Bizarre Window/Lock Issue
Discussion in '1st Gen Tundras (2000-2006)' started by mojo73, Oct 18, 2021.
  1. Oct 18, 2021 at 10:52 PM
    mojo73
    mojo73 [OP] New Member
    2004 White Tundra SR5
    The driver's controls for the other doors' power windows and locks only work when the driver's door is open. When the door is closed, the controls only work for the driver's lock and window. The door key will also not unlock the other doors if the door is closed. When the door is open, everything works normally.
    Any suggestions?
  2. Oct 18, 2021 at 10:58 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'm no mechanic, but I'd say you got a bad wire connection in the door.
    Pull the window control out and make sure it is securely plugged in.
    Also pull the door panel off and check for any frayed or worn wiring..
    Since it is more than one issue, it may be a bad ground.
    It may get down to using your DMM and start testing wires in the connectors.
    THinTX likes this.
  3. Oct 19, 2021 at 8:11 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Two things:
    One, pop out the window switch as it can be removed without taking anything else out. As LL said, make sure the connection is good. While there, reach your hand inside and jiggle some wires to see if you can get to act up or work.
    Two, the wires that run between the door and the boy through the boot. I had a weird door ajar switch issue and that's where my issue was.
    THinTX likes this.
  4. Oct 19, 2021 at 8:51 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    The only thing I will add to the above two good comments is look closely at any soldered joints/connections. Old solder becomes brittle with age and vibrations and can and does crack.
  5. Oct 19, 2021 at 8:59 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Echo checking into the harness passing from the body into the door. Most likely a bad connection in there.
  6. Oct 19, 2021 at 9:02 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Does it have the Factory alarm system?
  7. Oct 19, 2021 at 3:21 PM
    Yes. Please tell us which of these options is true for your truck:
    A) You have a factory installed security system (see pic below for what should be on your dash)
    B) You have an aftermarket or ported security system - if so, there should be a brain box somewhere under the driver's side of the dash, either the crappy 'blue box' system that often got ported in, or something else from Viper, Clifford, Avital, or similar, which is often black - most installers zip-tie under the dash, in my experience.
    Here's a pic of what the factory installed system would have in your dash, left of the steering wheel:
  8. Oct 19, 2021 at 4:50 PM
    Desert Dog
    I don't think he'll find that...
  9. Oct 20, 2021 at 7:08 PM
  10. Oct 24, 2021 at 6:21 PM
    mojo73
    As far as I know, it has the factory installed security system. The last owner lost the key fob, so I only lock/unlock it using the key. The problem went away after 48 hours, so i haven't investigated yet. Will use the suggestions here when it comes up again. Thanks!
  11. Oct 24, 2021 at 6:24 PM
    I'd still check just to be sure, but also understand if you don't. It may not be obvious, brain box may be inside or near the driver kick panel. You definitely don't want that in your vehicle if it's there, they only get worse and make more bizarre things happen with age, it seems.
    Other than that, just saying, you may just want to get a new fob. They're super inexpensive and easy to program (pair) as long as you have the ignition key. Can give instructions to add a remote, and to program out functions.
