Bilstein notches
Discussion in 'Suspension' started by Lennys lounge, Jun 15, 2017.
  1. Jun 15, 2017 at 2:28 PM
    Lennys lounge
    Lennys lounge [OP] New Member
    Leonard
    Northwest PA
    15 tundra crew max
    The lower notch is factory? Middle little lift ? Top to much to level with nothing added to rear?
  2. Jun 15, 2017 at 2:46 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    3 settings for those on the tundra. 0.75", 1.5", and 2.25" of lift.
    MotoTundra and 14burrito like this.
  3. Jun 15, 2017 at 2:49 PM
    Lennys lounge
    Leonard
    Northwest PA
    15 tundra crew max
    Will the top setting make the front to high getting ready to install? I've read it before just making sure I don't want to do it twice !
  4. Jun 15, 2017 at 2:51 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    What Bilsteins are we talking about? 5100's? 6112s? Top notch on the 6112 is 2.5 inches of lift which will make the nose be higher than the bed.
  5. Jun 15, 2017 at 2:53 PM
    Netmonkey
    Georgetown, TX
    Ohh. I assumed the 5100's.
  6. Jun 15, 2017 at 2:55 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Top setting rear is still a bit higher
    geno0506 likes this.
  7. Jun 15, 2017 at 2:56 PM
    Netmonkey
    Georgetown, TX
    The top setting with the 5100's will make it just about level. Keep in mind that the farther you get past 2" of lift, you will have more of a challenge to align it properly. 2.25" is on that edge. If you went, 2.5", I would get aftermarket UCA's.
    NewImprovedRon likes this.
  8. Jun 15, 2017 at 2:58 PM
    Lennys lounge
    Leonard
    Northwest PA
    15 tundra crew max
    OK the middle notch it is for today thank you !
  9. Jun 15, 2017 at 3:29 PM
    Netmonkey
    Georgetown, TX
    Cool. That's what I did too. 5100's on the middle setting. You can check out my build thread for pics.
  10. Jun 15, 2017 at 3:46 PM
    laniermax
    laniermax New Member
    Jack
    Atlanta
    2014 Tundra Limited 4x4 DC TRD Off-Road, Sunset Bronze
    Retrax Pro, AMP Bed Step, Aries 3D Mats, Thule Roof Rack, Bilstein 5100's, SCS SR8 Wheels, Toyo AT2's.
    I have a 2014 DC 4x4 w/ TRD Off-Road. I went with the middle setting on the 5100's and the rear sits just slightly higher than the front - exactly what I wanted. The top setting would have been too high. I'm not doing anything too radical on wheels/tires - 18" SR8 w/ 25 offset and LT285-65-18. Just had to remove the small front mud-flap to clear.
  11. Jun 15, 2017 at 5:09 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    On my '16 I went top setting and it sat fairly level, tail still higher, and measured the same front and rear as a stock Pro. That was with 5100s
  12. Jun 21, 2017 at 4:05 PM
    empenaflor
    empenaflor New Member
    2014 TUNDRA 4X4 LTD - Black
    I just had them installed yesterday, I'll post a picture when I can. I have it on the highest setting and also had the 5100s installed on the rear. It sits pretty level, I'm running 17" XD301s and 35x12.50r17 BFG KO2s. There is some rubbing that I need to take care of though, I'll probably get it trimmed
  13. Jun 21, 2017 at 4:14 PM
    Lennys lounge
    Leonard
    Northwest PA
    15 tundra crew max
    Im in the middle on the front nothing in the rear running 285 70r 17 bf Goodrich ko2 also . Sits decent if I went to top setting then my tires would look small im thinking!
    MotoTundra likes this.
  14. Jun 21, 2017 at 4:36 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Top setting up front, no lift out back. Bed had maybe 250lbs gear in it during the time of the pic.
    285/75/17 with no issues
  15. Jul 3, 2017 at 2:35 AM
    Apasion217
    Apasion217 New Member
    2016 Magnetic Grey Tundra
    I went top setting and the tire place was able to align my tires with no problems. IMG_0891.jpg
    CJ21 likes this.
  16. Jul 22, 2017 at 6:48 AM
    mlong219
    mlong219 New Member
    Does anyone have photos of both middle & top settings of the 5100's, so I can see the difference in height on the truck?
