C1310 code
Discussion in '2nd Gen Tundras (2007-2013)' started by chuck t, Feb 2, 2017.
  1. Feb 2, 2017 at 11:39 AM
    chuck t
    chuck t [OP] New Member
    2008 double cab
    none
    I have a trouble code C1310 ABS malfunction in HV. Along with this the VSC is flashing and the traction control indicator is on solid. Any body experience this?
  2. Feb 2, 2017 at 7:49 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Sounds like the AIP issue. Is that the only code you're getting?
  3. Feb 3, 2017 at 4:30 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    LOL, it's an ABS code. Not a powertrain code.
  4. Feb 3, 2017 at 4:36 AM
    caboose
    caboose -1
    somewhere in the USA
    tundra dc trd
    ride rites w/ air compressor, trd pro grille, decked bed storage, nfab rkr rails w/steps, remote start.
  5. Feb 3, 2017 at 5:08 AM
    Nor7
    The AIP issues for some reason always throw Trac control and vsc and 4x4 lights and codes. Search the forum if you don't believe me.
  6. Feb 3, 2017 at 5:27 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I believe you. The AIP malfunction also throws P-codes (powertrain codes). So far the OP has only reported an ABS code. 4x4 light wasn't mentioned either. Just working with tbe info provided.
