Bumper LED reverse lights...
Discussion in 'Lighting' started by TTU19, Dec 13, 2016.
  1. Aug 16, 2017 at 12:40 PM
    #61
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    @TNTundra08 I have my reverse lights wired directly to the switch. I was too lazy to figure out this diode thing as I'm a newb and electrical projects scare me. Let me know what you figure out so one day I can rewire.
  2. Aug 16, 2017 at 12:45 PM
    #62
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    See mines the opposite mine is wired directly to the reverse light. Diode is super easy. Has one side with two plug Ins and other side only had one (two power in one power out) im just not sure if it's okay to leave the lights ground to the factory reverse light with the diode and button or if I need to run a ground along with the power wire along the truck to ground
    JC303[QUOTED] likes this.
  3. Aug 17, 2017 at 12:42 PM
    #63
    JC303
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I'm not sure. Hopefully someone chimes in
  4. Feb 29, 2020 at 8:28 PM
    #64
    Lee4x2Tundra
    Lee4x2Tundra New Member
    Isaac
    2017 White Tundra TSS
    Hopefully this can come back from the dead lol. Anyone have a complete write up on doing the lights into the reverse lights and a switch? I can read all day long and day I’m good to go! Buuuut more of a visual kind of guy. Thanks in advance!
    SuperWhitePro19 likes this.
  5. Mar 5, 2020 at 2:17 PM
    #65
    102dalz
    102dalz New Member
    Andy
    2017 Tundra CrewMax White
    None
    What type of "under bumper" lights were y'all using?
  6. Feb 4, 2022 at 5:47 PM
    #66
    SuperWhitePro19
    SuperWhitePro19 New Member
    2019 Trd Pro Tundra CrewMax
    Sitting on 275/65r18 duratracs, truxedo sport soft roll topper, home install bed lights
    Just finished installing flush mount LED pods in my bumper. I used a Dremel 3000 with metal blades to cut the bumper. Drilled the holes, painted the exposed metal to prevent rust, mounted the lights (Nilight from Amazon).
    I also bought a Nilight wiring harness that came with a relay pre wired and a cheap switch. I also purchased an OEM style switch. Wiring the lights was simple after extending the harness to length. The OEM switch came with four wires as shown compared to the harness’s three wires. Black to black, white to both reds (so the back light on the switch only activates when switch is engaged), red to green. Everything works great!
    bulldog93 likes this.
