Best roof rack choice for CrewMax... Spider?
Discussion in '2.5 Gen Tundras (2014-2021)' started by GaFFLe, Aug 30, 2020.
  1. Aug 31, 2020 at 10:55 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Yes, for most.
    But to avoid the knucklehead factor it does help.
    And many prefer to not drop their headliners.
  2. Aug 31, 2020 at 11:03 AM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    sf319 and Hightide like this.
  3. Aug 31, 2020 at 11:09 AM
    Hightide
    Abalama
    Magic School Bus
    Didn’t notice he had joined.
    Good stuff.
    Thanks!
    Bob_Wiley[QUOTED] likes this.
  4. Aug 31, 2020 at 11:11 AM
    Bob_Wiley
    Eric
    AZ
    Hightide[QUOTED] likes this.
  5. Aug 31, 2020 at 11:13 AM
    Hightide
    Abalama
    Magic School Bus
  6. Aug 31, 2020 at 12:10 PM
    Spider No Drill Roof Rack
    Spider No Drill Roof Rack New Member
    Tiger
    The mounting brackets are design to wedge into the drip rails. The front and back of the rails help keep the mount from sliding forward or backward when the truck is in motion. With all 6 mounts install properly with the rack, each mount work against each other to keep it in place. (you asked what you do mean???) the design of mounts is to hold itself in place with the roof rack. If you were to try to lift or push the rack up the opposite side will not allow you to lift it up. Because the opposite side is tuck inside and downward toward your lifting position. so you can not lift it up. Now moving forward since the front or back of the drip rail is manufacture smaller in width than the middle. It actually help keep the mounts from moving forward or backward when the truck is in motion. In lams term you can take a round hole and try to stick a square block into it, it won't fit! As for testing most after market companies only do field test beside the big company have funding for it. I hope this help clear some un-answer questions for some of you guys. If you are here in Southern California I would love to meet up with you so you can see it for yourself.
    Hightide and saybng like this.
  7. Aug 31, 2020 at 12:51 PM
    GaFFLe
    GaFFLe [OP] New Member
    Atlanta, GA
    2020 Toyota Tundra Platinum
    Undercover bed sway cases
    I get it, those narrowing drip rails and contoured wedges are your saving grace. I bet those other hack-a-roof concepts wish they had thought of this! Good stuff!
  8. Aug 31, 2020 at 1:10 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    You can install one on my truck and test it for you..:mudding::mudding:
  9. Aug 31, 2020 at 1:34 PM
    Hightide
    Abalama
    Magic School Bus
    I will volunteer for testing as well.
  10. Aug 31, 2020 at 1:36 PM
    Tiger
    thank you for the offer... but I have a few trucks already in testing with it.
    GODZILLA, saybng[QUOTED] and Hightide like this.
  11. Aug 31, 2020 at 1:37 PM
    Tiger
    GODZILLA, saybng and Hightide[QUOTED] like this.
  12. Aug 31, 2020 at 1:38 PM
    Hightide
    Abalama
    Magic School Bus
    Ha! I figured you weren’t lacking for volunteers.
    Thanks for joining and being proactive with discount, answers and descriptions.
  13. Aug 31, 2020 at 8:23 PM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    Yes... but do you have any INFERNO trucks for testing?? Because... if not, I call dibbs.
    :fingerscrossed:
  14. Aug 31, 2020 at 8:35 PM
    Zero One Actual
  15. Nov 28, 2020 at 8:01 AM
    Alkare
    Alkare New Member
    Kevin
    Cotati, California
    2017 SR5 CREWMAX
    Any thought of using this system with load bars?