  17. Jul 22, 2017 at 7:16 AM
    Netmonkey
    Georgetown, TX
    Here is the middle setting. You can see the top setting on Apasion's post above.
    CJ21, be77solo, MotoTundra and 2 others like this.
  18. Sep 9, 2017 at 10:41 AM
    mlong219
    mlong219 New Member
    I want to say thanks, for suggesting the middle setting for the 5100 Bilsteins. I love the way my truck looks now!
  19. Sep 9, 2017 at 11:51 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    You guys are making me want to spend money....
    kenomouth64 likes this.
  20. Sep 9, 2017 at 1:03 PM
    Netmonkey
    Georgetown, TX
    Lol. That is the danger of this site. After I joined, I could only resist the mod bug for a year. :)
    MotoTundra[QUOTED] likes this.
  21. Sep 9, 2017 at 1:07 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That is fact! There is a competition between boat fund vs. truck fund, haha. I need to choose wisely.
  22. Sep 9, 2017 at 1:10 PM
    Netmonkey
    Georgetown, TX
    Oh man, that's a tough one :) good luck :)
  23. Sep 9, 2017 at 1:46 PM
    dejabrown
    dejabrown New Member
    Dave
    Gilbert, AZ
    2010 Crew Max Platinum
    Backflip cover, OME suspension, Smittybuilt M1 rear bumper, Move front bumper
    My 2010 2WD was lowered when I bought it. Thinking about OME mediums with their CS055R rear leafs. Any opinions? Also do I need to replace the front upper control arms? (Slee Offroad) Any advice?
  24. Sep 10, 2017 at 6:16 AM
    Netmonkey
    Georgetown, TX
    mediums? is that the 613 coils?
    http://toyteclifts.3dcartstores.com...t-4x4-Tundra-lift-with-shockscoils_p_227.html
    I think the CS055R leafs are for the Dakar leaf pack:
    http://toyteclifts.3dcartstores.com/D28XL--OME-Extra-leaf-for-CS055R-springs_p_1574.html
    but there are add a leafs for the stock tundra leaf pack:
    http://toyteclifts.3dcartstores.com/TAC-AL-LA--Rear-ToyTec-Add-A-Leafs_p_303.html
    the OME shock and coil lifts about 2.5". that is right on the edge of needing aftermarket UCA's. you might be able to get a proper alignment. if it was me, I would get UCA's.
    i know that you are interested in the Slee Offroad, but checkout the toytec site. they have more lift options.
  25. Sep 10, 2017 at 5:24 PM
    dejabrown
    Dave
    Gilbert, AZ
    Will do. Thanks!
  26. Sep 10, 2017 at 5:26 PM
    dejabrown
    Dave
    Gilbert, AZ
    My Tundra came lowered (used) so I don't trust the rear springs to be usable. There's about 1" between the springs and bumpstops in the rear.
  27. Sep 10, 2017 at 5:27 PM
    dejabrown
    Dave
    Gilbert, AZ
    Also - I have 2" OME springs and lift with OME shocks on my 97 LandCruiser an d they ride superbly.
  28. Sep 11, 2017 at 6:01 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I have had the OME 614 kit (medium length) on my Tundra for over three years now. They are pretty much bullet-proof.
    From what I've seen, 612 (shortest) gives around 3 inches of lift, 614 gives around 3.5 and 613 (longest) gives more than 3.5.
    Officially, they don't recommend OME for 4x2s. There are Tundra people who have installed the kit on 4x2. They seem to get a tad more lift than 4x4s.
    I would recommend 612 for your truck without a heavy bumper. You will probably get a little over 3 inches and you may get away from having to purchase a set of UCAs.
    Dakar springs, from everything I read, are awesome (that will lift the rear about 2.5 inches).
  29. Sep 16, 2017 at 4:47 AM
    JerseyTundra1260
    JerseyTundra1260 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
    Top setting....... No problems and rides great.
    geno0506, CJ21 and onetohunt like this.
  30. Sep 16, 2017 at 6:15 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    What setting is from the factory? I just installed new 5100's on the rear today. Did not see how they adjust? Is it the flat spot on top? Also how many leaf springs come stock? CM SR5 2008. Mine has three skinny ones and one fat one? Thanks. DIMG_6952.jpg
