Bilstein notches
Discussion in 'Suspension' started by Lennys lounge, Jun 15, 2017.
  1. Sep 16, 2017 at 6:17 PM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Rears don't adjust I believe. Just the fronts
  2. Sep 21, 2017 at 3:37 PM
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    Hey guys, a little concerned over here...
    I just had my Bilstein 5100's installed on the middle setting, and my front is probably 2" higher than the rear now. What gives? Any ideas? Anybody else had this issue thus far?
  3. Sep 21, 2017 at 3:38 PM
    JerseyTundra1260
    Marc
    New Jersey
    Did you install 5100's in the rear as well?
    BeachyTundra[QUOTED] likes this.
  4. Sep 21, 2017 at 3:42 PM
    BeachyTundra
    Brandon
    Spokane
    I did indeed install 5100's in the rear as well.
  5. Sep 21, 2017 at 3:50 PM
    JerseyTundra1260
    Marc
    New Jersey
    That definitely does not sound right. You should be sitting with a little rake still. Mine are on top setting and I sit level with the rears.
  6. Sep 21, 2017 at 3:58 PM
    BeachyTundra
    Brandon
    Spokane
    Right? My thoughts exactly. I checked the clips visually, and it is on the middle clip. There is one clip shown below it, which would be the bottom. Correct?
    I did order the parts off of Amazon, I know, I know, but I have Prime and am impatient. I cross checked the part number from my Amazon order, 24-232173, opened the box and looked at the instructions, and middle was supposed to provide 1.6" of lift. I double checked the part number on Bilstein's website, it is also 24-232173.
    My truck only has 600 miles on it, but I cannot imagine that the springs are going to settle two whole inches....
  7. Sep 21, 2017 at 4:10 PM
    JerseyTundra1260
    Marc
    New Jersey
    Not sure. Even if it was on the wrong setting lower or higher it should not be higher than the rear :notsure:
  8. Sep 21, 2017 at 4:14 PM
    BeachyTundra
    Brandon
    Spokane
    Right, my thought's exactly... I just emailed Bilstein about it. We'll see what they come back with.
  9. Sep 21, 2017 at 4:24 PM
    JerseyTundra1260
    Marc
    New Jersey
    Good luck... Keep us posted
  10. Sep 21, 2017 at 7:38 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Brandon did you do the install or have it done ? Make sure the spring seat that holds the coil and sits on top of the clip was not installed upside down. This can cause a huge problem and needs to be changed NOW. When I had the 5100 fronts at top setting I still had a slight rake (lower in front) You definitely have something installed wrong.
  11. Sep 21, 2017 at 7:48 PM
    BeachyTundra
    Brandon
    Spokane
    I was literally just coming on here to post that I had figured out, and they were infact installed upside down by the shop...
  12. Sep 21, 2017 at 7:59 PM
    CM-LENNY
    San Diego, CA
    SOOOOOOOOO scary that shops don't read the directions and follow step by step. I would get it back to the shop ASAP. That spring could let go and cause major damage. So sorry you have to go through this when you pay good money for a pro to do the work. Good luck.....
  13. Sep 21, 2017 at 8:17 PM
    BeachyTundra
    Brandon
    Spokane
    Yeah, that's the plan. Fortunately I'm going out of town this weekend and my buddy is driving. You better believe that they are going to have my truck back in on their lift first thing Monday morning to fix this. Aaaand they'll be putting it on the top setting this time, because you said you still have some slight rake :)
  14. Sep 22, 2017 at 7:45 PM
    CM-LENNY
    San Diego, CA
    Good luck with everything Brandon. Have a good weekend and let us know how it goes Monday.
  15. Sep 22, 2017 at 8:02 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    sub'd since I cant decide between middle or top setting. Fortunately I have a lot of time to decide since it will be a while before I'm able to do this mod.
