BlueBottle's '16 Plat CM Build
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueBottle, Sep 24, 2016.
  1. Sep 24, 2018 at 7:22 AM
    #661
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Looking good!
  2. Sep 24, 2018 at 10:37 AM
    #662
    SCSPerformance
    SCSPerformance #teamstealth Vendor
    Vin
    Bay Area, CA
    HOTNESS!!!
    BlueBottle[OP] likes this.
  3. Nov 12, 2018 at 11:55 AM
    #663
    Dark Knight
    Dark Knight New Member
    Bill
    2016 Black Tundra Crewmax 4wd
    Ordered mine today!!!!
  4. Nov 22, 2018 at 11:02 AM
    #664
    froggy78
    froggy78 Loco Moco Bastrd
    JP
    SF Bay Area
    1794 TRD
    Show me those pics of the front grill, again.
  5. Nov 22, 2018 at 11:21 AM
    #665
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    TheBeast, 831Tun and Pudge like this.
  6. Nov 22, 2018 at 11:22 AM
    #666
    froggy78
    JP
    SF Bay Area
    1794 TRD
  7. Nov 22, 2018 at 11:23 AM
    #667
    BlueBottle
    '16 Platinum 4x4
    See fine print
  8. Nov 27, 2018 at 11:34 PM
    #668
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Got a 42” Light bar from diode dynamics over Black Friday. Was a complete kit with brackets and relay wiring harness with switch. Extremely happy with these lights especially for how much they were.
    Headlights are 2018 Oem led
    Fogs are Baja Designs Squadron Pro in wide cornering
    1C329653-7FA6-4161-B52B-F79240D87DA1.jpg 67C8BB3A-0C78-4F69-8721-D594FF64812B.jpg 639476C3-16B2-4AB7-8995-42E1D8C5AB6D.jpg 264C1362-B2F1-4696-B71F-872C4D23EECD.jpg BD8C46F5-DB06-4AAD-8BC8-D15FFC91F635.jpg D94B3344-8C0D-4968-A53E-474BCB3046F9.jpg
  9. Dec 29, 2018 at 7:48 PM
    #669
    InfernoPro15
    InfernoPro15 New Member
    Hey awesome build. Question, after switching to 2018 headlights with new harness did you have to relocate "raptor lights" connection?
  10. Dec 30, 2018 at 9:34 AM
    #670
    BlueBottle
    '16 Platinum 4x4
    See fine print
    No. The park lamp is still the same wire. If you have a harness for the new headlights I would tap it from there though so your original harness remains untouched.
    831Tun and InfernoPro15[QUOTED] like this.
  11. Dec 30, 2018 at 10:18 AM
    #671
    InfernoPro15
    Good idea, thanks.
  12. Jan 13, 2019 at 10:30 PM
    #672
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Played with the Carly app with the tundra. You have to purchase their WiFi adaptor to use it. It’s for ecu diagnostics and to turn features on/off. Thought I’d share it in case anyone is interested in it.
    https://youtu.be/ElHIEXFiQ-I
    831Tun and dcsleeper408 like this.
  13. Jan 15, 2019 at 11:57 AM
    #673
    Juddrussell
    Juddrussell New Member
    Jacob
    Bentonville, AR
    2016 MGM Tundra TRD Pro
    BAMF Bedrack, 295/70/r18 General Grabbers, Bedslide, Weathertech floor mats, and Tepui Autana Sky RTT.
    Bluebottle, I love your truck. Thanks for sharing all the goodness
  14. Jan 24, 2019 at 10:27 PM
    #674
    caguilera21
    caguilera21 New Member
    Christian
    California
    Hey Blue. how is your Toytec Kit holding up? I'm considering Toytec or BDS for a 3" lift but have heard a few negative reviews from Toytec. Would love to be able to go Toytec because they are cheaper than BDS but don't want to risk purchasing a "bad" kit from Toytec. Thanks!
  15. Jan 25, 2019 at 6:32 AM
    #675
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I love em. I have the radflo versions so they are higher end then the regular toytec boss. Rides so smooth. No problems. I wouldn’t hesitate to buy again but if I had the moneys I would go blue.
    831Tun, zcarpenter92 and RoujePN like this.
