Cali Raised Led 32" Stealth Light Bar
Discussion in 'Lighting' started by Kevfran99, Oct 27, 2020.
  1. Oct 27, 2020 at 2:35 PM
    Kevfran99
    Kevfran99 [OP] New Member
    Kevin
    Lilburn, GA
    '19 TRD PRO
    TRD Rear Sway Bar - Front tint - Caliraised LED Fogs & Light Bar-Bed LEDs-Bed Cover-Wireless Charger
    Thank you! I'm extremely pleased with the quality from Cali Raised. I spent the extra time to wire everything right and zip tie it down. I love the factory button look from the inside.
    Piney[QUOTED] likes this.
  2. Oct 27, 2020 at 2:48 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    You could just mount this somewhere where it's not really seen. This is the regular switch it comes with. It has 2 sided tape on the back.
  3. Nov 11, 2020 at 7:39 AM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    Here's some pics of with regular headlights and then with the light bar on.
    with light bar on
    ManoTundra and drobb like this.
  4. Nov 12, 2020 at 6:31 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    15% off with November15 coupon code
  5. Nov 12, 2020 at 7:52 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    Aliens are coming....
    Kevfran99[QUOTED][OP] likes this.
  6. Nov 12, 2020 at 8:36 AM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    King's all around, Dirt Deeds 10" exhaust, 18x9 Method 305 NV, Falken Wildpeak A/T3W 305/65/18 tires, tinted windows (shhhhh)
    I don't have that exact same spot but I think mine would fit here. Would you have the same setup?
  7. Nov 12, 2020 at 8:40 AM
    TheBigTimpin
    TheBigTimpin New Member
    Great info. Thanks
  8. Nov 12, 2020 at 9:23 AM
    Captainjohn
    Captainjohn New Member
    2019 Tundra Dbl cab
    Rock sliders, topper, sliding bed
    I installed the same light bar on my 19 limited, looks and works great. I bought the back lit switch from them also, wasn’t on website at the time I ordered.
    I have the combo light bar,enjoy being able to lite up the ditches along side the roads.
    I hope that raised Cali has greatly improved their install instructions, because they were Terrible. I had to watch several other competitors sites/ YouTube to fill in all their missing information.
    CaptainGrumpus likes this.
  9. Jan 1, 2021 at 7:06 PM
    Blue93
    Blue93 New Member
    2018 Tundra
    Is this light about the same quality as the Diode Dynamics bar? I don't have experience with either and want to buy a good one.
  10. Jan 5, 2021 at 2:46 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    I can only attest to the Caliraised. So far it has been a good unit that I would purchase again.
  11. Jan 13, 2021 at 6:21 PM
    RX7
    RX7 New Member
    2021 Tundra TRD Pro
    Did you try it? Did the light switch end up fitting in the button slots under the climate controls?
  12. Jan 13, 2021 at 6:22 PM
    RX7
    RX7 New Member
    2021 Tundra TRD Pro
    I'm glad I'm not your neighbor...
  13. Jan 15, 2021 at 2:48 PM
    Kevfran99
    Kevin
    Lilburn, GA
    '19 TRD PRO
    lol. It is definitely a fun toy around the neighborhood and messing with friends.
  14. Feb 9, 2021 at 12:49 PM
    KTMRider
    KTMRider New Member
    Ken
    2020 Tundra
    No, haven't pulled the trigger.
  15. Feb 9, 2021 at 1:45 PM
    SNO BUS
    SNO BUS Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    I have had a caliraisedled lightbar sitting in a box with the included brackets for behind the bumper for like 2 years... could never figure out where or how the brackets mount to the truck. Any pointers?
  16. Mar 11, 2021 at 3:15 AM
    Buckwalleye
    Buckwalleye New Member
    2018 TRD double cab
    lmk if you want to sell it!!
  17. Mar 11, 2021 at 3:59 AM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    I put in a Lightbar switch under climate. It’s the same size switch blank
  18. Mar 11, 2021 at 4:31 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Bar looks killer.
  19. Jul 3, 2021 at 8:50 PM
    #49
    SNO BUS
    Nick
    Washington
    Hey guys. How’d you guys get this done? I have a Rough Country light bar and the Caliraisedled behind bumper brackets. Tried to do it a couple years ago (lol) and pulled the whole front end apart but couldnt get the crash bar bolt off, which i believe is what you mount this light bar to. Not sure if i was doing it wrong or not thinking hard enough, but i want to tackle it again with knowledge of how to do it correctly.
  20. Jul 3, 2021 at 8:58 PM
    #50
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I need to adjust the angle on my light bar, so I’ll try to take pics as I pull the bumper apart. Basic gist is: pull the grille and under-headlight trim pieces off, remove the splash guards behind the bumper end caps, remove the 4 12mm bolts (I think) from each end cap, then you should be able to pull the whole bumper off (caps and center valence). You might need a breaker bar to loosen the crash bar bolt that’s used for the mounting brackets.
    SNO BUS[QUOTED] likes this.
  21. Jul 3, 2021 at 10:14 PM
    #51
    SNO BUS
    Nick
    Washington
    I think that was my issue. I had a very limited set of tools when i was trying to do it and not enough leverage for the crash bar. I’d appreciate those pics tho!
  22. Jul 5, 2021 at 12:17 PM
    #52
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  23. Jul 25, 2021 at 7:37 PM
    #53
    SNO BUS
    Nick
    Washington
  24. Jul 25, 2021 at 7:40 PM
    #54
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :fistbump:
  25. Jul 25, 2021 at 8:41 PM
    #55
    MrYOTA
    MrYOTA LSU Fan'alyst
    Greg
    Bossier City, Louisiana
    2012 Tundra CrewMax SR5 T-Force
    That's how I want the front of my truck to look...