  16. Sep 24, 2017 at 8:00 PM
    BeachyTundra
    Brandon
    Spokane
    I'll throw up pictures Monday of mine at top setting, although that's probably the most common height for them. I've heard that top setting is effectively level, with a touch of rake, and middle is about 1/2" - 3/4" of rake.
    Tundra Fan[QUOTED] likes this.
  17. Sep 25, 2017 at 6:00 PM
    BeachyTundra
    Brandon
    Spokane
    [​IMG][​IMG][​IMG]
    Here you go fellas. Front is 1/8" lower than the rear at top setting. Perfect.
    Fucking shop still can't get my alignment correct though....
  18. Sep 25, 2017 at 6:50 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    I'd go with the top cuz you can't change it yourself unless you have a spring compressor stand. you just have to order it the way you want them. If you get the front too high just add an Ad a leave, shackle or air bags.
  19. Sep 25, 2017 at 9:48 PM
    #49
    Tundra Fan
    Toby
    Pics didn't work
    Is the alignment problem because they are on the top setting?
    geno0506 likes this.
  20. Sep 25, 2017 at 10:31 PM
    #50
    BeachyTundra
    Brandon
    Spokane
    Weird, your quote shows them for me. Reattaching.
    No, the shop is saying that alignment is all great and good to go, but the fucker pulls right.
    geno0506 and Tundra Fan[QUOTED] like this.
  21. Sep 26, 2017 at 4:53 AM
    #51
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    did you get an alignment printout? if so, what are the numbers?
  22. Sep 26, 2017 at 7:23 AM
    #52
    BeachyTundra
    Brandon
    Spokane
    I did not. I'll see if I can get my hands on one.
  23. Sep 26, 2017 at 8:42 AM
    #53
    Tundra Fan
    Toby
    Maybe I will go with the top setting whenI finally can do this. As long as it's not putting undue strain on anything and will last a long time. If I want to raise the rear a little bit to keep the rake I'll figure out something.
  24. Oct 10, 2017 at 7:00 PM
    #54
    borntostun
    borntostun New Member
    Hi all. Going with the 5100s all around, at top setting on the front . . . and 1" block in the back just keep a slight rake.
    After driving around my new '18 stock . . . I've fallen in love with the smooth and quiet ride. For those that have done the 5100 install . . . I assume the ride would remain nice, maybe better? Just wondering if the top setting causes less movement and hence a stiffer ride. Thoughts?
    Also, I've live the BFG KO2 and Duratrac life, and I am leaning toward keeping a quieter tire on this build . . . has anybody seen or had a nice setup tire wise that would maybe only take me up a bit from stock, while also keeping the smooth ride?
    Thanks everyone.
  25. Oct 25, 2017 at 4:10 AM
    #55
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    True, but the descriptive text on some web sites is misleading.
    "Multiple snap-ring grooves in the shock body allow for different spring seat positions, providing 0" to 2.5" of front end lift, depending on application."
  26. Oct 26, 2017 at 6:25 PM
    #56
    SC_HANK
    SC_HANK New Member
    2016 Tundra TRD Off-road
    I am new to this so excuse my ignorance- did you install in front and rear?
  27. Oct 26, 2017 at 6:35 PM
    #57
    mlong219
    mlong219 New Member
    @SC_HANK , I installed the 5100s on the front and rear of the truck.
    SC_HANK likes this.
  28. Nov 2, 2017 at 8:45 AM
    #58
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Did you get this in alignment @BeachyTundra? I was under the assumption 2in of lift wasn't that hard to align with the stock UCAs.
  29. Nov 2, 2017 at 6:26 PM
    #59
    BeachyTundra
    Brandon
    Spokane
    I did get it in aligned. Everything came back great.
  30. Nov 25, 2017 at 12:11 AM
    #60
    geno0506
    geno0506 New Member
    Michael
    What he said ^ exactly for mine as well! I bought the CB 1.5 shackles but didnt need them so they are collecting dust!
