Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Aug 15, 2015 at 6:04 PM
    T-Rex266 [OP] Fuck Cancer Staff Member
    With the permission of @LOTSOFTOYS, he's agreed to let us have a "ask the Toyota mechanic" thread. For those of you who aren't aware, Jace "Lotsoftoys" is a local, Denver mechanic for Toyota. He is the only mechanic myself, and many, many TW.com guys let touch their trucks.
    No trolling.
    No arguing.
    If you ask a legit question - expect a legit answer or follow up question.
    Be patient. Like most members here, he has a F/T job, and life outside of the forums.
    *Note: He is trained to troubleshoot and fix stock Toyota parts. He isn't going to know the aftermarket items unless he has done them on his personal vehicle. You also need to understand that it is going to be very difficult for him to diagnose your exact problem without seeing your vehicle. He will do the best he can with the words you write. Pics or video may help as well.
  2. Aug 15, 2015 at 6:32 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Mechanic? Who's a mechanic? :bananadead::anonymous:
  3. Aug 15, 2015 at 6:41 PM
    Mike Tread lightly.
    south carolina
    Can of worms has been opened.
    Cg13055, Lupe, TRD-tv and 3 others like this.
  4. Aug 15, 2015 at 6:45 PM
    My only complaint is, "why did it take so long to make this happen"? :oldglory:
    Is it true that my 07 Tundra may actually have Brembo calipers? My 07 calipers are definitely 4 piston. @LOTSOFTOYS
    Is that because I have the 07 tow/haul package?
  5. Aug 15, 2015 at 7:25 PM
    I like legit responses that will actually help members here. No need to to jump in unless there is something to add that may actually help. Hate jump in trolls with only negative responses and do nothing to actually contribute to our Tundra ownership experience. If you want to "jump" in, at least be consistent and try to provide a positive experience for all of us here. (I know "it's the internet") It's like, "what came first, the chicken or the egg?" I have lived too long to argue over that scenario. Be positive. :thumbsup:
    Corndog123, p1ayn, 08TXTundra and 4 others like this.
  6. Aug 15, 2015 at 7:48 PM
    garnaz
    garnaz New Member
    2004 ToyotaTundra limited 4x4
    Tvip module: does this control door lock remotes as well as the security system?
    Remotes won't program. Factory or ebay cheapys.
    Installed aftermarket remotes with starter kill. Now alarm will go off every so often when I unlock remotely. Disable horn by unlocking manually.
  7. Aug 15, 2015 at 7:55 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I know right.... I blame Sean :)
    Replied in your quote
    avssuc, OR18TRD, Kilos and 2 others like this.
  8. Aug 15, 2015 at 7:59 PM
    It's all Sean's fault. @LOTSOFTOYS , You now have a non paying extra job. I am now working on my list of questions for you to answer. Thanks for "volunteering". Good man.:cheers:
    Cg13055 and sprtbkr like this.
  9. Aug 15, 2015 at 8:16 PM
    garnaz
    garnaz New Member
    Thanks Lotsoftoys for replying so fast.
  10. Aug 15, 2015 at 8:21 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The egg. Thanks button is at the bottom.:p
    Tomcat likes this.
  11. Aug 15, 2015 at 8:32 PM
    Thanks (No wait):annoyed:
  12. Aug 28, 2015 at 1:48 PM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    My 07 Tundra sits a lot now that I have a new Tacoma as my daily driver. I noticed that after it has been sitting for a week or so when I turn on the air conditioning there is an initial loud metallic knock sound (coming from the compressor?) and an unusual "drain" on the engine at idle just for a moment. After the initial "knock" it goes away and the AC works fine. If I drive it for a few consecutive days afterwards it isn't an issue. Is this a sign of a failing AC compressor or could it be a sign of something else like a serpentine belt?
  13. Aug 28, 2015 at 1:59 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Is the noise louder in the cab or in the engine bay?
    Coworkers Nisan Titan does that. He said it is the motor that opens the vents or switches between AC and heat. Something jammed in it. Try switching to heat to see if it makes the noise again or just on startup.
    Cg13055 likes this.
