BlueBottle's '16 Plat CM Build
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueBottle, Sep 24, 2016.
  1. Jan 11, 2017 at 9:35 PM
    #121
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    thx. yes agreed, if everyone did everything the same all our trucks would look the same!
  2. Jan 11, 2017 at 9:54 PM
    #122
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Nice Tits!
  3. Jan 12, 2017 at 5:55 PM
    #123
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    . Are those lights just bulbs or are they ballast driven? I want to change over but I'm not fond of the ballast... well I'm afraid of them
  4. Jan 12, 2017 at 7:02 PM
    #124
    BlueBottle
    '16 Platinum 4x4
    See fine print
    it has a tiny ballast but nothing like the one that comes in an HID kit. Also take a look at these.. at about half the price, Ive read that the performance is up to par with the Philips.
    http://www.xenondepot.com/H4-Xtreme-LED-kit-p/xt-led-h4.htm
    Don't get LED's bulbs expecting performance.. you won't be happy if so, I only like it because they get rid of the yellow tint and are not worst than the factory's.
  5. Jan 19, 2017 at 5:49 PM
    #125
    BlueBottle
    '16 Platinum 4x4
    See fine print
    dcsleeper408 likes this.
  6. Jan 19, 2017 at 8:35 PM
    #126
    Morgan51
    Morgan51 New Member
    2016 Inferno CM Tundra TRD
    I've been looking at getting one of those! They are pricey but look like they might be worthwhile. Do you stow the front wheel in the bed or the floorboard of the rear seats?
  7. Jan 19, 2017 at 8:44 PM
    #127
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I can store it in the bed since I have a bed mat(keeps it from moving around) or else I would put it inside.
    It is def a good way to transport your bicycle.
  8. Jan 27, 2017 at 10:45 PM
    #128
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So I finally found a solution for the lack of lighting on our mirror switch. Since I have a Platinum, I always use the power fold button. It is very difficult to find when its dark.
    I purchased this LED from https://www.superbrightleds.com/moreinfo/led-wired-bolts/little-dot-smd-led-accent-light/639/1929/ and it was only $2.99!
    It was the smallest LED I could find on SBL website. It is also attached to a very thin ribbon so I knew I would be able to mount it anywhere. It is actually brighter than I want it to be since I only want it as ambient lighting. It is the same reason why I opted for a red color. I was hoping it wouldn’t be too bright.
    Installation
    · Remove side sil (clips)
    · Remove driver kick panel (1 nut & 2 clips)
    · Remove 2 10mm bolts on the lower part of the lower dash panel
    · Pry lower dash panel off carefully(held on by clips)
    · Then I was able to push in the tabs for the switch panel to push it out.
    · I used the Brown wire on the headlamp adj for my 12v light source and used a ground bolt for the ground.
    · Ran the light out above the switch panel and used double side tape to on the ribbon onto the dash
    BE2B7C46-300E-42BF-A5B0-6B4BB3F90090_zps_039ff4cc98f6de20bf536495a11c3f068195282b.jpg
    5DCC8325-6CCF-4A30-96D4-F4B2C3B4D9A0_zps_d0db91e2a451fa2f14dc32c996562260db831a19.jpg
    2C78B092-F170-4AA5-A8DF-864F028924EB_zps_b088f9bea50c52ca7175dc4fdd4b363a3568ad94.jpg
    F8AB89D3-0F31-4F79-9F48-D09DEF4CA1F1_zps_76a94a0613252769235eb74769729681eb8fadfd.jpg
  9. Jan 28, 2017 at 12:35 AM
    #129
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    GREAT fix. Thanks for the how to...
    BlueBottle[OP] likes this.
  10. Jan 28, 2017 at 12:26 PM
    #130
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Nice! Wish Toyota would have made the switch light up like the other switches. I have to fold my mirrors in every day to park in the garage and it would be nice to add your mod. Thinking I would go with the blue version. I'm now wondering about getting a few more so I can illuminate the foot wells at night when the headlights go on. My old Acura RL had that and my wife complains since she is always dropping stuff around her feet and can't see.
  11. Jan 28, 2017 at 1:26 PM
    #131
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Just be careful. The blue will be super bright. The red is already too bright that is why I aimed it down. At first I put it facing sideways and the red was glaring against my window.
