Bilstein 5100's in front with stock springs enough to level?
Discussion in 'Suspension' started by rustynail11, Mar 7, 2018.
  1. Jan 29, 2020 at 7:57 AM
    #91
    pauldrade
    pauldrade Drade Tundra
    Paul
    2013 tundra double cab
    3" lift, 33” tires open country AT2, 18" Mayhem rims, flowmaster exhaust, K&N intake, smoke rear lights and 3rd brake light. Optima RED Top battery, LED Lights all around, Mesh black Grill, Alpine double dash Nav head unit. Suspension 5160s rear 5100s front.
    Can you fit 33x12.50 wide tires with a 2.5” lift? Can anyone answer that one? Would really like to see if anyone has that set up. Thanks guys
  2. Jan 29, 2020 at 7:57 AM
    #92
    pauldrade
    Paul
    And anyone know best place to buy a front strut bar for a 2013?
  3. Jan 29, 2020 at 8:40 AM
    #93
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    What's a strut bar? Also, Tundras have coil overs, technically not struts.
    If you're asking about a coil bucket brace to brace the tops of the coil overs, there are some people working on creating one. LSK has one for their Race Kit.
  4. Jan 29, 2020 at 10:24 AM
    #94
    pauldrade
    Paul
    Sorry I meant sway bar
  5. Jan 29, 2020 at 10:43 AM
    #95
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    Are you looking for the standard swaybar that comes on all Tundras or the (red) TRD Pro swaybar? Coolsprings Toyota or Sparks Parts is a good online option. Swaybars are large to ship so if you are a Costco member, you can get a 15% off coupon for parts & service from a local participating dealership. https://www.costco.com/auto-program-parts-services.html
  6. Jan 29, 2020 at 11:36 AM
    #96
    pauldrade
    Paul
    Yes the red trd pro. Thank you!
  7. Jan 29, 2020 at 4:57 PM
    #97
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    Can you please pot a few pics of you truck?
  8. Jan 29, 2020 at 5:32 PM
    #98
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    rv740, Chucho[QUOTED] and Pbed85 like this.
  9. Jan 29, 2020 at 10:25 PM
    #99
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    Thanks SprinterAE86, Nice looking turck!
    Are you running stock UCA?, are the spacers in the coils or does it sit on top of assembly.
    Did you have to do BMC?
  10. Jan 30, 2020 at 8:06 AM
    #100
    SprinterAE86
    Ian
    Tuff country 2" level kit, 5100 bottom setting. 18x9 +12 w/ 295.70.18 Stock UCA, no BMC. Mud guard delete and front flap. Shim bumper 1/2" forward and move bumper trim forward. Still a slight rub on driver side body mount on reverse at full crank.
    18x9 +25 or +18 should not have any body mount rubbing. Still have to remove three mud guards and shim bumper.
  11. Feb 4, 2020 at 9:29 AM
    #101
    turk
    turk New Member
    greg
    millersville pa
    2011 platinum
    i guess what i am asking i just want to level the truck out with the 5100s [2011 platinum crewmax] so what setting do i need to achieve that not touching the rear. i pull a boat around 5k with sometimes 4 people.Right now stock the rear doesn't squat.I would like to go up in the profile to a 65 on stock 20" wheels.all answers appreciated.thanks greg.Right now there is 8" on the rear from the tire to the wheel well and the front 6".
  12. Feb 4, 2020 at 10:17 AM
    #102
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Middle setting...
  13. Apr 12, 2020 at 7:47 PM
    #103
    FXFormat
    FXFormat New Member
    Curious on why you did this along with the spacer, wouldn't it be better to just have the 5100's on the highest setting and ditch the block?
  14. Apr 13, 2020 at 5:41 AM
    #104
    wildbill2020
    wildbill2020 New Member
    2020 tundra sr5 crewmax
    5% tint all around, 35% tinted windshield with a 5% brow, removed stickers/decals
    Bilsteins in middle setting, 20x9, -12 wheels, 33-12.50-20 Toyo MT. Removed all mud flaps, no rub EA7C8E6D-3297-4658-B2CD-5801538CFB26.jpg
    rv740 likes this.
  15. Apr 13, 2020 at 5:46 AM
    #105
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    With the 2" leveling on top of the 5100 you might have to look at extending the bump stops more than just the washers that came with the 5100s. Those washers are sufficient for the 5100s only, but if you add the spacer you might bottom out and damage your shocks.
    SprinterAE86[QUOTED] likes this.
  16. Apr 16, 2020 at 10:44 AM
    #106
    SprinterAE86
    Ian
    I bought the spacer before the shocks. Since I have it already, I installed it. I'll be upgrading my springs soon and it will go to the oem to be used as a reassembled spare to bring with me for my cross country trip next year.
  17. Apr 16, 2020 at 11:17 AM
    #107
    FXFormat
    FXFormat New Member
    How do you like the ride quality of the 5100s? I found mine to be a bit stiff, my gf says the same thing, so then i had to go back to stock suspension and i shimmed a 1" block in the front shock and it was more comfortable.
