    Thanks all for the friendly welcome!
    Another question, I read through this thread but apologies if I missed this: if the oil is not dripping to the floor but just seeping out, what's the potential risk of just not getting it fixed? Seems like if the risk isn't that great, I'd rather not have the engine ripped open to fix it? Along the same lines, what are the potential risks of having the engine ripped open to fix it?
    Thoughts?
  15. Mar 25, 2018 at 4:20 PM
    #495
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Mine was barely seeping (had to look hard to find it). No smell or smoke, but I wanted it repaired under warranty before it became worse. My understanding is that it usually starts about 60k.
    NewImprovedRon and TheBeast like this.
  16. Mar 25, 2018 at 4:37 PM
    #496
    tundrathr0w
    Hondoman, so it sounds like you felt like the potential risks of opening up the engine was worth fixing the tiny seeping? Are you not concerned that the dismantling and reassembly of the engine could introduce different/worse issues later on?
    Hondoman[QUOTED] likes this.
  17. Mar 25, 2018 at 5:05 PM
    #497
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Honestly, I didn't want to risk it getting worse after the warranty runs out (only 2.5k miles now) and either being out $3500 later or not having it repaired and potentially hurting the resale value.
    In this case, I think humans can do a better job than robots. As many trucks that have this issue, I'm confident they know how to correctly put them back together.
    tundrathr0w[QUOTED] and TheBeast like this.
  18. Mar 25, 2018 at 7:12 PM
    #498
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Really no telling if it will remain a seep or get worse, if mine wasn't leaking like it was I would have probably left alone vs. having things opened up like what had to be done.
    There really isn't a mileage it starts at, pretty much all over the place. One member in here had the leak at 580miles and I had mine at 21k...so somewhere between 0 and 60k I guess your could say.
  19. Mar 25, 2018 at 8:36 PM
    #499
    TheBeast The Beach
    I let mine go til I hit 58K, then I went to Toyota right before my powertrain warranty was up.
  20. Mar 25, 2018 at 8:46 PM
    #500
    tundrathr0w
    TheBeast, when did you first notice the leak? Why did you wait until 58K?
  21. Mar 25, 2018 at 9:15 PM
    #501
    TheBeast The Beach
    around 45K I would say. It didn't bother me. I probably had it on since 35 or 40K. I kept going back and forth on getting it fixed or not but eventually took care of it before I ran out of warranty after reading on this forum.
  22. Mar 26, 2018 at 7:58 AM
    #502
    whatsthehatch
    whatsthehatch New Member
    2017 Tundra CM SR5 4x4
    BAH! This is not want I want to see. I just got out of a 2017 F150 For engine issues! I have a New 2017 Tundra now that I will be checking for leaks... 888 Miles and don't have it yet. I sure hope to be a lucky one and not get it. I did a quick search at cars.com and there are several 330,000 plus mile 5.7 tundras out there so if we all have to have the work done then they surely did and it still performed...
    757TUNDRA likes this.
  23. Mar 26, 2018 at 8:41 AM
    #503
    Atomic City Tundra
    Devin
    New Mexico
    Mine started at 14K. I know several people that had them start leaking very early also. Not really a "time" when this occurs from what I have seen. Just that some do it, some don't.
    TheBeast likes this.
  24. Mar 26, 2018 at 8:58 AM
    #504
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    There is a poll on here. It has been getting more attention, but it could use a whole lot more votes. Forums can make a problem seem like an epidemic since most people turn to forums for advice or to search for others with their same problem.
    I'm not downplaying the cam tower leak, it is common enough that Toyota should have done something about it years ago to prevent future model years from continuing to suffer from a known issue. But by the numbers maybe it's not as common as we think.
    Everyone reading this thread daily should vote. I'm sure this thread has a dozen people starring through their front wheel wells every day.
    https://www.tundras.com/threads/ple...does-not-have-a-leaking-cam-tower-seal.21843/
    757TUNDRA and TheBeast like this.
  25. Mar 26, 2018 at 9:16 AM
    #505
    Do you need to stay in a 1/2 ton? I wouldn’t purchase anything in the 1/2 ton market besides a Toyota. That being said, most on here get pretty crappy fuel economy for a daily commuter anyway. I wouldn’t put a GM 3/4 ton off the list. Those are rock solid trucks with the gas power plant.
  26. Mar 26, 2018 at 9:58 AM
    #506
    Same exact experience with the trucks.
    Watt maker likes this.
  27. Mar 26, 2018 at 10:01 AM
    #507
    Good catch!
    I would be changing the oil filters out more frequently until you no longer see gasket material (2-3 times per oil change, top off fluids), and stick with the 5k oil changes as well.
    NewImprovedRon and Watt maker like this.
  28. Mar 26, 2018 at 12:41 PM
    #508
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
  29. Mar 26, 2018 at 1:43 PM
    #509
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I don't need to stay in a 1/2 ton, but if I get something that can tow more I'm just going to want to go buy something bigger to tow! But really, the Chevy 6.0L gas engine seems to get similar MPG to the 5.7L, so that's something to think about...
    I really do love my Toyota and am starting to worry less about this as time goes on. I'm honestly kind of waiting for the Tundra redesign. I'll probably wait until the gen 4 is a year or two old and then get into something else. My powertrain warranty will be good through Sept 2022, so if Toyota can manage to get the gen 4 out by 2020 I'll have some time to make a decision.
    Watt maker and TheBeast like this.
  30. Mar 26, 2018 at 2:20 PM
    #510
    whatsthehatch
    I had a 2500 HD 6.0 2wd that would barley get 12mpg on the highway. Mostly 9-10 mixed average.