  14. Aug 28, 2015 at 2:02 PM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    Its definitely louder in the engine bay. I have to think it is coming from the compressor like it is seized for a moment and breaks free??? It only does it when I turn on the AC, not heat or just the fan.
    On a side note, I see you are in Broomfield. My wife is from Broomfield:)
    Cg13055 likes this.
  15. Aug 28, 2015 at 2:24 PM
    Moved to "ask the Toyota mechanic" thread.
    Cg13055 likes this.
  16. Aug 28, 2015 at 3:03 PM
    csuviper
    Broomfield, CO
    Sneaky, sneaky
  17. Aug 28, 2015 at 4:33 PM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    Oh, Thanks!
  18. Aug 29, 2015 at 8:36 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I'm sure it's the ac clutch just initially grabbing causing the noise. But ac works fine?
    Cg13055 likes this.
  19. Aug 29, 2015 at 1:47 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    I recently did my first oil change on my 2011 5.7 with 33,000 miles. I used full synthetic 0-20W valvoline, about 3 weeks later I began to see 3 or 4 drops of oil on the garage floor and could smell hot oil as if it was getting on the exhaust. At first I thought maybe I screwed up the oil change, but upon further inspection found both valve covers leaking! 1) Should I have used 5W-20W instead of 0W-20W? 2) When they change oil at the dealership what viscosity do they use? 3) Have you seen any other Tundras come in with this problem? I must add that the dealership is changing them out under warranty. Has anyone else on this forum had this problem with their truck? I appreciate your thoughts on this LOToys.
  20. Aug 29, 2015 at 4:56 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes I've seen that before. You are using the correct viscosity.
    My question to you though is...
    Are u sure it was the valve covers and not the cam towers?
    Cg13055 likes this.
  21. Aug 29, 2015 at 5:55 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    I guess you would call them cam covers as it is overhead cams, I am old school they used to be valve covers. I guess I was surprised that I was having this problem, as none of my Tacos ever leaked a drop of oil with many more miles on them. I appreciate your time LOToy's thank you.
    Cg13055 likes this.
  22. Aug 29, 2015 at 7:13 PM
    Tundrazy
    Tundrazy Turd Bro
    David
    '17 CM Cement PRO
    Yes, it works fine after the initial noise. i guess I will just ride it out and see what happens. Thanks all for the replies.
  23. Aug 30, 2015 at 7:24 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Try to take a couple pictures of the leak(s) and post them here. That may help clarify.
    Cg13055 likes this.
  24. Aug 30, 2015 at 7:45 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    No your right they are called valve cover gaskets. Cam towers are under the valve covers, on top of the cylinder heads
    Yip
    Cg13055 likes this.
  25. Sep 4, 2015 at 5:07 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    Hey @LOTSOFTOYS hope you can help me out.
    I have a '12 Tundra and getting a bunch of maintainer done.
    I bought the truck with 40k miles and it currently has 65k miles.
    I have never done anything with th tranny. I do quite a bit of towing 2-3k lbs.
    Can't find anything on the previous owner doing any tranny maintainer either.
    Should I just do a simple drain and fill method using WS fluid?
    Thanks in advance!
    Cg13055 likes this.
  26. Sep 4, 2015 at 10:15 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes you are spot on. Drain and fill it. Flushes arent necessary imo. Are u going to do it your self, I'd recommend having a dealer do it. Gotta use the scan tool....
    Cg13055, FundraTRD, 040Tundra and 2 others like this.
  27. Sep 4, 2015 at 10:35 AM
    CaptTyler
    Tyler
    @LOTSOFTOYS i could do it but probably will have a Toyota shop do it if you recommend it. Thanks for the help!
  28. Sep 4, 2015 at 1:12 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    If u could watch transmission temp I'd say u can do it. Draining and measuring how much comes out isn't a reliable way of doing it.
    Cg13055 and CaptTyler like this.
  29. Sep 4, 2015 at 7:20 PM
    Tundra 12
    Tundra 12 New Member
    12 tundra
    None
    Hey I was thinking to change my spark plug to laser ngk. I know Toyota used auto lite. Is that going to have any prob. Thank you
  30. Sep 4, 2015 at 7:40 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Probably not. I'm not a big believer of hp gains just because of spark plugs.... let us know how they work out!?
