Bikes and Tundra
Discussion in 'Sports, Hobbies & Interests' started by scurdyness, Dec 17, 2016.
  1. Jul 29, 2020 at 9:39 AM
    #781
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Can anyone recommend a somewhat cheap bike tool set....i see the park tool kits for a few hundred up to 7 grand...not interested in doing much but changing petals and maybe a chain or two. Also can anyone suggest a bike stand so I can work on it.....somewhat cheap...thanks
  2. Jul 29, 2020 at 10:11 AM
    #782
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  3. Jul 29, 2020 at 10:12 AM
    #783
    RollTide82
    Michael
    2019 Tundra 4x4
    Looks good to me
  4. Jul 29, 2020 at 12:29 PM
    #784
    Warreng
    Warreng New Member
    A hex wrench set is about all you need to do basic work on a bike. Not much to them.
    I will add to that, a spoke wrench, chain break and brake bleed kit.
    Mountun Goat likes this.
  5. Jul 30, 2020 at 7:42 AM
    #785
    SomdTundra
    SomdTundra New Member
    2016 Crew Max
    6 inch Rough Country Lift NITTO Ridge Grappler 35’s American Thunder Flowmaster Dual Exhaust Moto Metal Rims
    2020 Roubaix leaning on the Tundra kickstand. Moved over to this Specialized road bike this year after riding a Cannondale for a few decades. Getting fitted and a tune up this afternoon.
  6. Aug 1, 2020 at 11:57 AM
    #786
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    0732C077-D80C-449F-899B-AFDB3D921F5E.jpg A few rides so far and this Hightower rocks. Hit up DuPont state forest early AF to beat the crowds. Plan to do the same tomorrow. Took the lower bearing assembly out, regreased cleaned and reinstalled. Also found a slight driveline noise and sloppy shifting was most likely a loose derailleur. Bike getting washed more than the truck right now, guess it makes sense since the truck is being treated nicer. I’m off-roading the bike and not it.
    Edit: Turned out driveline was actually chromag pedals. Discovered it when I switched back to the XT clipless.
    fuse74, TheBeast, Wallygator and 8 others like this.
  7. Aug 2, 2020 at 8:46 AM
    #787
    Yzed608
    Yzed608 New Member
    Wisconsin
    Little late on the reply, I have a 2015 Kona Lava dome which I believe was $750 new (their site shows the current model as that). Looks like they changed it up a lot since my model (new frame, 1x instead of a 3x in front, and a small upgrade to entry level fork.
    I'll just say what I've done as it's not the same model as the Fire Mountain (appears to only by 27.5, the Lava Dome is 29") but it's in the same price range.
    On mine I replaced the fork because it was truly bad, no rebound damping so if you hit something big enough to get the wheel off the ground it'd smack down and sounded like you were breaking it. The current fork looks like it has lockout (good for climbing) and rebound adjustment so it should be much better than what mine came with.
    I've also had to replace the BB twice and the pedals because of bearings going out, I've also bled the brakes once, and the front derailleur needed some tuning to shift right. Other than that I've liked it, I mainly use it for paved 'state trails' and on my smart trainer. Total between outdoors and indoors it has about 1,600 miles on it.
    I've never ridden a 27.5", but I love the 29" wheels, they roll over cracks and stuff so easily, combined with the larger tires for small stuff you really don't need rear suspension.
    Hope that helps somewhat. The main issues I had were just cheaper bearings and a bad entry level fork, but have no problems with the frame or any of the actual Kona parts. I'll admit I think I like the 1x setup on the new model than the 3x just for simplicity.
    Wallygator and Mountun Goat like this.
  8. Aug 2, 2020 at 8:59 AM
    #788
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Appreciate the info. I actually have a 2021 Mahuna on the way. Should be here within 2 weeks.
  9. Aug 2, 2020 at 9:04 AM
    #789
    Yzed608
    Yzed608 New Member
    Wisconsin
    Awesome, have fun man! Let us know how you like it.
  10. Aug 2, 2020 at 6:17 PM
    #790
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    C82F6204-9F94-4CD2-A614-BB187F75505A.jpg Bikes are fun.
  11. Aug 3, 2020 at 1:46 PM
    #791
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I always wanted the sand colored nomad and a sand color Toyota!
    TheBeast likes this.
  12. Aug 3, 2020 at 3:43 PM
    #792
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Thanks! I think this is a better bike for me and I love my cavalry blue.
    Wallygator likes this.
