BiggHertz - DZTLIMO
Discussion in '2.5 Gen Builds (2014-2021)' started by BiggHertz, Jan 25, 2022.
  1. Jan 25, 2022 at 12:13 PM
    BiggHertz
    BiggHertz [OP] DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Just getting this build log going...
    Low Lean and not so mean...
    Current State :
    Vendor Shout Outs (I am not endorsed nor sponsored for any products or services) in no particular order.
    • 2018 Super White CrewMax Platinum 4x4
    Front Suspension (+3"):
    Rear Suspension (+3.25"):
    Wheels:
    • Method MR701 18x9 +25 Matte Bronze - Qty 6
    Tires:
    • Toyo RT 37x13.5r18 - Qty 6
    • Nitto Ridge Grappler 35x12.5r18 - Qty 5 - removed 2022-01-31
    Armor - Exterior:
    Armor - Interior:
    • Window Tint Front: 5% XPEL Prime XR Plus
    • Window Tint Rear: 20% XPEL Prime XR Plus
    • Window Tint Windshield Banner: 5% XPEL Prime XR Plus
    • Front Floor Mats - Husky Liners X-Act Contour
    • Rear Floor Mats - WeatherTech FloorLiner
    Power Delivery:
    Lighting - Auxiliary:
    • Fog - Baja Designs Squadron Sports with Amber Wide Cornering Lenses in Baja Designs Fog Pocket Kit
    • Lower Bumper - Onx6+ White driving combo
    • A-Pillar Spots - Baja Designs XL Racer White High Speed Spots mounted on SDHQ A-Pillar Brackets.
    • A-Pillar “Ditch” - Baja Designs S1 with Amber Wide Cornering Lenses attached to side of XL Racers.
    • Chase - Baja Designs S1 with Amber Wide Cornering Lenses mounted on SDHQ Universal Chase Light Mounting Kit
    • Rock - KC Cyclone V2 x 6
    • Engine Bay - KC Cyclone x 2
    Lighting - Exterior:
    • Puddle - vLED Kit
    • Reverse - vLED HO 7440 6k
    • Front Corner - vLED LL 194 Amber
    • License Plate - vLED LL 194 6k
    • Cargo Lamp - vLED HO 921 6k
    Lighting - Interior:
    • Dome - vLED 6K Long Life 194
    • Visor - vLED 6K
    • Footwell - vLED 6k bar X4 - individually integrated into each seating position.
    Communications:
    Body - Exterior:
    • Mirror Caps - SEM Trim black over OE Chrome
    • Door Handles - OEM Black Handles
    • Front Bumper Spacers - Coachbuilder
    Body - Interior:
    • Vent Rings - SEM Trim Black
    • Driver Side Grab Handle
    • Radio Knobs - AJT
    • Dual Zone Climate Knobs - AJT
    • Climate Control Trim - AJT
    • Shift Gate Trim - AJT
    • 4x4 Selector - AJT
    • Shift Knob - Black TRD
    • Cup Holder Trim - SEM Trim Black
    • Dash Plate - Rago Fabrication w/ ICS Backing Plate
    • 67d mounting solution
    Performance:
    • Throttle Confuser - Pedal Commander
    • Exhaust - Modified TRD
    • Intake - aFE Dry Filter
    In Car Entertainment:
    • Kenwood DMX-1037s
    • JL Audio Stealthbox
    Convenience:
    • Running Boards - AMP PowerSteps - removed 2022-02-20
    • Remote Start - 12volt.Solutions - Standard Kit
    • Aluminum Oil Filter Housing - OE
    • Oil Drain Plug - Valvomax
    Miscellaneous:
    Maintenance:
    • Engine Oil - Amsoil OE 5w-30 (5k/6mo)
    • ATF - planned at 45k
    • Transfer Case - Ravenol 75w (15k/12mo)
    • Front Diff - Amsoil Severe Gear 75w-90 (15k/12mo)
    • Rear Diff - Amsoil Severe Gear 75w-90 (15k/12mo)
    • Power Steering - Amsoil OE Multi ATF (5k)
    • Brake Fluid - Amsoil DOT 3/4 (24 mo)
    Musings:
    Trials and Tribulations:
    Trip Log: (Majority of the photo credit goes to my trail mates)
    -Jason
  2. Jan 25, 2022 at 12:14 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Place Holder
  3. Jan 25, 2022 at 12:15 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Front Suspension (+2.25)
    Place Holder
  4. Jan 25, 2022 at 12:15 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Rear Suspension (+?):
    Out with the "OLD"
    OE vs Deaver U748:
    Fox 2.5 R/R vs Fox 3.0 x 12 Bypass
    Driver's frame rail prepped (OE Bump Pad and Upper shock replaced with TC and Camburg bits):
    Passenger's frame rail prepped(OE Bump Pad and Upper shock replaced with TC and Camburg bits):
    Axle tube prepped for lower mounts (OE lower shock mounts removed):
    Driver side in:
    Passenger side in:
    Undercarriage shot...
