BlueBottle's '16 Plat CM Build
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueBottle, Sep 24, 2016.
  1. Oct 31, 2016 at 10:25 PM
    #61
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Little sneak peak.......
    949ECC77-3355-46FD-AE2A-FD143D4A2CF4_zps_ef1f69e78da0a16e7d9f223cbd335fbc68ec10fd.jpg
    54C22950-703F-400B-876B-21E404E58128_zps_70ec053d8c6cea73d948ba9b0e20dd915aad6479.jpg
    r4z0r51o and dcsleeper408 like this.
  2. Nov 2, 2016 at 6:00 PM
    #62
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Installed some VLED V3 Triton 3157CK in red.
    The red is deeper and brighter than the oem halogens. The LED's fill the housing well unlike the cheap LED's that do not.
    I would say they are 25% brighter but the what I really like is the instant on/off of LED's
    http://www.vleds.com/shop-bulb-numbers/3157-3156-led/v3-kit-r-3157ck.html
    Driver side is the VLED and passenger is still oem on both pictures. Kept the camera on manual with same settings for both shots.
    Park lights only
    6CBD1062-C511-493F-A33F-217C481ECA9E_zps_a7cf04408e484ed837b610dac15200d96300fffd.jpg
    Brake lights
    F5FAF870-3440-47E0-8043-1149DB17D170_zps_8ccc02abf506f81a266c1b0d06e72a8ce0845ef0.jpg
    geno0506 and J4RR3N4 like this.
  3. Nov 2, 2016 at 6:15 PM
    #63
    BlueBottle
    '16 Platinum 4x4
    See fine print
    GAknight, R-C and dcsleeper408 like this.
  4. Nov 2, 2016 at 6:19 PM
    #64
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Let's see a side view of the new flares. Nice work!
  5. Nov 2, 2016 at 6:38 PM
    #65
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Ill try to get some this weekend. Thanks!
  6. Nov 3, 2016 at 6:21 PM
    #66
    BlueBottle
    '16 Platinum 4x4
    See fine print
  7. Nov 3, 2016 at 7:09 PM
    #67
    14tundra
    WI
    Looks good man! I'm going to clean mine up and take some decent pics this weekend.
  8. Nov 5, 2016 at 9:54 AM
    #68
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So after, driving about 1,000 miles on the new suspension/wheels/tires I wanted to do another quick review. The ride is actually better than stock, most likely due to the bigger sidewall of the 18's and taller/bigger tire. Even the wife noticed a much more compliant ride on-road. Have yet to take it off-road and have no immediate plans to at this time. Have no regrets getting spacers(since this truck see's mainly concrete and asphalt). Once my shocks do wear out, I will def be going to coilovers though. Just to have an upgrade on ride quality.
    I also recently made new measurements of my suspension lift to show how much lift I got after everything settled.
    Just to recap my suspension setup
    • Front - LRO 3" spacer w/ stock shocks
    • Rear - CB +3 Shackle w/ stock shocks
    • 18x9+12 with 305/65/18 Falken Wildpeak AT3
    Measurements from center hub to bottom of my Bushwacker Fender flares are:
    FL : 24.11" FR : 24.50"
    RL : 24.89" RR : 24.89"
    So as you can tell i have about a 1/2"-3/4" Rake on the truck with this setup.
    I have the lift numbers from before my lift but unfortunately those are before my bushwackers so the measurements will not be accurate. I think the bushwacker fenders sit a tad bit lower than the oem fenders. If anyone can confirm, that would be great to know.
  9. Nov 5, 2016 at 10:03 AM
    #69
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    Are they colormatched?
  10. Nov 5, 2016 at 10:06 AM
    #70
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @ReCKzX No they are not. I just put them on straight from the box. I will get some quotes to color match and do it once funds permit. I actually do not mind the contrast at this time but I'm sure it will eventually be color matched.
  11. Nov 5, 2016 at 10:12 AM
    #71
    ReCKzX
    ReCKzX New Member
    Gotcha. It was hard to tell. They look good, but I think they would look better colormatched.
  12. Nov 5, 2016 at 5:25 PM
    #72
    JazzSR5_Tundra
    JazzSR5_Tundra New Member
    2014 Black Tundra SR5
    KNN 6 series cold air intake/custom dual exhaust w/ magnaflow muffler and exhaust tips/Raptor series running boards (black).
    Did you notice any improvements or negative impacts afterwards?
  13. Nov 5, 2016 at 8:39 PM
    #73
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Nothing but positive. The way it was before I would have sold the exhaust. I couldn't stand the drone. This exhaust actually sounds really good chopped after the axel.