  13. Aug 8, 2020 at 7:27 AM
    #793
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Going here soon
  14. Aug 11, 2020 at 7:02 PM
    #794
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    5DA30200-0599-463E-9DA1-72CB4165419D.jpgMy main bike...
    B9CF31D9-F494-4281-B1CC-B60C37CC2954.jpg...and my single speed.
    No pictures with my Tundra yet. I throw the bikes on my beater car most of the time.
  15. Aug 12, 2020 at 9:16 AM
    #795
    Oey12
    Oey12 New Member
    Joey
    New York
    Well this thread inspired me to go ride and drive my truck .
  16. Aug 12, 2020 at 9:37 AM
    #796
    Newm
    Newm New Member
    KC
    Long live the single speeders! :cheers:
    Oey12[QUOTED] likes this.
  17. Aug 12, 2020 at 11:35 AM
    #797
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    What model bike is that? ... looks fun!
  18. Aug 12, 2020 at 12:13 PM
    #798
    Oey12
    Oey12 New Member
    Joey
    New York
    2019 Giant Fathom 1...great bike for the money if you are trail/XC weekend warrior. When I was younger I had many high end full suspensions. The last couple of years I got back into the sport but with two kids I couldn’t justify spending thousands anymore. Technology has improved tenfold since I stopped riding so now in my opinion entry level bikes are equivalent to mid level bikes from 10 years ago. I am a very happy owner and it really is a blast to ride!
    drobb[QUOTED] likes this.
  19. Aug 16, 2020 at 10:42 AM
    #799
    YotaFan05
    YotaFan05 New Member
    NE OH
    2011 Tundra Crewmax
    We are looking at getting our first bikes for trail riding. I've been looking at the Giant Talon, and currently on a wait list for them. Is there any others I should consider in the <$1000 range?
  20. Aug 16, 2020 at 11:31 AM
    #800
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    The Costco Northrock's are rebranded Giants if you can find any left, just get them tuned because Costco staff who put them together aren't likely bike mechanics. I have not compared the difference in components whether the Talon is a big step up so you might want to check that.
    YotaFan05[QUOTED] likes this.
  21. Aug 16, 2020 at 12:07 PM
    #801
    Oey12
    Oey12 New Member
    Joey
    New York
    The bike I have pictured above (2019 Fathom 1) I was able to get for $950 (msrp was 1450). Multiple bike shops were willing to honor that price. The Talon is a decent bike for lighter riding. The Fathom will serve you much better in the long run and as your skillset improves you will not be force to buy a better bike until you get super serious...
  22. Aug 16, 2020 at 1:10 PM
    #802
    YotaFan05
    NE OH
    2011 Tundra Crewmax
    Thanks! The shop does have some Fathom's on order as well. I will look more into them.
  23. Aug 16, 2020 at 4:08 PM
    #803
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    much harder to find these days, but there are still used bargains to be had... I got my 2014 Giant Anthem 27.5 for $1100 in nearly new condition, retail was about double that. Picked up a $300-350 Novara Duster for my son for $120 plus another $60 or so to replace cables and switch the shifter over to a paddle
  24. Aug 16, 2020 at 8:29 PM
    #804
    TheBeast The Beach
    ended up ordering a 2021 SC Hightower after demo-ing one at my LBS...now the wait.....Stumpjumper, Ripmo V2 were on the short list too.
    been riding my hardtail everyday...thanks covid..
    Skey44 likes this.
  25. Aug 16, 2020 at 8:58 PM
    #805
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  26. Aug 17, 2020 at 9:10 AM
    #806
    tbutler
    tbutler Team Toyota
    2021 Land Cruiser HE - Black
    It took 2.5 months for me to get my new SC Blur. Ordered it March 6, received it May 22. However, they did upgrade my fork and dropper because of the wait. COVID shut the factory down and really hurt production. Hope you get your sooner.
    TheBeast[QUOTED] likes this.
  27. Aug 17, 2020 at 6:47 PM
    #807
    Tundra9831
    Tundra9831 New Member
    The bike industry as a whole has major supply issues right now. Combo of more people riding, supply chain issues, and inaccurate production predictions.
    JoshuaA and TheBeast like this.
  28. Aug 17, 2020 at 6:55 PM
    #808
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Do they make bikes for less than $8k
  29. Aug 17, 2020 at 6:56 PM
    #809
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    You can still get a $12k S-Works it’s just hard to find the <$5k.
  30. Aug 17, 2020 at 7:03 PM
    #810
    Tundra9831
