Bilstein 5100's in front with stock springs enough to level?
Discussion in 'Suspension' started by rustynail11, Mar 7, 2018.
  1. Mar 10, 2019 at 3:17 AM
    Yota707
    Yota707 New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    Would you recommend going with the top setting vs the middle setting to get the closest possible to the Pro look as possible?
    OR18TRD[QUOTED] likes this.
  2. Mar 10, 2019 at 3:37 AM
    Yota707
    Yota707 New Member
    David
    Bay Area
    2015 Tundra TRD
    @OR18TRD looks great thank you for all the great information. I’m going to go with the top setting hope it’s what I’m looking for. From there I’ll decide what todo with the rear suspension!
  3. Mar 10, 2019 at 3:46 AM
    Finch
    Finch New Member
    Donnie
    '16 Inferno CM 5.7L TRD Off-Road
    @OR18TRD Please enlighten me on the need for a shackle. Still learning all this.
    AggiePhil likes this.
  4. Mar 10, 2019 at 4:01 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    A block lift makes the springs a little stiffer. A shackle adds the lift without stiffening the rear springs. The Coachbuilder shackles with the new bushings help minimize bed hop.
  5. Mar 10, 2019 at 4:09 AM
    Finch
    Finch New Member
    Donnie
    Thanks. I've since done a little research and it's making sense now.
  6. Mar 10, 2019 at 7:58 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Comparison:
    Bone Stock
    Bilstein 5100 Leveling Shock middle setting
    Bilstein 5100 Leveling Shock top setting w/shims, @BOSS4x4s Shackles top setting
    Ray 10s 18x9 +25mm offset, Falken Wildpeak AT3s 305/65-18; suspension same as above
    vokeydawg, Iw378, splitfuse and 11 others like this.
  7. Mar 13, 2019 at 8:41 AM
    owb2gp
    owb2gp New Member
    ID
    So the place that put my 5100's in all 4 corners did the top setting in the front. Sometimes it looks level and other times nose high. I bought a 1" block for the rear, should that make it look better?
  8. Mar 13, 2019 at 9:18 AM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    Level ground and tape measure are the only way to really know. Measure straight up from the ground through the middle of the wheel to the wheel well, then see if difference between front and rear. That will tell you the difference or if there is still some rake.
    I did 5100's on the middle with 2 CB shims in front, got exactly 2.5 inches of lift. I set about 3/4 of an inch higher in the rear, looks level, looks good and feels good. 33" tires are on the way.
    Picture is on a slight down hill angle of the road in my neighborhood. Should give an idea.
    owb2gp[QUOTED] likes this.
  9. Mar 21, 2019 at 7:01 AM
    2019-1794
    2019-1794 New Member
    2019 1794 Crew Max 4x4
    275/65/R20 KO2 with 5100's @ middle setting
    iWoosa, CaptJim1794 and mattyd170 like this.
  10. Mar 21, 2019 at 7:26 AM
    r1-superstar
    DB
    UTAH
    Your truck still looks nose high; not level.
    Measure from the center of the rim to the fender rather than from the ground. This way you take out the tire and difference in inflation out of the equation.
  11. Mar 21, 2019 at 7:27 AM
    r1-superstar
    DB
    UTAH
    You should definitely be nose high. The 1" block, would bring you close to level. Only thing you can do is install them and see. I still think you will be nose high with adding the 1" block.
  12. Mar 21, 2019 at 12:32 PM
    mattyd170
    Albuquerque, NM
    Here is with the new tires. I forgot the measurement, I will have to get them again. Front is slightly lower than the rear, like 1/2" or so from what I remember. 275/60R20 Falken AT3 tires.
    parker44, BC.TRD and 2019-1794 like this.
  13. Apr 11, 2019 at 6:23 PM
    Marco
    Marco New Member
    5100 top setting with 275 65 R20 on 20 Rotivia LT tires no rubbing. the the Rim tire give 2" of lift 41 back and 41 and 5/16 front
  14. Apr 24, 2019 at 1:18 PM
    BC.TRD
    BC.TRD New Member
    2019 TRD OFF ROAD CEMENT
    1 CB shim each side?
  15. Apr 25, 2019 at 8:27 AM
    Cdorman
    Cdorman New Member
    Oklahoma
    2015 - SR5 - CM - MGM
    Color match MGM Bulge/Grille Trim Pro Grille TRD Pro Headlights(black) OEM led fog lights upgrade Headlight Revolution HID upgrade TVD vinyl decals Fog lights Always MOD Bilstein 5100’s 12Volts remote start kit PowerBass plug/play speaker upgrade
    Following :spending:
  16. Apr 25, 2019 at 10:00 AM
    Marco
    Marco New Member
    5100 I painted my springs. Set on 3rd setting my front is 40.8”rear 41” I set my snap rings then plastic steel in 4 spots on under side of clips. 275 65 20 tires I get 41” lift in total. Rides great.70C6A3EE-4F5D-47A7-A28E-F590DD05A098.jpg 0445536D-A320-4CBE-BF5B-3892B62AEE49.jpg
  17. Apr 25, 2019 at 4:41 PM
    mattyd170
    Albuquerque, NM
    No, I put the 5100's in the middle setting and 2 CB shims on each side. Of course, I am writing this and don't have my measurements, but I wanna say like 2 1/4 to 2 1/2 inches lift in front.