  5. Jan 25, 2022 at 12:15 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  6. Jan 25, 2022 at 12:16 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Armor - Exterior:
    2021-05-05 - After 2 months of waiting...was glad to pick up my CBI Full Overland Skid and RCI Gas Tank Skid at SDHQ!
    CBI Overland Skid:
    OE and it's replacement...
    a quick 45 minutes later we go from...
    to
    RCI - Fuel Tank Skid:
    Being a Platinum Trim, there was no skid plate and no provisions for the OEM or RCI Fuel Skid. A set of OEM fuel tank straps with the threaded studs were ordered and installed to give the RCI skid somewhere to bolt to. 3 bolts, 3 cotter pins to replace the straps...
    So a quick 30 minutes went from no fuel tank protection....
    to this...completely worth the price of admission.
    ABS Sensor Guards - SDHQ:
    I only have photos of fronts...
    Before:
    After:
    Bedliner - Line-X Premium
    Bed Channel Stiffeners - SDHQ Built Hidden Bedside Support System
    Many thanks to @TG705 for the smoking deal on these.
    Driver:
    Passenger:
    TRDFerguson and boostedtrdpro like this.
  7. Jan 25, 2022 at 12:16 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Armor - Interior:
    Place Holder
  8. Jan 25, 2022 at 12:16 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  9. Jan 25, 2022 at 12:16 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Fog Light:
    Baja Designs Squadron Sports Amber Wide Cornering in Baja Brackets
    Chase Light:
    I cannot state how important these have proven to be in the dusty/inclement weather conditions we've experienced.
    Baja Designs S1 Amber Wide Cornering on SDHQ Mount.
    High Speed Spot and Cornering Lights:
    Baja Designs Racer Spot on SDHQ A-Pillar Mount w/ Baja Designs S1 Amber Wide Cornering bolted to the side of it.
    Stealth Light Bar:
    Baja Designs 30" Onx6+ White Driving Combo kit.
    mid install..
    done...
    TRDFerguson likes this.
  10. Jan 25, 2022 at 12:17 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    VLED Puddle Lights
    Rock Lights:
    Low Level Design-
    Passenger Front:
    liner removed for picture, but uses longer bolt, spacer and Rago Cyclone Mount, bolted using AIP bolt hole.
    w/liner
    Driver Front:
    Through bolted into Radiator Core Support.
  11. Jan 25, 2022 at 12:17 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Place Holder
  12. Jan 25, 2022 at 12:17 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  13. Jan 25, 2022 at 12:17 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Body - Exterior:
    2021-04-14 Painted Mirror Caps and Black Handles...
  14. Jan 25, 2022 at 12:17 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Body - Interior:
    Interior Black Out...
    SEM Vents, Shifter, Cupholder
    AJT knobs and doo-dads...
    Before:
    After:
    Rago Plate, ICS Backing Plate, 67d base, Arm, Clamp...
  15. Jan 25, 2022 at 12:18 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Performance:
    Throttle Confuser: Pedal Commander
    Exhaust Modification:
    in short, got tired of bonking my TRD duals against my bedsides so decided to dump them...
    Exhaust cutter, elbow grease and slip on turndowns from AFE...
    For those who wish to repeat this modification...see:Warranty Denial - Rear Propeller Shaft Scored by TRD Exhaust Hanger
  16. Jan 25, 2022 at 12:18 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Place Holder
  17. Jan 25, 2022 at 12:18 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Convenience:
    Place Holder
  18. Jan 25, 2022 at 12:18 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Miscellaneous:
    BMC/CMC:
    Mild chop for 35s at OE suspension and alignment.