  14. Nov 6, 2016 at 7:31 PM
    #74
    BlueBottle
    '16 Platinum 4x4
    See fine print
    iPhone Pic
    Also got Huper Optik 35% tint to the 2 front windows.
    20806054-358D-4BEE-B750-082A6358B477_zps_93f51b0cd86a58c492dde884121eafb139984b08.jpg
  15. Nov 6, 2016 at 7:33 PM
    #75
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Damn she's looking good man. The flares really complete it.
  16. Nov 6, 2016 at 8:18 PM
    #76
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I really wanted the flares color matched but did not want to pay to have them painted so I just slapped them on.
    They actually look better than I though they would. I think if my truck was white it would be different.
    zcarpenter92[QUOTED] likes this.
  17. Nov 6, 2016 at 8:54 PM
    #77
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Agreed, generally I like em un-paint matched if the pickup is a dark color.
  18. Nov 13, 2016 at 1:51 PM
    #78
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Do you have any pictures of what you had to trim on the rear
  19. Nov 16, 2016 at 7:43 AM
    #79
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Sorry Dustin I saw this a little late... but hopefully this picture will help others following this thread and answer some trimming questions.
    I trimmed part of the metal fender at an angle and the plastic fender also the CMC. No rubbing with 35" with18x9 +18 offset.
    J4RR3N4 and dcsleeper408 like this.
  20. Nov 23, 2016 at 2:39 PM
    #80
    BlueBottle
    '16 Platinum 4x4
    See fine print
    AJT Design aluminum fob case
    I couldn't decide red or black so I bought both =)
    Constructed very well. Red one is machined finish and black is matte. I prefer the matte between the two but both are very nice.
    B66D35B5-E50A-48EE-88F5-1DFEF8527EB3_zps_dab872855c3fce834f53a4f09376168f4a647219.jpg
    36539664-C7C6-426B-9C83-690D3BB775B2_zps_60578d743d95d8aa2a18eb28e0716de530344634.jpg
  21. Nov 23, 2016 at 4:15 PM
    #81
    Martin Rolka
    Martin Rolka New Member
    Martin
    2014 Tundra Crewmax Limited
    Are those fob cases smaller or lighter than the original Toyota, really wish the original was smaller!
  22. Nov 23, 2016 at 4:56 PM
    #82
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It's about the same size but it is more square than the oem unit. I'll take a comparison photo later.
    + they are a little heavier due to being aluminum. But not heavy by any means.
  23. Nov 24, 2016 at 5:08 PM
    #83
    Martin Rolka
    Martin
    And I love those wheels, Truck looks great! Have a MGM Limited Crewmax With the NFab nerf bars with 3/1.5 Toltec Boss Lift, used the stock wheels with spider trax wheel spacers. Your truck looks great!
    T-Rex266 and BlueBottle[OP] like this.
  24. Nov 24, 2016 at 8:32 PM
    #84
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks. I'm planning on getting the Boss kit once my shocks wear out.
    I'm looking for some high clearance steps. Was looking at the NfAbs but they look like they hang pretty low. First option at this time are the gorhjno rb10's.
    T-Rex266 likes this.
  25. Nov 25, 2016 at 6:37 PM
    #85
    R-C
    R-C http://101financial.com
    Ryan
    Las Vega$
    2017 TRD Pro
  26. Nov 25, 2016 at 10:33 PM
    #86
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have not yet changed any of my signals. Rule of LED signals are, you do need resistors if you will be going LED's. I almost bought some LED signal bulbs from VLED's but I bought other stuff instead. So LED signals will have to wait for now.
  27. Nov 25, 2016 at 10:49 PM
    #87
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    How is your reception compared to the OEM one. I've been contemplating one of these but don't want to lose range.
  28. Nov 25, 2016 at 11:04 PM
    #88
    BlueBottle
    '16 Platinum 4x4
    See fine print
    it is definitely shorter but still very usable. I measured about 8-9 stall spaces away it worked so I'm guessing thats about 100ft away. I will try to measure the distance a little better but so far it hasn't bothered me. If I had remote start, it may bother me but for unlocking/locking the truck, it's good enough.
    gosolo and Tundra Fan[QUOTED] like this.
  29. Nov 26, 2016 at 1:13 PM
    #89
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Just read the thread. You have really built a nice looking rig. The quality of your pictures makes it a lot of fun too!
  30. Nov 26, 2016 at 5:39 PM
    #90
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thank you.. i know a picture is worth a 1000 words so I try to show it. Trying to document mods that I don't see much about. Hopefully help out future & current members.
    dcsleeper408 and gosolo[QUOTED] like this.