  18. May 11, 2020 at 2:06 AM
    #108
    Bloomjtundra
    Bloomjtundra New Member
    Josh
    2011 Tundra DC 4x4
    4064732E-E1CF-43AF-9E0D-00AC10A92E33.jpg Just installed 5100’s on the middle setting. Ride is nice, less bouncy than stock from what I can tell in a quick 10mi drive.
    Rear is 5100’s, no lift.
    I have just about 0.5” of rake but it looks level, which is what I wanted.
  19. Oct 10, 2020 at 4:41 AM
    #109
    TOMMYBOY1
    TOMMYBOY1 New Member
    Tom
    2023 Toyota Tundra Trd Sport Crewmax
    I have top setting on the 5100 and 1 inch block in rear , rear is 1.5 inch higher in back then front
  20. Dec 5, 2020 at 7:24 PM
    #110
    Bluesttape
    Bluesttape New Member
    Jesse
    2021 Grey Platinum
    Wow. Info overload. A lot of great info here. I’m 1 1/2 weeks into my first Tundra (2021 Platinum).
    I do want to level it and wonder if anyone has advice on my specific needs.
    1) RIDE QUALITY - this will be my daily driver. I also have 2 kiddos still in car seats so this is also our road trip vehicle. I’m to a point that I enjoy comfort.
    2) CAMPER - I currently pull a 2500lb pop up camper, only 10 times a year. Usually less than 5 hours each way. I doubt I’ll get a bigger one in the future but who know.
    3) OFF ROAD - I don’t ‘wheel’ often but I do go on some fairly rocky roads a few times a year to explore, fish, camp, etc. Not often but I definitely wouldn’t take our Outback on these roads.
    4) just a reminder that ride quality is #1
    current considerations
    - Bilstein 5100 at middle setting
    - Bilstein 6112 at ______ setting
  21. Jan 4, 2021 at 6:40 AM
    #111
    thetastelingers
    thetastelingers Master Baiter
    Soddy Daisy, TN
    2021 MGM CM Sport
    In process
    Figured I would add my experience to this thread, since I used it before I raised my truck.
    2021 TRD Sport
    Bilstein 5100s on the top setting.
    The rear is 1/4" lower than the front. This picture is stock rear, but I've ordered Coachbuilder +2 shackles to raise the rear.
    [​IMG]20210101_153428 by Robert Stewart, on Flickr
    Boerseun likes this.
  22. Sep 22, 2021 at 8:55 AM
    #112
    bigrigg101
    bigrigg101 New Member
    Washington, MO
    2015 Platinum CM TUNDRA
    Having 5100's installed on a 2015 CM Platinum. Shop said the highest setting was compressing the factory springs too much. Anyone else have reports of this? I put matching 5100's on the rear already.
  23. Sep 26, 2021 at 12:34 PM
    #113
    eagleguy
    eagleguy New Member
    Ok. Between the sloped surfaces, different size tires and other modifications the photos of the front lift are all over the map.
    21 SR5 stock CrewMax. Is it the 5100's on the middle or top section that levels things out with NO other items added or removed?
  24. Oct 3, 2021 at 9:48 AM
    #114
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    I have 5100’s set on the middle setting. The truck looks leveled, but the rear is 1.5” higher (measured from the ground to the top of the wheel well). My truck looks like r1-superstars except green. Middle setting is the way to go IMO.
    mattyd170 likes this.
  25. Feb 3, 2022 at 9:38 AM
    #115
    tsgoodwin23
    tsgoodwin23 New Member
    2020 tundra TRD Sport
    Do you have to get anything else that doesn’t come with the shocks for a shop to install them?
  26. Feb 3, 2022 at 9:47 AM
    #116
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Nothing else was needed. 5100's use your stock coils so the shop will take your stock springs and top hats to assemble the fronts. They would use the stock bushings from the rear to install 5100s on the rear corners.
  27. Mar 20, 2023 at 5:42 AM
    #117
    BigWheel
    BigWheel New Member
    Do 6112’s or 5100’s ride better? (I will be using the lowest height setting)
  28. Mar 20, 2023 at 6:44 AM
    #118
    old dude
    old dude New Member
    2011 SR5 4WD
    FYI I installed 5100s on the front of my 2011 at the highest setting. truck is now level with no load in the bed. No problems with original springs, ride might be a little stiffer than OEM. I installed them because I use a Fisher plow and the original rake on the truck screwed up the plow geometry. Was a pretty easy install although I have a good spring compressor and lift in my shop.
    BigWheel likes this.
  29. Mar 20, 2023 at 1:16 PM
    #119
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    Honestly, it depends on what you want and what you will be doing with the truck. I have had 5100s in the middle setting, and they are great. For my 85% on the road and 15% light off-roading, they were all I ever needed. My friend has 6112, and he loves them, but he is doing heavy off-roading every weekend and is also waiting for the long travel Icon system. 5100's are probably the best shock for 90% of the readers here, but if you want 6112, buy them. You shouldn't regret it, ever, and if you do, you can sell them here quickly and buy 5100s.
    BigWheel[QUOTED] likes this.
  30. Mar 20, 2023 at 1:57 PM
    #120
    2020cement_tundra
    2020cement_tundra New Member
    Nick
    SC
    2020 tundra
    B9172088-84C6-4424-96CA-290A32733E2E.jpg Middle setting front stock rear