    Mark cut lines:
    Cut and dress:
    Weld and dress (keep bushing cool with wet rag:
    Rust protection (Steel-it):
    Don't forget the underside...
    Enjoy:
    Rear Differential Breather:
    Thanks to @tempetoyotachad for tracking down the union and breather for me!
    Parts utilized:
    • Toyota Union - 90404-51319
    • Toyota Breather - 90930-03136
    • <15 feet of 5/16" ID fuel line
    • 2 appropriately sized hose clamps for OD of fuel line.
    • zipties!
    Onboard AIR (ARB Twin on SDHQ Mount):
    Parts Used:
    Low Level Circuit Design
    Updated Setup:
  19. Jan 25, 2022 at 1:12 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  20. Jan 25, 2022 at 1:17 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2021-09-11 - Four Peaks
    Went solo, so a few hard parking shots is all I've got...
  21. Jan 25, 2022 at 1:23 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2021-09-18 - Schnebly Hill
    an absolutley random up and back to Sedona...
    Camburg UCA hitting the inner fender shroud...
    some of those rocks were taller then I anticipated... oh well...
  22. Jan 25, 2022 at 4:55 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2021-10-17 - Lower Sycamore Creek
    Not much to report here, met up with @AT x AT, @Olson , @TundraPHX... except @Olson took is Tundra where a Tundra isn't meant to go...that was the last time Olson owned his Tundra...
    Coming to the realization that I'm too caught up in the moment and never take pictures on trips...
    Oh I did learn that there is more then one mode to disable the anti-hoon nannies.... @TRDFerguson - Wasn't present to set me straight...not until after the fact...
  23. Jan 25, 2022 at 5:02 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2021-10-23 - Tundras To Sedona
    Was a long day, drove up from Chandler to Sedona did a Schnebly Hill to T2S Base Camp and then off to "Greasy Spoon/Diamondback Gulch"
    Schnebly Hill Up...had to stop for a few photos...
    Greasy Spoon/Diamondback Gulch:
    Meet up with @AT x AT and @TRDFerguson at base camp for an hour or so then hit the road...
    Trying to track down the photos...
    Front to Back - TRDFerguson, Myself and AT x AT
    AT x AT out front...
    @TRDFerguson
    @AT x AT
  24. Jan 25, 2022 at 5:27 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2021-10-31 - Upper Sycamore
    Met up with @AT x AT for Sunday Funday....
    @AT x AT
  25. Jan 25, 2022 at 6:35 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2021-11-07 - Upper Sycamore Creek
    Met up the the boys @TRDFerguson and @AT x AT for some afternoon fun..
    Helped a fellow adventurer by pulling his Subaru out of creek...
    Trip was cut a bit short on account this guy wouldn't move from the roadway...
  26. Jan 25, 2022 at 6:40 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2021-11-27 - Bulldog Wash to Saguaro Lake - Failed Attempt
    Nobody died..but we (@TRDFerguson) did manage to burn a whole lot of day light and not make it to where we wanted to go...
  27. Jan 25, 2022 at 6:48 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Our poor paint…
  28. Jan 25, 2022 at 6:49 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2021-12-17 - Bulldog Wash to Wolverine - Night Run
    Night run with the boys @TundraPHX and @AT x AT....
    Still looking for photos, but have a night shot flexing my rock lights....
    @TundraPHX view of the chase lights...
  29. Jan 25, 2022 at 6:52 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    nails on a chalkboard for about 6 miles...ish..yeah...that was fun..
    TRDFerguson[QUOTED] likes this.
  30. Jan 25, 2022 at 7:11 PM
    BiggHertz
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2021-12-18 - Bulldog Wash to Saguaro Lake & Upper Sycamore - Redemption
    After admitting defeat and giving the paint some much needed love after our attempt on 2021-11-17, @TRDFerguson and I found our way easily this time...damn you GAIA/iPhone/AppleCarPlay...
    Making our way...
    We made it...
    getting all "insta-famous" for this one...
    But of course, nothing is an adventure like going somewhere where truck should not go...wish I would've gotten a picture of his truck...but steep is a good word to describe his attempt of king of the mountain...
    @TRDFerguson playing with is new DD 42" bar...one might say it is bright...
    Hard parked...
    TRDFerguson and vanthesupreme like this.