    Cat3ILS and Viper3G[QUOTED] like this.
  12. Jan 29, 2017 at 2:15 AM
    #132
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Great looking Tundra... One question? I really like the wheels but do they not come with center caps for rear wheels? That rust spot on the center of the rear wheel just does not cut it. Not a show stopper but it does stand out. Thoughts? for the coin they really should come with a center cap, it appears they did for the front. Again very nice looking Tundra.
  13. Jan 29, 2017 at 8:27 AM
    #133
    BlueBottle
    '16 Platinum 4x4
    See fine print
    They do come with caps but I prefer the look without the caps. I was planning on painting the rear black but just haven't had time yet. You can check out @dcsleeper408 buuld. He made the factory dust cap from the front fit the rear.
  14. Jan 29, 2017 at 12:12 PM
    #134
    Captquicksand
    Captquicksand New Member
    17 Tundra CW platinum
    What kind mpg you are getting with those tires, did it drop a lot?
  15. Jan 29, 2017 at 2:30 PM
    #135
    BlueBottle
    '16 Platinum 4x4
    See fine print
    With my current setup I avg about 14. When I was stock I saw 15-16. So it dropped 1-2 mpg.
    Captquicksand[QUOTED] likes this.
  16. Jan 29, 2017 at 2:38 PM
    #136
    Captquicksand
    That's not bad at all, I was avg 12 on my Tacoma with 33s. Do those tires make any noise?
  17. Jan 29, 2017 at 2:45 PM
    #137
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Zero noise. I'm pretty happy with it but I wish I would have gone with 35's instead. But they don't make these tires is 295/70.
  18. Jan 31, 2017 at 7:13 PM
    #138
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So I removed my flares just to change it up a bit. I think I like the no flare look better. Most likely will stay this way.
    If anyone looking to pick them up that's local send me a message!
    6B4C05C0-11D1-44F5-9E63-39EDEDF0A60A_zps_4e053b55e076765181f7efb3d37d9bc1a5cfdd2b.jpg
  19. Jan 31, 2017 at 7:15 PM
    #139
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Saw your flares on CL.
    dcsleeper408 and BlueBottle[OP] like this.
  20. Jan 31, 2017 at 7:20 PM
    #140
    BlueBottle
    '16 Platinum 4x4
    See fine print
    U want them? Friends & family discount!
  21. Jan 31, 2017 at 7:22 PM
    #141
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Did you see my nerf bars?? We can trade again. :rofl:
  22. Jan 31, 2017 at 7:29 PM
    #142
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Hmmm. Fender flares? Can't dicide if I wanna go there or not
  23. Jan 31, 2017 at 7:32 PM
    #143
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I saw them! If I didn't have my GoRhinos I might consider. Your steps only fit double cabs tho.
  24. Jan 31, 2017 at 7:34 PM
    #144
    BlueBottle
    '16 Platinum 4x4
    See fine print
    You can buy them, slap them on them then you can decide lol. But seriously PM me if your serious.
  25. Jan 31, 2017 at 7:37 PM
    #145
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I'm not a big fan of flares, but they actually looked really good on your truck for some reason. Maybe even better with them on. Why did you take em off?
  26. Jan 31, 2017 at 7:38 PM
    #146
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Looks good blue. :cool:
    I'm another fan of no fender flares. Sold mine on CL also.
  27. Feb 1, 2017 at 6:51 AM
    #147
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Those looked good on your truck, I like them 'cause they don't have the "rivets". I've got some other things that I wanna do before I start thinking about flares.
  28. Feb 1, 2017 at 5:21 PM
    #148
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yup. That's the reason why I went with these. No rivets. I want to keep the stock body lines which is why I removed them.
  29. Feb 3, 2017 at 7:40 PM
    #149
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Applied some matte black TRD Offroad bedside stickers from eBay.
    C3284220-AFF2-4060-9C28-3169E2C2A101_zps_87c430d7d5a9b150e3f12aeaf993507b5a640c5e.jpg
    1AF2D233-DDB3-42B3-8F3A-269175CEE096_zps_614e99d947f4ef04f45954599a5bc3b19611372e.jpg
    Bannock452 and dcsleeper408 like this.
  30. Feb 3, 2017 at 7:45 PM
    #150
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Nice and subtle! :thumbsup:
