Bilstein 5100's in front with stock springs enough to level?
Discussion in 'Suspension' started by rustynail11, Mar 7, 2018.
  1. Mar 24, 2023 at 1:16 PM
    #121
    spensane
    spensane New Member
    Jeremy
    2008 CrewMax Tundra
    Where is the best place to buy 5100's from? I want completely assembled fronts and 5100's for the rear. Also, what spring are y'all that had them assembled go with?
  2. Mar 25, 2023 at 12:28 PM
    #122
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    I’m not the expert but 5100 uses your stock springs so not sure you can get fully assembled
  3. Mar 25, 2023 at 1:35 PM
    #123
    spensane
    spensane New Member
    Jeremy
    2008 CrewMax Tundra
    I can’t use my stock springs. One is broken.
  4. Aug 10, 2023 at 5:23 PM
    #124
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    So you can use 5100 with stock springs and get 2.5” level?
  5. Aug 10, 2023 at 5:41 PM
    #125
    Yes
    Tsm503[QUOTED] likes this.
  6. Aug 10, 2023 at 5:58 PM
    #126
    2020cement_tundra
    2020cement_tundra New Member
    Nick
    SC
    2020 tundra
    I purchased from hotshot off-road. Great prices, and excellent customer service.
    Tsm503 likes this.
  7. Aug 12, 2023 at 2:59 PM
    #127
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    Ok, I read the entire thread and no one mentioned if the stock UCAs contact the coil spring at full droop. I have a recently acquired 15 double cab SR5 4x4. Previous owner installed a 3.5 / 1.5 spacer lift that has to go. Dirt roads are the extent of my off roading. I want to do this once and be done with it. Would 5100s on the middle setting cause the UCA to hit the spring? A small rake would be fine.
    Thanks
    Tsm503 likes this.
  8. Aug 13, 2023 at 7:04 AM
    #128
    2020cement_tundra
    Nick
    SC
    2020 tundra
    On my 2020 the middle setting with stock springs and no other modifications works fine with 285/75/18. Nothing hits anywhere.
  9. Aug 13, 2023 at 12:30 PM
    #129
    DCRB4X4
    DCRB4X4 New Member
    Thank you
    I have a set of fronts on the way.