    The pictures are deceiving too. When the truck is just parked out there in a parking lot, it looks perfect and level. Can't tell any difference front to back. I parked really far away from Lowes the other day so I could walk up and see it from afar, looks so good. Super happy. If anything should have gotten 275/65/R20 tires for a little bigger tire, but I'm good..................for now. hahahahah.
    Marco likes this.
  18. Apr 25, 2019 at 5:21 PM
    Marco
    Marco New Member
    I got my Rotivia 275 65 20 tires off E bay
    For 680 thier LT 10 ply E. Great deal. They’ll give u 2” lift with your 20”s
  19. May 2, 2019 at 4:15 AM
    #49
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    What setting for the front?
    Doing my homework. This is likely the exact path I'll go.
  20. May 2, 2019 at 6:20 AM
    #50
    Wvmoonshiner
    Wvmoonshiner 2020 T4R Venture SE
    Chuck
    West Virginia
    2020 T4R Venture Midnight black
    Top setting
  21. Nov 13, 2019 at 5:13 PM
    #51
    TNTundra7
    TNTundra7 New Member
    TN
    2016 SR5 4WD 5.7L
    Bilstein 5100s, TRD RSB, TRD Wheels
    Anyone have a pic with the 5100s on the next to lowest setting? My goal is similar to that of the OP's.
    Also, am I correct that even if you set them to stock, there is still a slight lift? Thought I read that the lowest setting is like 0.84" or something?
  22. Nov 13, 2019 at 5:33 PM
    #52
    Marco
    Marco New Member
    2881A8B7-A63A-4CBF-B3C7-B33A0A23AB18.jpg 2881A8B7-A63A-4CBF-B3C7-B33A0A23AB18.jpg 2881A8B7-A63A-4CBF-B3C7-B33A0A23AB18.jpg The upper setting will give you a level look
  23. Nov 14, 2019 at 2:54 PM
    #53
    Zum
    Zum New Member
    NS Canada
    There's a thread with pictures of 5100s on bottom or lowest clip. There is a .87" raise to the lowest setting.
    TNTundra7[QUOTED] likes this.
  24. Nov 14, 2019 at 3:38 PM
    #54
    Ol' Salty Dawg
    Ol' Salty Dawg New Member
    2017 Tundra 2WD XSP-X
    except an alignment.
  25. Nov 15, 2019 at 4:33 AM
    #55
    Crewmax808
    Crewmax808 New Member
    Honolulu, Hawaii
    2016 Sunset Bronze Mica Tundra Crewmax
    TRD Swaybar, 20"Black Rhino Traverse wheels wrapped in Toyo Open Country ATIIs, Bilstein 5100s on all corners, BAKFlip MX4 Bedcover
    2nd to lowest setting, 5100s on all 4 corners20191114_192548.jpg 20191114_192548.jpg
  26. Nov 15, 2019 at 12:02 PM
    #56
    TNTundra7
    TN
    2016 SR5 4WD 5.7L
    Thanks! Looks good. Stock wheel/tire sizes?
    Crewmax808[QUOTED] likes this.
  27. Nov 15, 2019 at 3:20 PM
    #57
    Crewmax808
    Honolulu, Hawaii
    20x9 Black Rhino Traverse wheels wrapped in Toyo Open Country AT II's, 275/55/20
  28. Dec 4, 2019 at 6:48 PM
    #58
    GATORthaBEAST
    GATORthaBEAST New Member
    2019 Tundra SR5 2WD Silver Sky Metallic
    18x9 METHOD MR312 w/BFG A/T KO2s, TRD DUAL EXHAUST, TRD PRO SKID PLATE, BLACK TOYOTA NERF BARS......work in progress.
    Can anybody give me some insight....I just ordered 5100s for the front and 2 Coachbuilder 1/4" shims and the plan is to do the middle setting plus add the shims to get me right at 2" of front lift. After several hours of research her on the forum, some people say middle setting gets you level. Some say top setting gets it level. Well that's an inch difference from middle to top. Give or take. I want it to be level with no rake. If it ends up being nose high, I'll just add some shackles in the back. I wanted to run 6112s at 1.9" but they are out of my budget. I initially ordered a 2" spacer kit, but after pretty much everyone on here saying not to do spacer, I went with 5100s. A guy on here did 5100s middle setting with a CB shim on each side, and it looked exactly how I want it. Any advice would be great. So confused. Seems like every truck is different. Waiting on the 5100s, already have my wheels (Method 312s) and decided on 275/70/18 BFG k02s. Just gotta get it all installed.
  29. Dec 4, 2019 at 7:05 PM
    #59
    whiskeydrink
    whiskeydrink Asst to the Regional Manager
    West TN
    2019 QS SR5 Offroad
    Just had my 5100s installed. I wanted middle setting with no shims to keep some rake. The shop installed them on the top setting instead, with no shims, and a stock rear, and honestly I’m glad they did. The truck looks dead level. Sometimes I think it might be a touch nose high, but maybe bc I’m just paranoid. Hope this helps.719EF8A1-2AD2-4693-A3C9-B199993E14D5.jpg
  30. Dec 5, 2019 at 8:11 AM
    #60
    GATORthaBEAST
    Thanks!! That’s what I’m looking for is dead level. And this is why I can’t make up my mind. Every truck looks different!!! Hahaha