  16. Feb 7, 2019 at 11:29 AM
    #676
    kw819
    kw819 New Member
    not sure if you mentioned but how are your raptor lights mounted? i have mine held on with zip ties, but looks like yours arent
    RoujePN likes this.
  17. Feb 7, 2019 at 12:42 PM
    #677
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Double stick tape!
    dcsleeper408 likes this.
  18. Feb 7, 2019 at 1:21 PM
    #678
    kw819
    kw819 New Member
    nice!! no movement or issues with that?
    Rica25 likes this.
  19. May 22, 2019 at 3:12 PM
    #679
    ktmsmitty
    ktmsmitty New Member
    Ed
    Murfreesboro, TN
    2019 Toyota Tundra SR5
    Coming REAL soon.............
    I’ve got my crosshairs trained on this setup! Sounds great thank you for the video and sound.
  20. Jul 30, 2019 at 7:32 PM
    #680
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Been a while with no update.
    Installed a kenwood Excelon dmx906s headunit w maestro rr module. Connects to the trucks can bus system to grab the trucks data. Comes w wireless Apple carplay. Also made my speakers from @james@tech12volts sound better. Bought everything needed for install from James.
    7F6D24BD-027C-424C-9EA1-480E97911E13.jpg 44C0EEF9-2189-49F7-8A6A-752625F41D72.jpg A076F476-B25F-427B-8AD9-A994A26C2941.jpg
    Also put on a tailgate mat. Should have done this long time ago! Tired of hurting my knees climbing up there.
  21. Jul 30, 2019 at 10:11 PM
    #681
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  22. Jul 31, 2019 at 5:19 AM
    #682
    Stig
    Stig New Member
    Just a tip. Youcan tuck that tailgate pad under the plastic trim at the top of the tailgate. Looks factory and stays put! Just remove the plastic fasteners and lift the lip to tuck the mat in.
    Rica25 and BlueBottle[OP] like this.
  23. Jul 31, 2019 at 6:26 AM
    #683
    BlueBottle
    '16 Platinum 4x4
    See fine print
    :cheers:
    Wow I didn’t think of that. But I placed the hook and loop on the plastic so I can’t do that now.
    How do you clean this material? What do you use to clean/maintain it?
    dcsleeper408[QUOTED] likes this.
  24. Oct 3, 2019 at 9:10 PM
    #684
    canadianguy
    canadianguy New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    How do you like the Toyo tires over the Falken tires? In different weather conditions? Ride?
    Rica25 likes this.
  25. Dec 15, 2019 at 3:55 PM
    #685
    BlueBottle
    '16 Platinum 4x4
    See fine print
    sorry I missed this. The Toyo’s feel better driving around. I think they are lighter. I had no complaints with the flaken’s except they got flat spots easily and I felt them driving for a few miles before they go away. I’m happy with the Toyo’s but would still recommend falkens if that’s what budget allows.
    Rica25 likes this.
  26. Dec 15, 2019 at 3:59 PM
    #686
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I’ve had these ring covers from @Adam AJT DESIGN for a while but just installed it today. This is great way to get rid of that chrome rings and will match my new AJT console trims!
    5AF4068C-DC51-403B-AC63-2D651A55CBC8.jpg 54C53F22-6BFD-4E5B-B46B-74AE07D0EFF4.jpg
    831Tun and Rica25 like this.
  27. Dec 22, 2019 at 3:19 PM
    #687
    nowayout
    nowayout New Member
    NY
    15 Dbl
    @BlueBottle is there an option on the Kenwood to turn the screen completely off?
  28. Dec 22, 2019 at 8:30 PM
    #688
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yes. I believe all headunit do.
    nowayout[QUOTED] and Rica25 like this.
  29. Feb 6, 2020 at 7:17 PM
    #689
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Some more goodies from @Adam AJT DESIGN
    he has some high quality stuff for sure.
    PS : I have a TRD pro shift knob for sale if anyone is interested. Silver $65 shipped conus
    D3FE81E2-D0C8-45EE-830A-72446C0FD958.jpg 85B84D86-9796-4D62-AA52-78F16D0B3AA1.jpg
    GAknight, TheBeast, 831Tun and 2 others like this.
  30. Feb 6, 2020 at 7:41 PM
    #690
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    nice! Was it easy to change it out?
