BlueBottle's '16 Plat CM Build
Discussion in '2.5 Gen Builds (2014-2021)' started by BlueBottle, Sep 24, 2016.
  1. Sep 27, 2017 at 2:07 PM
    #271
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I do which is why I've always tried to do my mods in good taste, not over top, not trying to result in down the road issues because of them. Very true on ur toyota statement, even when I change something I try to make changes that don't change too much from how the vehicle was originally intended. Hence pro rims bigger tires, stock light housings just tint the white in them, ect.... I try to just make it better without changing it too much. Which is all reasons I like idea of 18 led. But, the out put in low beam I feel I need upgraded. I'm using my BD s8 on a in cab swirch as my highbeams around town and so far love it. Problem is when I go from that down to low beam I struggle to see at night. I fed need to do something decisions decisions. Soon as I decide retro I find a reason to go 18? I guess it's no different than any other thing I've added or changed on my truck. I obsess over the decision for a while then add it to the list of way too much money I've spent on doing stuff to it list.
  2. Sep 27, 2017 at 5:08 PM
    #272
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Well if total output is what you are after then go with retrofits. HID retrofits to be specific. you will be happy with the results. Since you are used the your S8's, I think the '18 LED's might not be bright enough for you.
  3. Sep 27, 2017 at 5:16 PM
    #273
    TheBeast The Beach
    looks great ! love the parking lights. which philips LEDs were you using before ? I need some for my gen 2....:cookiemonster:
    BlueBottle[OP] likes this.
  4. Sep 27, 2017 at 5:56 PM
    #274
    BlueBottle
    '16 Platinum 4x4
    See fine print
  5. Sep 27, 2017 at 7:32 PM
    #275
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Always coming through with some awesome photos! Thanks for sharing the headlights and output. Truck is looking really good man!
    MotoTundra and BlueBottle[OP] like this.
  6. Sep 28, 2017 at 2:22 PM
    #276
    bluecrush
    bluecrush New Member
    Do you need resistors in any of these? The Rear Tail/Brake lights are not available anymore from VLEDs. However, they do have a V6 coming out next month. Do you need a resistor to use this as a tail light to avoid the hyperflash, or is that only for blinker lights? (new to this)
  7. Sep 28, 2017 at 3:33 PM
    #277
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Only blinkers. I ordered a set of the V6's for my front blinker and added their resistor.
    dcsleeper408 likes this.
  8. Sep 28, 2017 at 3:35 PM
    #278
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So the Wife said "put some wheels & tires on my Jeep!"
    So I did ...
  9. Sep 28, 2017 at 6:24 PM
    #279
    moviepro314
    moviepro314 New Member
    Iowa
    2017 Tundra Platinum
    Line-x Premium Spay-on bed liner, Truxedo Lo Pro Roll-up Tonneau Cover, Dual Swing Cases from Undercover, Pop & Lock Power Tailgate Lock, BottlePro 2
    How's the reception with this antenna? Did you notice a change at all?
  10. Sep 29, 2017 at 10:32 PM
    #280
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Very minimal loss. Not noticeable enough to swap it back.
    moviepro314[QUOTED] likes this.
  11. Sep 30, 2017 at 9:33 AM
    #281
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Baja Designs and joonbug like this.
  12. Sep 30, 2017 at 9:35 AM
    #282
    mgm16trdpro
    Northern NJ
    Nice sports with fog pocket kit. I can't wait to get mine. What lens wide corner or something else, and what u think of them?
  13. Sep 30, 2017 at 9:36 AM
    #283
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Wide cornering in amber. Don’t know yet. Still installing them! And plus it’s daylight still. Will update later tonight with pics of course. But so far impressed with quality.
  14. Sep 30, 2017 at 9:46 AM
    #284
    mgm16trdpro
    Northern NJ
    Awesome glad to hear. That's exact setup I've been very patiently waiting for. I'm trying to prioritize and it's not far down the list. A tune, lighting and some small cosmetic upgrades is all I got left to do. Definitely keep me informed on how u like. I plan to run on street at night and if u remember I'm looking to get better output on road outside the use of s8. Glad someone who's knowledgeable got exact same I've been saying I was getting ahead of me so that I can rely on your input and review before I pull trigger myself, thinking tax time.
