Blue smoke blues??? UPDATE: Dealer states failed PCV
Discussion in '2.5 Gen Tundras (2014-2021)' started by darkknight2014, May 1, 2018.
  1. May 7, 2018 at 4:12 PM
    darkknight2014
    darkknight2014 [OP] Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Well the total cost was $548 which i payed because toyota only told them it was a pcv valve. So i got home and called the warranty place who then called toyota and now $348 is on them. I added the throttle body cleaning plus i have to pay for the $7 for the pcv lol but the rest is all warranty.
    15whtrd likes this.
  2. May 7, 2018 at 4:23 PM
    Sunnier
    Sunny
    San Diego, CA
    548
    - 348
    - 7
    Mod$ :headbang:
  3. Jan 14, 2019 at 6:56 PM
    Tundragrey16
    Tundragrey16 New Member
    2016 tundra 5.7 crewmax
    None
    I have been getting blue exhaust smoke on cold starts. Not everyday, but most. Truck is 2016 5.7 FFV, has 63,XXX miles, and has been maintained by toyota for all service. I took the truck into toyota and they told me it was normal and could not duplicate. I replaced the PCV valve and that did not make any difference. Old pcv valve seemed as if it were functioning just as the new. I asked toyota about a TSB or an update and they said that they do not have any updates for it. I researched oil separator and I am not sure If I can tackle intake removal on my own to install. Truck seems to start and run with no problems. Has anyone besides Darkknight201 gotten resolution from replacing the PCV and Oil separator both?
  4. Jan 14, 2019 at 7:06 PM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Had the same issue and replaced the valve with no luck. What fixed it for me was changing the oil a few times.
  5. Jan 14, 2019 at 7:13 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    What brand and weight did you change to? And what oil were you running when it was smoking?
  6. Jan 14, 2019 at 7:22 PM
    Tundragrey16
    None
    They changed my oil again today while they did the check on my exhaust blue smoke that they could not duplicate. They are using the synthetic oil for mine.
  7. Jan 14, 2019 at 7:40 PM
    Tundragrey16
    None
    Maybe I need to not worry and it will work itself out on its own as Norfolk757 mentioned.
    Norfolk757 likes this.
  8. Jan 16, 2019 at 3:54 PM
    Norfolk757
    Tom
    Norfolk, VA
    The issue with mine was the truck was traded in to a domestic truck dealer and those geniuses changed the oil with regular conventional service. After going crazy and changing the valve it was an OEM oil change that fixed my issue. I had to have my engine oil flushed as well.