  15. Sep 30, 2017 at 10:14 AM
    #285
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Sneak peak. Pointed the fog as low as possible. Still has some glare. From what I see his may be off-road lights only!Morimoto on passenger side.
  16. Sep 30, 2017 at 10:21 AM
    #286
    mgm16trdpro
    Northern NJ
    Technically they are only for off road, but I've heard of others getting away with on all time. I'm planning to run always, maybe point out slightly might help more.
  17. Sep 30, 2017 at 10:24 PM
    #287
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Took pictures of the final product. Very satisfied with the brightness of these lights. And its not even the PRO's!
    Headlights : 2018 LED lights
    Fogs : BajaDesigns Squadron sports w wide cornering amber lens
  18. Sep 30, 2017 at 10:38 PM
    #288
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Paul...I told him the same thing. His truck was actually what sold me ona Tundra. I found a pic online and it brought me to this site. I've been gawking ever since. Total class is what I think of every time I see a picture of this truck
  19. Oct 1, 2017 at 7:10 AM
    #289
    BlueBottle
    '16 Platinum 4x4
    See fine print
    So sweet of you lol. :cheers:
    Maybe it's my picture taking skillz that lure people in hea
    :worthless:
  20. Oct 1, 2017 at 8:33 AM
    #290
    Eclipsed & Floating
    Voluptuous Whitey
    Incorrect my friend! It's your extremely good looking truck. I've told you before that your truck is what made me buy a Tundra. :thumbsup:
    It's beautiful, classy, and a step ahead of me at all times
  21. Oct 1, 2017 at 8:46 AM
    #291
    BlueBottle
    '16 Platinum 4x4
    See fine print
    :hattip:
  22. Oct 2, 2017 at 1:21 AM
    #292
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Damn man I didn't want the new headlights before, but you've made me reconsider! :thumbsup:
  23. Oct 2, 2017 at 5:56 AM
    #293
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It’s only money! If you still have holegens you need to swap out! ‘18 leds or retros.
  24. Oct 2, 2017 at 11:02 AM
    #294
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Those lights should work very nice in our Nor Cal fog. :thumbsup:
  25. Oct 2, 2017 at 11:08 AM
    #295
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thats what i was thinking! cant wait to test it out! I kind want to do the anytime fog mod but I hate cutting factory wiring. Might wait till I get switchpros and just connect my fogs to that.
  26. Oct 2, 2017 at 8:19 PM
    #296
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yes the Siriusled is slightly lighter. A little pinkish but not bad enough to bother me. I think it’s good enough for not needing to add resistors. I would buy them again. I don’t like the vlr Pro resistors because you need to tap into your factory harness for the 921 lights.
  27. Oct 2, 2017 at 8:23 PM
    #297
    BlueBottle
    '16 Platinum 4x4
    See fine print
    My interior led lights bugged me because they were 6k and the blueish tint was starting to get annoying. So I ordered the new vled 5k 194 bulbs.
    The white ones are from superbrightled and black are vled.
    The left light is vled and right is sbl. The sbl is so Blue it makes the vled look yellow even though it’s pure white.
    Really happy with the switch. Highly recommend vled 5k led bulbs if you want the pure white light.
    silverhack, T500 and TRON like this.
  28. Oct 2, 2017 at 8:30 PM
    #298
    Tundra Fan
    Toby
    Seconded. My last car had the blueish white lights and I wanted to stay away from that this time. When I ordered all my LED's I tried to stay in the 4500-5500 range. I really like the bright white glow. :cool:
  29. Oct 2, 2017 at 8:35 PM
    #299
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Which bulbs did you go with?
  30. Oct 2, 2017 at 8:49 PM
    #300
    Tundra Fan
    Toby
    All my interior bulbs except the vanity mirrors came from superbrightleds. I picked the "natural" color over the "cool". The other bulbs I ordered from vleds and picked 5k. All of them are a bright clean white. The puddle lights I replaced with the ones you found. No color option choice there, had to go with what they had, but I'm very happy with them. The stock puddles sucked.
    I don't remember where I got my license plate lights, but it was from one of those two after the freebies that came with the puddle lights crapped out.
